Question about Panasonic Televison & Video
Panasonic DMR ED 30V -- remote does not have any effect on unit. Cannot turn on. Once TV is manually turned on, pushing ANY button on remote gives message ICHK REMOIE on screen. Cannot get any other reaction.
  • ceramic_nut_ Aug 06, 2008
    model should read Panasonic DMR ES 30V
    Panasonic DMR ES 30V -- remote does not have any effect on unit. Cannot turn on. Once TV is manually turned on, pushing ANY button on remote gives message ICHK REMOIE on screen. Cannot get any other reaction. Changing batteries does not help.
    Genius:
  • 2,035 Answers
≥The remote control and main unit are using different codes. Change the code on the remote
control.
Press and hold [ENTER] and the indicated number
button at the same time for more than 2 seconds.
≥The batteries are depleted. Replace them with new ones.
≥Point the remote control at the remote control sensor on the main unit.
≥Remove obstacles between the remote control and main unit.
≥Don’t place the signal sensor in direct sunlight or in areas that may be subject to sunlight
exposure.
≥The child lock function is activated.
Good luck..
Posted on Aug 19, 2008
    Champion:
  • 221 Answers
The battery should be replaced, and if it still doesn't work, try getting a new remote.
Posted on Aug 06, 2008
  • Suvvy Roy Aug 07, 2008
    the IR receiver on the TV may be defective, but it is probably better to call up panasonic and order a new remote and see if that works first
    Sergeant:
    Champion:
  • 310 Answers
Replace the battery. And then check it
Unit turns on and off but nothing else works
Simultaneously press the [CHANNEL UP] and [CHANNEL DOWN] buttons on the front of the DVD Recorder for approximately 10 - 15 seconds (until the unit powers off).
Disconnect the wall outlet. Wait for 10 minutes. Then power up.
It this still does not help....and If you are capable of taking the risk check out DMR-EZ47 Firmware Installation Instructions
Panasonic DMR EZ47 Installation Instructions Manual
Familiarize yourself with all the steps and especially the page 7,8 before you attempt this,
Mar 25, 2016 | Panasonic DMR-EZ47V DVD Recorder/VCR
Why does playback start automatically?
This will be on the menu of the player somewhere, perhaps under playback. If you don't have manual you can download a free PDF from the Panasonic website.
Jul 22, 2015 | Panasonic Televison & Video
L.S. How to reset Panasonic DMR-EH55 DVD Recorder / HDD Recorder to factory settings?
You can either go into menu (pressing 'FUNCTIONS' button on remote) and look for 'RESTORE DEFAULT SETTINGS' or similar heading, or you can (while unit is on) on the front of the unit (not the remote) press CH UP and CH DOWN buttons together for 5 seconds - the unit will switch to standby. Give either one a try. (refer to page 60 onwards in your user manual - these pages detail 'settings').
If you cannot find your manual, it is available for download (free) - http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Operating-Instructions/model.DMR-EH55S.O#ts
I hope this helps in some small way. Thanks for asking FixYa!
Feb 12, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
My Panasonic DMR-EZ17 DVD Recorder keeps saying
You have to use the remote for this unit or a remote for a similar dvd recorder, when you have it hold the enter/ok button and the number 1 or which ever number your stuck on 2 or 3 for 5 second and then go into setup and change it to the one you want RC1 ,2 or 3 !
Jun 26, 2010 | Panasonic DMR-EZ17 DVD Recorder
I have Panasonic dmr-e95H and need to reset the
My DMR-E95H displays: "CHK REMOTE2" whenever I push a button on my "replacement" remote. Is there a way to reset the DMR-E95H without the original remote?
Apr 05, 2010 | Panasonic DMR-EH57 HDD Recorder Player
How do I reset the clock for the one hour time switch? This was the first DST switch since broadcasting went digital. The loss of the TV guide is no big deal but cannot I cannot change the clock. The...
The Panasonic DMR-EH50 can be reset like it was brand new. I assume the DMR-EH55 can be also. The up and down channel buttons are located on the front of the unit behind the small door in the center. With the unit on press and hold these two buttons for atleast 10 seconds. This will restore the unit like it was new and you will need to go thru set up procedure. The above action will put the unit in the off position. When you turn it on it will guide you thru the set up procedure. Once this is complete you can press the setup button and manually set the clock, however, the unit will need to be shut down for 24 hours to allow the tv stations line-up to be restored.
Nov 02, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
Panasonic DMR-EZ28 won't talk with remote
hi you need to reprogram the remote to fit with the unit there have 3 codes for remote 1 or 2 or 3 to reprogram your remote with the code indicated on your display press and hold the [3] and [ENTER/OK] buttons together for approx 5 to 10 seconds, then release
Jun 24, 2009 | Panasonic DMR-EZ28K DVD Recorder
Push on button dvr says set 2
Press ENTER and number 2 together on the remote control for at least two seconds to restore control.
Feb 13, 2009 | Panasonic DMR-ES35VS
Remote control for panasonic
I unplugged the unit. Replugging it fixed the problem, And it's an e46.
Jan 13, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
DMR-E80H Remote stopped working
There is a section in the manual about resetting the remote. It is a simple fix You can go to the manuals on Panasonic.com to find the methods of the madness
Aug 08, 2007 | Panasonic DMR-E80H DVD Recorder
Televison & Video Logo
87 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
