Question about Craftsman YT 3000 42" Kohler 22 hp Gas Powered Riding Lawn Tractor
The engine will start and run for 5 seconds and stop.I have fuel to the fuel filter.
  • 608 Answers
You have a fuel problem most likely a block in the carby. If it runs with the choke partially on this will verify the cause
Posted on Apr 11, 2011
  • Bob Van Deusen Jul 01, 2012
    I just changed my fuel pump for 35 bucks runs fine. Also check fuel cap is vented, I think that ruined my pump. Get pump online as they range in price.
Engine starts but stops in about 5 seconds. Restarts strong shuts off.engine has been getting weaker, less rpm and power last month.
Check your fuel filter, take your filter off and blow through it if its hard to blow through it replace it
Jan 29, 2016 | Garden
Fuel being being pumped out off r/h air filter for a few seconds, does it when trying to start as well!
it's normal for it to run for 5-10 seconds if you turn the key but do not start the car it will shut off.
Apr 15, 2013 | Yamaha Xv1100 Virago Xv 1100 1989-1998...
Engine stars and then stops, not fuel pump problem
What is the make/model/year/motor etc.?
Sep 15, 2012 | Cars & Trucks
2006 Cherokee KJ 2.8 CRD intermittent problem. Engine starts then stops. After priming at fuel filter will start & run ok
fuel pump relay . you should hear the fuel pump run for 5 seconds as soon as you turn the key on .after that the cranking sensor takes over when engine it turned over to start
May 26, 2010 | 2006 Jeep Liberty
Starting problems
Dirty fuel filter or faulty fuel pressure check valve which is located on your fuel pump sending unit. Try this test, turn the ignition on for 10 seconds (engine not running) then turn it off for 5 seconds and turn it on again then try to start the engine after 10 seconds. This will re-pressurize the fuel lines to start the engine, the fuel injectors need 62-65PSI to have them start the engine. Anything less then that and you'll have starting problem.
If it start's right up, then your ether have a fuel pressure check valve gone bad or a fuel leak at your fuel pressure regulator which is also common, but if your engine is still running 100% then i'll lean towards check valve or dirty fuel filter.
Start with the simple and replace the fuel filter, a dirty fuel filter will cause fuel restriction that may just be enough to the fuel pressure below 62PSI upon cold starts and a dirty fuel filter will cause the fuel pump to fail early in it's life.
Thank you for using Fixya and goos luck.
Mar 18, 2010 | 2002 Cadillac Escalade Ext
Aprilia mx50 will kick over then stop after 5 seconds kick over again and will stop after 2 seconds, then wont start, leave for a few mins and will kick over and will run for 5 seconds and so on, any idea...
If your bike starts even for 5 seconds you should investigate your fuel delivery system.Check fuel pump,filter,try spray carb cleaners like Gum Out.Most importantly make sure your choke is working.You got your ignition (spark) it is most likely fuel related.Good Luck.
Sep 19, 2009 | 2005 Aprilia MX 125
1986 sei 1200 goldwing It will start from ignition on,fuel pump runs for a few seconds,fuel light goes out,every thing normal-no LED diagnostic lights.When it starts it will run for about 3-5 seconds &...
check the fuel filter it sounds like it's pluged and causing too much back presure this is causing an over load in the fuel pump causing it to stop working or to presure lock
Aug 03, 2009 | 1986 Honda GL 1200 Aspencade Gold Wing
Weedwacker starts easy but will not run for more than 5 seconds .
May need to check for holes in fuels. Or fuel pump diapham is bad. If so replace carb., don,t waste money on carb. kit.
May 13, 2009 | Garden
Craftsman YT 3000 42" Kohler 22 hp Gas Powered Riding Lawn Tractor Logo
194 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
