Question about Dishwashers
We have had our dishwasher for 2 yrs now and it has worked great. However, my wife tried to start it and now it wont start or light up. I have checked and it has power going to the unit.
  • 4,323 Answers
Hi
If it has power going to unit and still won't start then it means that the power control board is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 07, 2011
Less that 2 yrs old..door wont latch. As a consequence machine won't start.
It is possible the door latch is faulty or the springs at base of dishwasher are soft and need adjusting. the springs keep the door in position. refer this site for parts.
Dec 31, 2012 | KitchenAid KUDS30IXBL Builtin Dishwasher
Water left in the bottom of a hobart (kit aid) dishwasher
Drain valve not opening, kinked or blocked drain hose. Remove the hose from the sink plumbing and look for debris. try running the drain hose into a bucket to eliminate a domestice plumbing issue, but hold onto it when it starts draining, or you will have a wet kitchen. Timer contacts may not be opening drain valve.
Sep 15, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Led wont light up. no power to dishwasher
Measure for 115 volts AC at the junction box behind the front lower panel where the incoming power connects to the washer wiring. If ok, you will need a wiring diagram of the washer to go further.
Aug 17, 2009 | Maytag MDB9600A Jetclean II Built-in...
Adg450 about 5 yrs old. Beep Beep.....Beep
Hi, I have a very simular problem, I have just read that running the water in the kitchen sink until its hot may work, if not could you please let me know if you get an answer to this problem,
Thanks
Peter
Aug 01, 2009 | Whirlpool ADG450 Slim-Line Built-in...
Runs forever! even on Normal wash...help !!
Check to make sure you heating element has not failed. Dishwashers of today heat the water periodically through out the cycle and if the element has failed. The heating delay light is the indicator that tells you that it is trying to heat the water.
Feb 26, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Error soak and scour light comes on wont wash
press and hols start button until it resets then try again.
Feb 20, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
Control panel lights OK; Won't start into cycles
Hey, just had the same problem with my 9150. Moisture got into the electronic key pad. $300 to replace it. I was 5 months out of warranty.
I called 800-688-9900 and Maytag agreed to cover the part and we have to cover the labor. Not completely satisfied but a little bit helps.
Jan 09, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Viking Dishwasher leaves a film on the dishes
Hi! I found a great product at www.dishwasherfilter.com that will take care of this problem for you and your wife. It mounts under the sink and works great!
Use promo code DF5150 when ordering for an additional discount!
Dec 16, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Maytag dishwasher mdbh950awb
Sounds like you have a control panel and/or control board issue. Normally when operator functions fail or "halfway" work the main control board, associated keypad, or wiring are the likely suspect. Now...another remote possibility could be the door latch not closing properly. However, this would affect ALL functions. I hope this helps you.
Jul 31, 2007 | Maytag 24 in. MDBH950AWS Built-in...
Dishwashers Logo
32 people viewed this question
Top Dishwashers Experts
