Question about Craftsman Garden
Will not start-bought to sears repair certer and had fixed 10/10 at no cost since it was under warranty. Again will not start only 5 months after repair.Repair service only good for 90 days from what i am told.Very unhappy with Sears product.Have cleaned air filter,put in fresh mix. Please tell me what else i can do to get it running other then going to Home Depot and looking at there leaf blowers.I would rather stay with Sears since i have been a loyal customer for many years,from garage door opener to lcd t.v.etc.Please advise me on this problem
  • 1 more comment
  • artman39 Apr 07, 2011
    Lets try ONE more time since as i stated in my email i have done all that you suggested to repair leaf blower.If next fix does not work please cancel my account.Thought i explained every thing on what i did and you come back with the exact same remedy
    Have done all of THAT as i have stated and not the answer. Try again and if not the answer the second time CANCELL MY ACCOUNT Sorry
    just sent a email about why i am canceling
    President:
  • 1,654 Answers
Hi, If you can remove the spark plug, do so and clean it. Use some light emory cloth and polish the electrode on the plug. The plug is probably wet from trying to start it so dry it before you clean it. Put it back in and use a little starting fluid and see if it fires/ If it does then there is a fuel issue.
3 elements for a small engine to run...fuel, compression & spark. Do you have test equipment to test for spark and compression? If not
Spark: You can remove the plug from the engine and hook it back up to the coil wire put the end of the plug near some grounded metal and pull the starter rope and see if you get a spark. If you see a spark chances are your okay in the electrical dept. If your not getting a spark it's not a fuel problem
Compression: While the plug is out put your thumb over the spark plug hole and pull the starter rope does it kick your thumb back 2 cycle engines need close to 90 pounds of compression to start & run 120 is more in the normal range. So this thumb thing is pretty mickey mouse but if you ge a real good push back chances are your okay there too.
Fuel: Is your plug getting wet when you try to start it? Then it is getting too much fuel, if it is dry, Remove the spark plug and pour a little gas into the spark plug hole? replace the plug will it fire then? If so you have a fuel delivery problem.
This unit is made by Poulan/weedeater, it's been my experience that there are a lot of problems with the gas lines rotting apart. Verify that the fuel take-up/filter which should be dangling inside of the gas tank is still attached to the fuel hose Is the primer actually priming? those hoses can rot out too. As far as removing the carb to clean it... there are probably some screws underneatth the air cleaner cover If you remove those screws the carb will come loose you can then disassemble it...Chances are it's Walbro carb here is a site you can access... http://wem.walbro.com/walbro/family.asp You can see exploded views of their carbs. One side of the carb is held on with 4 small screws on the corners, the other side, the throttle side;is held on with one big screw in the center, there is a diaphram under each cover. The fuel pump diaphram (the one under the throttle end) covers a couple of resivoirs where junk/sludge builds up and can prevent gas from getting through to the engine. If one of the hoses did rot out... debris from the rotted hose can make its way into the carb and blocks things up
But before I would suggest that you rip all this apart..be sure to check all of the simple things first.
Posted on Apr 07, 2011
  • Dcramer531
    Dcramer531 Apr 07, 2011
    Whe I got the question I had no idea someone else had given you advice, have you tried the steps I outlined in the last respsonse, if so let me know. Thanks
  • Dcramer531
    Sorry you had a bad experiance here, I am still willing to help with this if you so desire and good luck to you in getting your blower working.
  • 10,319 Answers
Many things can go wrong. for instance the fuel can have sediments plugging up the carburetor .
do a check on the fuel line in the fuel tank. if stored away for many months the fuel line will disentergrate causing it not to start
How fix blown element on Electrolux induction range?
If it's a year old and under a 5 year warranty then it will be covered under the warranty and shouldn't cost you a dime. If it happens again then speak to someone about getting a different range since you may have received a lemon.
Nov 01, 2012 | Kitchen Ranges
Kenmore refrigerator compressor stopped
With all that said, here is the problem with the machine. It costs about sixty dollars.
Whirlpool refrigerators as well as the other brands that fall under the corporation most like at some point within the first five years will stop cooling and freezing, and the sound you here will be either a humming follow by a click or in some cases just the click alone. This is caused by the start device on the compressor. The relay part of it has basically burnt, fell apart inside, however you want to describe and is not passing the power to the compressor to come on. To access this pull the refridgerator out from the wall, and first and foremost unplug it. Once that is done remove the lower panel, sometimes cardboard sometimes metal which is held up by a few quarter inch screws. Place to the side and located the compressor. The box on the side is start device, it will have 2 or 3 wires going to it, most of the time red and white respectively. Also they maybe a black box thats connected to the start device and sits horizontallty. Thats the capacitor. Keep that if your going to do the repair yourself. I recommend doing it because its very easy and will save you alot of money. You can buy this part at www.repairclinic.com or at www.apdepot.com just be sure to have your make and model number handy.
May 28, 2012 | Kenmore Refrigerators
Cannot get power - changed fuse in plug and restarted. Kodak esp 3250 bought in Aug 10
> bought in Aug 10
Did your Kodak come with a 1-month, 3-month, 6-month, or 12-month warranty?
If the latter, then exercise the warranty, to get it repaired/replaced at minimal cost to you.
Jan 07, 2011 | Computers & Internet
Can not turn on
> only 5 months.
Then, it still is under warranty.
Either Wal-Mart or Toshiba will repair it or replace it, at their cost.
Jul 17, 2010 | Toshiba Computers & Internet
GE oven started flashing F2 only months after purchasing now beep and flashes F 2 and doesnt work, stove top still does not oven though, help!
As long as you did not purchase the range from Sears, (and it is under a year old) you should call an authorized GE servicer to repair the product under warranty. If you contact GE, (for warranty service) they will most likely send out "A & E Factory Service" which may be slow, and there is a lot of negative stuff about them on the net. Call a local authorized GE servicer. Most likely you have a problem with the oven sensor. If you bought from Sears, it did not come with a GE warranty.
Nov 05, 2009 | Dryers
Kenmore elite top loader
Call or email the consumer feedback or make a complaint to Sears. I had a similar prob. Sears ending up replacing rhe washer and paying for rental. Took up to 3-6 months, calling and writing complaint letters.
Jun 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool Duet Washer (GWH9100LW1) Bangs Loudly during spin
how old iss your washer? do you have an owners manual. because usually there is an extended factory warrenty on the tub and basket. the only thing you would have to pay for would be the labor. Call whirlpool if you do not have a owners manual to find out. the bearing is compressed in the tub. does it sound like an airplain taking off in your house that's usually it.
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Overlay Panel bubbles up!
I had the same oven panel overlay bubbling problem on my GE oven purchased in 2008. It started peeling and bubbling within the 1 yr warranty, and GE sent me a replacement panel. This new part began bubbling again within 4 months. Again, I called but now they say it's out of warranty and they will not replace it. Obviously there's a manufacturing defect in this part. The panel looks terrible. It appears that GE no longer cares about the quality of their products.
Jan 02, 2009 | Ovens
Haier 42EP242S Problem
too bought a Haier Plasma 42EP24S ,it stopped working after 7 months -I moved and did not touch it for the next five months
while searching for another tv to replace it- I came apon this site .
the tv was out of warrenty by both sears and haeir
well after reading these posts I called haier america and complained they in turn extended my warrenty and a sears rep came on 5 differant times and replaced all the boards inside tv with no luck - so after putting in over $1400.00 in parts an repair into a $1200.00 tv they wanted to start replacing boards again
I refused and kept complaining to several differant reps at sears
[they told me it was haeirs responsabilty not thiers] I don't know haw many times I explained to them that sears sold me the tv not haeir so stand behind what you sell -well after alot of calls and persistance sears replaced my tv free of charge with credt for a new tv for exactly what I paid
SO DONT BUY ANY PARTS OR PAY FOR ANY SERVICE IF YOU BOUGHT THIS TV AND ARE HAVING PLOBLEMS
be persistant untill its either fixed or replaced
Dec 10, 2007 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Nikon d80
Have the same cam and lens. Can u try another lens to se if its the cam or lens therese a prob with ?
Nov 07, 2007 | Nikon D80 Digital Camera with 18-200mm...
Garden Logo
174 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
