Question about Weber Baby Q Grill
Weber Seriel #QT0379827 MOdel #396000 Baby Weber
Flame comes out of the regulator of our large baby weber. what should we do?
    Problem Solver:
  • 11 Answers
CALL WEBER! They'll get some information from you and then either help you fix the problem, replace the defective part or replace the grill. They've never failed to solve a problem I've had with a Weber Grill!
PFSmith
Posted on Nov 23, 2008
FLAME WON'T TURN DOWN ON WEBER BABY Q
Sounds like the reg is letting too much gas pass
Oct 10, 2017 | Weber Baby Q Grill
Weber model 396000 regulator does not work my weber serial number d l 1356456 need to know how to fix it.
Change it I belive you can get regs at candian tire or Calgary BBQ Center
Apr 16, 2012 | Grilling
Baby weber flame will not adjust to different levels stays on high flame even when we turn the knob
You will need to replace the control knob assembly. Which includes the tank hook up & regulator. Contact Weber Customer Service @ 1-800-446-1071 for this part.
Hope this helped you.
Jul 06, 2011 | Weber Baby Q Grill
Regulator vibration
If you are using a disposable propane bottle, make sure it is not horizontal when it's hooked up. It should be at a 45 degree angle or higher. You may be getting liquid out of the bottle (instead of vapor) at the angle you have it hooked up. Hope this helps. Douglas
Jun 06, 2010 | Weber Baby Q Grill
The lid on my weber baby q 100 is cracked. can i
Yes call Weber Customer Service They are great !
Feb 01, 2010 | Weber Baby Q Grill
Low and intermittent flame of weber Q 220
You can try replacing the regulator to cure the gas flow problem, I believe the ignition is a piezo, if it does not click when you push it or turn it, it most likely needs to be replaced. If it still clicks, then there could be a bad wire or electrode.
Dec 22, 2009 | Weber Baby Q Grill
Cannot get good flame on the burner of my baby weber grill. I've tried cleaning it checked hose, tank, regulator, seems to have good flow, but low flame only, even when set in high????????
I had this problem with a brand new grill so it wasn't grease in the hose. Due to the new propane regulators you have to turn the propane tank on for at least a minute before turning the grill to light. Let the tank sit in the light position for five seconds and then you light the grill. This will keep air from getting into the intake hose and will keep your gas flame roaring high.
I was only able to get the grill up to 250 degrees before I found this fix posted on the Weber site. It is listed as the number one solution in the FAQ section.
May 18, 2009 | Weber Baby Q Grill
My weber Baby Q grill has a low flame.
Agree with rjmbridge. I called the Weber support people and was told that there is a built in safety feature on the regulator that will cause the flame to burn at a low setting if the gas within the extension tube to the large tank and regulator is not allowed enough time to equalize. They suggested turning on the gas from the tank very slowly, allow about 2 minutes with the temperature control knob turned off, then turn the temp knob on and light. This worked for me.
May 27, 2008 | Weber Baby Q Grill
Weber Baby Q Grill Logo
2,464 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
