Question about Vacuums
I am looking for russell hobbs hepa cyclonic 1800 (14043) parts and not having much success could you point me in the right direction please?
  • 436 Answers
Wow, doesnt seem like its gonna be easy but here is a contact site you can try
http://www.russell-hobbs.com/parts.shtml
I hope they can help you out.
Good luck
Please rate FIXYA
Posted on Apr 07, 2011
Russell hobbs vacuum model no 18213 can't get bags?
You can get Menalux 1900 for Russell hobbs vacuum model no 18213 which fit perfectly. Also you ca buy SENCOR SVC 900 bags which fit perfectly and you get 5bags in one package + filter for very good price.
Also there are moe bags that fit to this vacumm model.
Jan 22, 2012 | Vacuums
Hi, I have washed my hepa filter by mistake for my DC14. Once it has dried out will I still be able to use it?
Unfortunately if you've washed the HEPA filter, it's probably best to replace it. To order a new one, please get in touch with us directly - you can call free on 08002980298 (UK), or 1866MYDYSON (US). We look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Aug 02, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
I'm trying to get replacement beaters for my RH Mixer Model #RHHM16. Thank you,
click on this link and enter info,, they have the parts you ned http://www.russell-hobbs.com/parts.shtml Please rate my reply Thanks Good Luck
May 04, 2011 | Vacuums
I need a manual for russell hobbs 10661 as been given one without instructions....
A Russell Hobbs 10661 is an espresso maker - not aware of a Vacuum cleaner with that model number . Are you SURE you have the model number correct?
Jan 31, 2011 | Vacuums
Cyclone action is not working
When the Cyclone Assembly on the Dyson is not spinning around, it usually means that you are loosing suction somewhere. This can either be caused by a clog, suction leak, or dirty filters. I will give you detailed step by step instructions along with pictures on how you can diagnose this.
Possible Problem # 1. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the vacuuming position with the handle down. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the handle was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
Possible Problem # 4. The Dyson DC07 has two filters on the vacuum. The first filer is the pre-motor filter. This filter is located on the right side (if you're standing in front of the vacuum) underneath of the of the cyclone assembly. There is a filter catch that holds the filter and the filter bracket in place. Simply press the filter latch, and remove the plastic circular part that comes off. In side of this plastic part you'll find the pre-motor filter. This filter is washable, but if it hasn't been washed recently, this could be the source of your suction loss. Here's what a clean pre-motor filter looks like, compared to a dirty filter:
The second filter in your Dyson is the HEPA filter. The HEPA filter is also known as the post-motor filter, or it's located after the motor. This filter typically doesn't have any effect on the suction, but you should periodically open it up and take a look at it. Despite the bogus claim of a Lifetime HEPA Filter. As you can see in the picture below, this filter gets filthy. When this filter is this dirty, it prevents the air flowing through the filter, which causes the air to look for other ways to escape, causing the dirty air to escape unfiltered. A dirty filter can also take away from the life of the motor. Here's how you can access the HEPA filter.
First remove the dust bin completely from the vacuum cleaner. Take a flat head screw driver, and right where the dust bin was sitting you'll see a groove. Put the flat head screw driver, and pry this groove off. Here's a picture of that: de80f32.jpg
Also on both the left and the right side, there are two more grooves that need to loosened before the filter can be removed:
After loosening three grooves, one on the front, left and right sides, the HEPA Filter cover can be removed. Inspect the filter to see if it's dirty. Here's a look at what a dirty filter looks like compared to a brand new filter:
I'm pretty sure that one of these solutions will help you with your loss of suction, and the cyclone assembly not spinning.
If one these solutions still didn't fix your problem, I'd be happy to try and help you further. Just use the Clarification Request, or comment section here on the Fixya repair page, and let me know specifically what happened after trying these solutions. We can then narrow down the possible problems, and help you get your vacuum fixed.
I really hope that this repair was helpful to you. If this repair did help you, please be sure to rate this repair as helpful by clicking the thumbs up icons in the top right hand corner of the repair. Thanks so much!
Chris J.
GoVacuum
Apr 03, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson collecting debris/hair, ect on top of hepa filter?
Called Dyson today about the cyclone canister clogging in my DC17 Animal. Turns out it's a problem with the black rubber gasket in the bottom of the canister. This also causes the HEPA filter to get lots of dirt and debris on top of it. They are sending me a new Cyclone canister with the corrected gasket. This will prevent anything but small particles of dust from entering the top of the cyclone and the HEPA filter should no longer collect all that stuff. Hope so!
Feb 09, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuums Logo
150 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
