Question about SkyGolf SkyCaddie Handheld GPS Unit
How do I activate the back light - it tends to go off very often. Is there a button.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
I researched your question and found a web site that has manuals available for Sky Caddie units. You can download the manual and keep it for future use and it probably has all the setting you need in it. The website is below either click on the link or paste it into your web browser address bar.
http://www.golfgpsrental.com/GPS-Manuals.html
I hope this helps you out, if it does please leave me a Yes on the web page you received my response on. Thank you.
Posted on Apr 07, 2011
I have a Kenwood KA-30 amplifier. As you may well know, the selector buttons on the front panel are not directly connected to the switches on the inside. They are connected via a piece of Z shaped black...
A trick a repairman should me was to use a soldering iron to melt the buttons back on to the connector. You have to be careful that the buttons still move up and down. But apart from that it will fix them, without the cost of a new set of buttons. Take care with melting plastic, it will give off toxic fumes. Wear eye protection as the fumes tend to go towards the eyes.
Aug 18, 2017 | Audio Players & Recorders
Unit will not power up
the lamp may be faulty needs replacement, another culprit is the color wheel when worn out they tend to get stuck and cant spin hence the clicks as tries to spin needs replacement most color wheels come inbuilt in the light engine u will need a tech to replace it and u are good to go remeber the lamp cant turn on if the color wheel is stuck cos its the one that syncrinizes with dmd board which in turn activates the ballast board to fire or light the lamp
Jul 15, 2013 | Sony BRAVIA KDL-V40XBR1 Television
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
E-037 accidentally I set higher quantity block too low and i can`t register anything over 20
For error code E037- turn key to program- push 0 then cash amount tend button then subtotal button. Let it work. When receipt is finished printing... Will be long...push 0/cash amount tend button then sub total. Turn key back to register mode and you will be back in business.
Oct 18, 2012 | Casio PCR-T220S Cash Register
2003 oldsmobile alero rear defroster doesn't work but the light on the defroster button goes on
Hi
There is module located behind the right hand quarter trim panel by the back window. Both your defrost and antenna run thru htis module. This module tends to heat up and fries. You wll need a new module and also a new wiring pigtail for it as this pigtail tends to get very brittle where it plugs into the module.
Not all that hard to repair. Just a pain!
Hope this helps
Teeje
Dec 17, 2010 | 2004 Oldsmobile Alero
Outside electrical outlet does not have power however when switch to outlet is in on position red light illuminates but no power,tried reset buttons and checked for flipped circuits
If the power light illuminates when the switch is on ,you must at least have a 'live' feed.
If nothing works when plugged in, it tends to suggest that there is a break in the 'neutral' somewere or that the neutral contact in the switch is not activating.
You need to get a multimetee and test for volts across the line and neutral with the switch on, if you get no reading you have a neutral fault.
Finding the fault will not be easy as it will be a faulty outlet, a bad connection or worse but unlikely a broken wire.
Dec 16, 2009 | Electronics - Others
Green light comes on but nothing else happens. No
try bringing it into a sony store and asking whats wrong with it
Oct 21, 2009 | Sony Playstation 3 (PS3) Console
Paper led light wont stop flashing
Pull the tray out and make sure the back guide is pushed against the paper. The back guide tends to move easily on these models
Jul 15, 2009 | Brother HL-2040 Laser Printer
Electric door locks
If you can see the lock (manual buttons) attempting to move, just spray the door latches with wd40 really well. I even open up the door panels abt once a year and just give a squirt into the rubber boots on the solenoids. These tend to rust and bind more because the rear doors are generally used less than are the fronts!
Jan 03, 2009 | 1997 Jeep Grand Cherokee
SkyGolf SkyCaddie Handheld GPS Unit Logo
55 people viewed this question
Top SkyGolf GPS Experts
Steve
Steve
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
