Question about HP OfficeJet 7310 All-In-One InkJet Printer
Hp 7310 prints but receiving error message scanner failed. I turned it on and on and unplug still scanner failure but it prints from computer???
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 144 Answers
Hi there!
if its a scan issue, you may need to uninstall/reinstall hp printer software. or check on the scan bed if the light is coming out when you turn on the printer. check out this link too, this have all the info you need and tech support for that printer:
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=391182
Posted on Apr 07, 2011
Hp7310 not scanning when using HP Solution Center. Scanner works well with Microsoft Windows Fax and Scan. I have repeatedly installed HP drivers.
May i know the computer operating system and do you receive any error messages while attempting to scan via Solution center?
May 22, 2011 | HP OfficeJet 7310 All-In-One InkJet...
Received the following message when I tried printing - "System Error. The printer failed to print due to a system error. Try printing again. If unsuccessful turn Windows off and reprint." Can you sugg
Turn it off and unplug it for about 30 seconds. Plug it back in, turn it on and try printing a Self-Test (Setup, 2, 5). If this works, try printing your document again.
Apr 14, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Hp officejet 5610 Wont scan . Print. Copy
your printer is dead and is uneconomical to repair. sorry
Jan 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet 6310 scans once but then says scanner failure
hi,
that error message is nothing to do with the software part, it actaully hardware issue try the following,
1) unplug the machine and connect it to wall outlet directly,
2) unplug the power cord from the printer and press and hold ON for 1 min and release the ON button and plug it back..
3) Disconnect the power cord from the product.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons and if printer turns off, turn it back ON and wait until it cmopletes its instialization and if still persists, it a hardware failure...............
regards,  raj_p5983
Jan 19, 2009 | HP Officejet 6310 All-In-One InkJet...
Continued problem on officejet 7310 all in one printer
Unplug the printer from the wall , shut off computer . plug in printer after about i min. turn computer on. If this does not work you will have to reload your software
Jan 05, 2009 | HP Office Equipment & Supplies
Won't scan nor fax
HP multi units are notorious for scanner failures. It is just a weak component in their machines. I have seen this time and time again. The only solution is to change the scanner out or purchase a different machine. Just keep in mind the notoriety HP has which failed scanners. If you want to venture into the replacement of the scanner the following website might have the product you are looking for. Otherwise, search around the net for a scanner assembly unit for the OJ7310. But, be prepared scanner units are not cheap.
Check here first...PrinterFixer.net
Nov 13, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Scanner Failure
The only thing I can surgest is that you check installed programs I found that the 750 is very fussy about being the only kid on the block. Maybe worth trying a commercial program that says it will remove "junk" from your hard drive
Aug 24, 2008 | HP PSC 750 All-In-One InkJet Printer
Ink system has failed
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jul 18, 2008 | HP Photosmart C6100 All-In-One Printer
Hello, I have an HP OfficeJet 7310 all-in-one print/scanner/fax etc. I purchased about two years ago but don't use very often. Yesterday while I was trying to send a fax I received a loud winding-up...
I have same problem! The copy/scan function would feed the orginal from the ADF halfway and instead of making a normal loud feeding noise it made a horriable alarming sound and displayed an error message. To fix it: I waited a day or two and bang the top of the feeder cover with normal force while the original is feeding. It appeared the problem is resolved. I have no idea what the problem is, however I think if this work for few months at a time is fine by me.
Apr 12, 2008 | Office Equipment & Supplies
HP OfficeJet 7310 All-In-One InkJet Printer Logo
111 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
