When I try to copy a file it ejects the DVD and says that Windows can not read the disc
  • 2,229 Answers
Well, the disk is probably not good. Try another.
If the problem persists, I'm thinking you need a new drive.
Posted on Apr 07, 2011
Error 0a-0224-0000
Dear Vincent,
The 0A-0224-0000 is a "File Copy Failed" error. It means that either the computer was not able to read from the CD/DVD or it finished reading from one CD/DVD and was expecting to read data from the next one (when you have two or more recovery CDs/DVDs). If you have more than one recovery CD/DVD, as soon as you see the CD/DVD reader LED (light) stop flashing, eject the CD and insert the next one in the sequence, doing so till all recovery CDs/DVDs have been read.
If you cannot eject the DVDs by pressing the eject button (some DVD writers only allow you to eject the disc after finishing the whole operation) you will have to straighten up a paper clip and insert it in the small hole close to the eject button to force it open and change the CD or DVD (do a Google search for "how to open a CD or DVD drive with a paperclip, in order to better understand how to do it)".
Hope this helps!
Oct 31, 2013 | Toshiba Computers & Internet
Remove Write protection from DVD disc
1. Insert the DVD disc into the computer's DVD-ROM burner drive. Click on "Burn files to disc" from the window that automatically pops up.
2. Type a name for the DVD disc in the "Burn a Disc" box. Click "Show formatting options" and choose a formatting option.
3. Choose "Live File System" to allow files to be copied immediately to the DVD disc, much like sending data to a USB flash drive or floppy disk. Live File System discs can only be read by Windows XP or later versions. Choose "Mastered" to have files be copied to the DVD all at once. This is the standard burning method; discs can be played back on any DVD-ROM drive.
4. Click "Next" to prepare the disc. Files can now be copied to the disc using the selected method.
Sep 04, 2012 | HP Computers & Internet
How do i format a disk??
Format a CD or DVD
Before you can copy files to a CD or DVD, the disc must first be prepared using a process called formatting. There are several ways to format a CD or DVD disc. Your choice of format determines which computers and other devices will be able to read the disc.
  1. Insert a disc into your computer's CD or DVD drive.
  2. In the dialog box that appears, click Burn files to disc.
  3. In the Burn a disc dialog box, type a name for your new disc.
  4. Click Show formatting options, and then click one of the following formatting options:
    • Live File System
    • Mastered
  5. Click Next to prepare the disc.
    Now you can copy files to your disc using whichever method you selected.
Apr 05, 2011 | Microsoft Windows XP Professional With...
Driver needed for TSST Corp CDDVDW TS-H653N SCSI CdRom Device please. DVD drive shown in My Computer, and MS says I have the correct driver for this device. But, it doesn't work.
If the computer still cannot read a disc, there may be a problem with the drive. Go to method 3 to troubleshoot the CD or DVD drive. If the computer can read the other disc, there is a problem with original CD or DVD. Contact the manufacturer of the damaged disc to obtain a replacement. Method 3: Try a different disc drive If the disc is clean and undamaged, check whether there is a problem with the drive. To do this, follow these steps: If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc. If your computer does not have more than one disc drive, you can insert the disc in a different computer. If the other CD or DVD drive can read the disc, there may be a problem with your CD or DVD drive. Go to method 5. If the other CD or DVD drive cannot read the disc, the disc may not be compatible with the drive. Go to method 4. Method 4: Make sure that the disc is compatible with the drive Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive. A DVD disc is incompatible with a standard CD drive. A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs. A DVD disc is incompatible with a drive that does not have a DVD logo on the front. If the disc is compatible, go to method 5. If the disc is incompatible, use a compatible disc or contact the vendor for a compatible replacement. Back to the top Method 5: Use Windows Update to check for updated drivers If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing. To check for driver updates that you can install, visit the following Microsoft Web site: http://windowsupdate.microsoft.com If these methods do not resolve your issue, try the advanced troubleshooting steps in this article. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help, or you might want to contact Support. For information about how to do this, visit the following Microsoft Web site: http://support.microsoft.com/contactus/ If methods 1 through 5 did not resolve the issue, you can follow these methods to try to isolate and resolve the problem. Method 1: Test the disc by using the command prompt to copy files Try to copy files from the disc to the hard disk. If the hard disk cannot copy files, the disc might be damaged. If the files are copied successfully, there may be file types on the disc that the hard disk cannot read, or there may be a problem with the CD or DVD drive. To test the disc by using a command prompt to copy files, follow these steps: Create a test folder on the hard disk, and then give the folder a folder name such as "cdtest." This is the folder to which you will try to copy files. Click Start, and then click Run. Copy and paste (or type) cmd in the Open box, and then press ENTER. Copy the files from the CD or DVD drive to the test folder on the hard disk. To do this, type xcopy DiscDrive:*.* HardDiskDrive:cdtest /v /e at the command prompt, and then press ENTER. Make sure that you replace “cdtest” with the name of your test folder. Note In this step, DiscDrive is the drive letter of the CD or DVD drive with which you have problems. HardDiskDrive is the drive letter of the hard disk drive to which you want to copy these files. If you are asked whether cdtest specifies a file name or a directory name, press F. If you successfully copied the files from the disc to the hard disk, the disc is not damaged. To remove the copied files, type rd /s cdtest at the command prompt, and then press ENTER. If you cannot copy the files, the disc may be damaged. Contact the manufacturer of the damaged disc to obtain a replacement. To continue trying to isolate the problem and test the CD or DVD drive, go to method 2. Method 2: Test the CD or DVD drive in a "clean boot" state If the disc is readable and undamaged, there may be some hardware or software that is interfering with the CD or DVD drive. You can test this by inserting the disc into the drive after restarting your computer in a clean boot state. This helps you determine whether any hardware or software is interfering with the CD or DVD drive. To test this, follow these steps: Restart the computer in a clean boot state. Note For more information about how to start Windows with a minimal set of drivers, click the following article number to view the article in the Microsoft Knowledge Base: 310353 How to configure Windows XP to start in a "clean boot" state After the computer is restarted, exit all programs and applications that may be using the CD or DVD drive. First, right-click each icon in the notification area, and then click Exit. Note The notification area is located at the far right of the taskbar, near the clock. Some programs that are listed in the notification area do not have an Exitcommand. Therefore, you may have to click Quit, Close, or Disable, depending on the commands that are available for that program. Click Start, and then click Run. Copy and paste (or type) taskmgr in the Open box, and then press ENTER. Windows Task Manager opens. Click the Applications tab. If any programs appear in the Task list, click the name of the program to select it, and then click End Task. Repeat the previous step until the Task list is empty. Close Windows Task Manager. Reinsert the disc in the CD or DVD drive. If the CD or DVD drive can read the disc, there may be other programs preventing the drive from reading the disc. Go to method 3. If the CD or DVD drive still cannot read the disc, go to method 4. Or, if you are not specifically using a DVD drive, you may want to contact Support. For information about how to contact Support, go to the "Next Steps" section. Method 3: Change the CD or DVD drive configuration If there are programs that are preventing the drive from reading the disc, you can try to resolve this issue by configuring the drive to run in direct memory access (DMA) mode. DMA mode is a high performance mode for transferring data to and from devices. These include CD and DVD drives. To configure the CD or DVD drive to run in DMA mode, follow these steps: Configure the CD or DVD drive to run in DMA mode. For more information about how to switch your computer's disc drive controller to DMA mode, click the following article number to view the article in the Microsoft Knowledge Base: 310751 Device settings are hard to find in Windows XP Reinsert the disc in the CD or DVD drive. If the CD or DVD drive can read the disc, you are finished. If the CD or DVD drive still cannot read the disc, try to troubleshoot DVD components by using method 4. Or, if you are not specifically using a DVD drive, you may want to contact Support. For information about how to contact Support, go to the “Next Steps” section. Method 4: Troubleshoot DVD problems If the advanced troubleshooting methods 1 through 3 do not resolve the issue, and you have problems specifically with a DVD drive, follow these steps to try to isolate and resolve the problem. Prerequisite You must use a DVD drive with a DVD logo on the front, not a standard CD drive. Step 1: Unplug any cables that are connected Unplug any cables that are connected to the video outputs of the computer. Reinsert the disc in the DVD drive. If the DVD drive can read the disc, you may have problems with the video hardware installed on your computer. Contact the manufacturer of the video hardware for support or for a replacement. If the DVD drive still cannot read the disc, go to step 2. Step 2: Update the DVD driver Contact the manufacturer of the DVD drive to obtain an updated driver for the DVD drive, and then follow the manufacturer's instructions to install the driver. Reinsert the disc in the DVD drive. If the DVD drive can read the disc, the problem was caused by an outdated driver. You are finished. If the DVD drive still cannot read the disc, go to step 3. Step 3: Obtain a hardware-based DVD decoder or software-based DVD decoder Contact the manufacturer of the DVD drive to obtain a hardware-based DVD decoder or software-based DVD decoder, and then follow the manufacturer's instructions to install the decoder. Note Many video adapters help decode DVD discs. However, the video adapter may not fully decode a DVD movie. Reinsert the disc in the DVD drive. If the DVD drive can read the disc, the problem was caused by an outdated DVD decoder. You are finished. If the DVD drive still cannot read the disc, make sure that the sound card in the computer is compatible with the DVD drive. To do this, contact the manufacturer of the sound card. Reinsert the disc in the DVD drive.
Feb 27, 2010 | Compaq Computers & Internet
When i insert a burned cd, the cd is recognized as such, but it does not see the files on it.It considers it as an empty cd
If you have burned CDs using Windows XP, you are already familiar with the Mastered format. The latest version of Windowsoffers a new format, called Live File System. Discs that use the LiveFile System format are often more convenient because you can copyselected files immediately and as often as you want, as if the discwere a floppy disc or USB flash drive. On the other hand, Live FileSystem discs can’t be used in all computers and devices. Use this guideto understand the difference between Live File System and Mastereddiscs:Discs formatted with the Live File System option:Work like a USB flash drive or floppy disk, meaning you can copy files to disc immediately without having to burn them. Are convenient if you want to keep a disc in the burn drive and copy files whenever the need arises.Are only compatible with Windows XP and later versions of Windows.Discs formatted with the Mastered option:Don’tcopy files immediately, meaning you need to select the entirecollection of files that you want to copy to the disc, and then burnthem all at once. Are convenient if you want to burn a large collection of files, such as a music CD.Are compatible with older computers and devices such as CD players and DVD players.
Why are there different versions of the Live File System format? Eachversion of the Live File System format is compatible with differentoperating systems. Depending on which computers you plan to use a discin, you might need to select a different version of Live File System.If you plan to use your disc on the latest version of Windows,however, you will never need to change the version of Live File Systemyou use. If you need to make discs that are compatible with earlierversions of Windows, use the table below to select the right Live File System version for your needs:
The following table describes Live File System versions and their appropriate uses.
1.02
This format can be read on Windows 98 as well as many Apple computers. You should use this version if you need to format DVD-RAM or MO (Magneto-optical) discs.
1.5
This format is compatible with Windows 2000, Windows XP, and Windows Server 2003. It might not be compatible with Windows 98 or Apple computers.
2.01
This format is compatible with Windows XP and Windows Server . It might not compatible with Windows 98, Windows 2000, or Apple computers.
2.5
This format is designed for the latest version of Windows and might not be compatible with earlier versions of Windows.
For information on how to choose one of these versions when you format a disc, see Format a CD or DVD.
Top of page Foranother computer to be able to read a DVD disc, that computer must havea DVD drive. CDs can be used in both CD and DVD drives.
Oct 26, 2009 | Sony Computers & Internet
I am trying to install windows service pack 1. I keep getting an error code: 0x00F0826. Can you tell me what this means and how to fix it? I am running windows vista basic. 32-bit. Thanks.
if there error appeared while windows copying files then disc OS or the DVD ROM might be faulty. Try to test first the ODD if it is faulty. Use the drivers and utilities cd from dell to test the DVD ROM. If DVD ROM reads fine the drivers disc then try the OS disc to a different computer if it can load vista files. if not the OS disc has the problem. If no issues with OS disc and DVD Rom then it might be the HDD.
Oct 22, 2009 | Dell Inspiron 1420 Laptop
IView 6000kr DVD Player can't play RMVB file from DVD disc
The problem may be that you used a data disc mode. That leads to discs that can be read by other computers not by most DVD players. Did you finalize the disc before removing it from the computer? Try finalizing the disc. From Windows File Explorer, select the DVD drive and choose the Manage tab. Then see if Finish Burning is available.
In the future, make sure that you choose the With a CD/DVD Player option instead of the Like a USB drive. Then finalize the disc before ejecting it. See http://www.online-tech-tips.com/computer-tips/how-to-burn-cds-dvds-blu-ray-discs-windows/ for some tips.
I hope this helps.
May 01, 2017 | iView Multimedia Website Pros Netobjects...
I burnt a data DVD incorrectly and am trying to locate the files
yes, you are right, the picare are stored on the DVD. however, the pic need to be in a windows XP or Vista comparable format (jpag is the most common).
Close the popup asking you "to drag the file to the disc". This is because the dvd is not completely full or you did not finalized the dvd.
go to "my computer" click on the drive where the dvd is loaded. click on open or explorer. you should be able to see what is on the dvd.
Dec 02, 2008 | Computers & Internet
Cannot copy files to DVD disks
when i try to copy and paste file to DVD, through windows, a message appear says"windows encountered a problem when trying to copy this file." i dont know why, could someone help?
i'm upset now. :(
Dec 21, 2007 | Gateway GT4022 PC Desktop
How do I copy the files to my computer?
• Windows XP After connection is established, simply drag-and-drop files, using Windows the PC. The DVD Camcorder appears as an external DVD-RAM drive in Windows • Windows 98SE, ME, 2000 After connection is established, simply drag-and-drop files, using Windows PC. The DVD Camcorder appears as two external drives such as a removable Explorer. If DVD-RAM disc, the movie files will be copied from the removable If DVD-R disc, the movie files will be copied from the DVD drive.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
