Question about Black & Decker Garden
Need owners manual for B&D paper shredder Model BD-10P. i have a jam
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
The manual is little help but you can find it here:
http://media.homedics.com/IBs/bds/BD-10P_IB.pdf
Troubleshooting
If you have a problem with your shredder, check the symptoms and remedies below.
If you cannot solve the problem this way, contact Black & Decker paper shredders
Customer Service.
Do not open shredder head to attempt repair: It could expose
you to electric shock and will void your warranty.
- Check to see if bin is full. If bin is full, empty bin and
replace. Follow instructions under maintenance.
- Oil cutting cylinders.
Shredder squeaks, grinds or runs
below capacity.
- No action required. This is a self-Shredder continues to run for cleaning function.
1 or 2 seconds after shredding
has been completed.
Symptom Remedy
- Make sure shredder is plugged in.
- Make sure power switch is in "Auto" position.
- Make sure bin is fully closed.
- Check to see if either bin is overfull which could result
in a jam. If so, empty.
- If you are unable to clear the jam, turn off and unplug
the shredder. Slowly and carefully pull the remaining
paper out. Forcefully removing the paper is likely to
cause irreparable damage to the shredder.
Shredder does not start or stops
while shredding.
Paper jams.
HOW TO GET SERVICE:
Visit our website at www.blackanddeckershredders.com or call the toll free customer
service line at 1-800-297-5028.
® SKU #BD-10P
Product Information
This product is designed to shred paper, staples, small paper clips, credit cards, CDs and DVDs.
It is not intended to shred large paper clips, continuous forms, adhesive labels, transparencies,
newspaper, cardboard or any other plastic other than credit cards. Using it for these purposes
is likely to cause irreparable damage. Please do not attempt to shred more than 10 sheets/1 CD
or DVD at a time. Shredder should not run more than 200 sheets/50 disks continuously. Items
should be centered and unit will begin and end shredding automatically. All disks should use
specific entry as noted on your shredder.
Maintenance
It is important to empty the waste bin regularly to ensure the smooth operation of the
cutting cylinders. The shredder will not operate when the bin is full. Regular oiling
is also necessary for proper performance. It is recommended to use the shredder oil
every few weeks.
Maximum running time: 3 minutes
Automatic cool-down period: 30 minutes
Voltage: 120
If you have any questions regarding the product, please feel free to
call toll-free 1-800-297-5028
Thanks for Choosing FixYa,
Kelly
Posted on Apr 07, 2011
Shredder jammed and will not back up - how do I unjam it?
Carlo, unplug shredder, patiently use pick, scissors etc to remove stuck paper. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Unjam Paper Shredder
How To Fix Paper Shredder Jam Video
How To Clear Jammed Paper Shredder ABC Office
Best Way to Clear Out Jammed Shredder Ask Ozone
Jun 30, 2016 | Shredder Office Equipment & Supplies
My Black & Decker Shredder #BD-61 all of a sudden does not work. I used it tonight, but the next time I tried it does not work. The lights come on in both positions, but
On some shredders when both the forward and reverse LEDs are on it can indicate either a jam or a full receiver bag/ container (the area that the shredded paper is fed into).
Try the following steps:
  1. ) unplug the power
  2. ) open up the shredder (see 1 on diagram)
  3. ) empty out all the shredded paper (see 2 on diagram)
  4. ) check that the shredding jaws (both the entrance and exit) are clear of any shredded material (see 3 on diagram)
  5. ) put everything back together
  6. ) plug power cord back in
  7. ) force the shredder into reverse (see 4 on diagram)
Hopefully you should hear your shredder motor running. If it is switch it to automatic and try shredding again
Jan 24, 2015 | Shredder Office Equipment & Supplies
Runs reverse auto
From your manual!
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the waste basket; insert waste basket and repeat jam clearing procedure.
Feb 01, 2014 | Fellowes DM12C Shredder
Omnitech shredder model ot--exc10a , shredder runs but when insert paper to shred it stops, pull out paper and it runs non stop!
Sounds like there's blockage between rollers and it also jams the sensor so auto function stops working. You will need to clear out as much jammed paper as you can using tweezers. Inspect the centre of the feed opening, there should be sensor which must be clear of blockages and moving freely. So clear any stuck paper with tweezers, in addition you can soak any jammed paper with WD-40 and unit should be good as new. Although if sensor arm is damaged then replacement of such sensor is unavoidable.
Nov 04, 2013 | Omnitech 18-Sheet Cross-Cut Shredder
Doesn't work in auto position but works in reverse
Most likely your optic sensor has something in front of it. Clean out the unit really well. It does take time, about 3 different screwdrivers, lon pliers and tweezers and a vacuum or compressed air. After that, learning more new words and swearing to god you will never let this happen again until the third time.
Jan 06, 2013 | Black & Decker BD10P Shredder
How to lubricate a Black & Decker Model BD-s600 paper shredder
    • 1 Turn the paper shredder off and unplug it.
    • 2 Clean out the paper shredder. Make sure the blades are free of paper bits and debris. Remove pieces of paper that are jammed around the blades.
    • 3 Spray the shredder oil through the blade opening or throat of the shredder. Spray it in a stream.
    • 4 Plug the shredder back in and switch the reverse button on. Then run it for 10 to 30 seconds in reverse to allow the blades to be saturated with shredder oil.
    • 5 Put the shredder in forward motion and let it run again to disperse the oil thoroughly to all areas of the cutting blades.
    • 6 Feed a couple pieces of paper through the blades to be shredded and absorb any extra shredding oil.
Read more: How to Lubricate Paper Shredders ' eHow.com http://www.ehow.com/how_5761042_lubricate-paper-shredders.html#ixzz1kDQGrxZ8
Jan 22, 2012 | Office Equipment & Supplies
The shredder was paper jammed
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds.
Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled.
Follow instructions to oil your shredder;
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three time.
Regards.
Apr 20, 2011 | Geha Primo 1400 Shredder
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
Cuts out after 1 second & red light comes on
The red light typically means either something isn't installed right in the shredder head, or there's a paper jam. Did you recently take the shredder apart? If not, there's probably some jammed paper in there somewhere.
Jul 06, 2010 | Fellowes PS60-2 Shredder
Our Aurora AS1712X paper shredder is jammed in a couple of places with paper so badly that we cannot free the jam and the tooth wheels cannot turn freely. Is there an easy way to clear the jam?
Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 20, 2010 | Aurora Electronics AS882C (Cross-Cut)...
Garden Logo
328 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
