Question about Garden
I have a Euro Pro pressure washer model #1500, I need the connector from the machine to the water hose, can you give me the part # & where I can purchase it, thank you for your assistance.
SOURCE: I need the manual to Euro=Pro, Model 7500, Craft N' Sew Please..
http://homeappliance.manualsonline.com/ex/thread/view/idThread/159782
This one is in 3 languages, but it is worth the read. The diagram to choose the patterns from the frony of the machine are on page 28. Hope this helps.
Posted on Sep 23, 2008
safenude
  • 124 Answers
SOURCE: Need instruction book for Euro-Pro X, Model F1066
Welcome to Fixya! I am the expert that picked your problem to solve. Here is the link to view and download your manual:
http://www.euro-pro.com/europro/manuals/F1066.pdf
Thanks for using FixYa.com
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further. I am at your service.
Posted on Jan 31, 2009
SOURCE: need instruction book for coleman powermate clean 1500
The hose connection I believe is for hooking a hose up and running it into a bottle of cleaner. The cleaner is mixed with the water when it is sprayed, The knob on the bottom adjusts the strenght of the solution. Most washers have the same setup.
Posted on May 26, 2009
  • 3 Answers
SOURCE: help me find a manual for a euro pro 7133 sewing machine
I hope this helps. It took some searching but this is what i found. Good luck!
http://www.sharkclean.com/manual/7133_REV_1204_ENG-SP-FR.pdf
Posted on Jan 22, 2010
SOURCE: Need Behringer V-Amp Pro repaired or find diagram & parts
my euro2442 is not prperli runing so plese send me your service center in india
Posted on Jan 04, 2011
Euro-Pro X
Check the hose for something clogging it. It will be past the flattened area (by that I mean further from the steam cleaner). It sounds like something got stuck in the hose, and as the steam cleaner kept sucking on the hose, it caused the hose to flatten.
Sep 08, 2007 | Euro-Pro Steam Generator EP8001 Iron
Lost manual for euro pro 1100 model of dressmaker 2
here's a link for a manual--the link will show a euro pro name click on
the name & then select your model number 1100 & it will show the
machine & manual that you can buy
http://www.mastersewusa.com/menu-europro-instruction.htm
Sep 05, 2012 | Euro-Pro Sewing Machines
Need a user manual for euro pro sewing machine EP385
Euro-pro.com
Retrevo.com
home appliance.manualsonline.com
Or go to the website of sewvacdoctor.com & email them about a manual
Mar 06, 2012 | Euro-Pro Sewing Machines
I bought a Euro Pro TO242RW convection oven and Rotisserie. No manual or rotisserie spit. were can i get these things. Thank you.
Have you tried to find the Euro Pro website to look there? Have you searched on the internet using Euro Pro, model,and the word manual because there are sites that offer manuals on products. And the same thing for the rotisserie part. Maybe doing that will give you leads to look further if need be.
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 05, 2011 | Euro-Pro TO285 1500 Watts Toaster Oven...
Washer overflowed after moving Load Capacity Switch from Super to reset and then to Large load?
On this model of washer you have 4 separate components that could cause overflowing. The water valve, pressure switch, pressure switch hose & the air dome. If you have to turn the water off to prevent overflowing, I would recommend replacing the water valve. If you can turn the timer off & the water stops overflowing, I would recommend checking the pressure switch, hose & air dome.
Jan 16, 2011 | GE Washing Machines
I have a frigidaire gallery series front loader washer model gltf2940e it keeps giving error e10 what do i do
E10 means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Sep 15, 2010 | Frigidaire ATF6000ES Front Load Washer
When the washer turns on, the agitator begins to operate. However, the water does not enter. The hose and screens are clear and i even replaced the inlet valve, but still no water.
There is a pressure switch (load size switch) that senses the pressure of the water in the tub. This switch has a small rubber hose attached to it that runs down into a connector on the outer tub of your washer.
More than likely this hose and or the connector that it goes into at the tub may be stopped up or clogged with trash. You will need to locate this hose and connector and clean it out. (depending on what brand machine you have there are different ways to access this)
You may also be able to take the hose off at the switch (behind the backspash of your machine) and blow through it.
It is also possible that you have a bad pressure switch but this is unlikely. It is more common to have a trash/gunk build up in the hose and or connector.
Jun 29, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
LG Tromm Washing Machine giving error code of IE
HI. This is a water inlet issue here.
Correct water level (246) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes
First you will need to check the water fill faucets to make sure that they are turned all the way on.If the faucets are on, then move on to the hoses. Check the hoses for kinks. Make sure the hoses are straight, and not curved. If all checks out Ok here, i would advise to move on to the filter screens.
The hot and cold water from your home is connect to the water inlet valve on the back of the washer. In each end of the water supply hoses there may be a filter screen to catch debris and prevent it from damaging the washer. The water inlet valve also has filter screens. If the filter screens become clogged, the result is low water pressure, no water or the wrong water temperature,as well. The water inlet valve can be identified by the water hoses connecting to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting adequate water pressure and to clear any debris from the line.
Inspect the filter screens on both of the hoses and the inlet valve for debris build up. If you find any debris, clean it out. The screens in the inlet valve are not removable so use caution to avoid damaging them.
If you are getting good water pressure and you find no build up of debris, then the inlet valve itself may be faulty.
TESTING PROCEDURE FOR THE WATER VALVE ASSEMBLY
There are two wires connected to each solenoid on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals ( Be sure to not pull the wires). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. Test the second one in the same way as the first
NOTE:-(The water inlet valve can be identified by the water hoses connected to it at the back of the washer.)
(If the entire inlet system check out ok, and the hoses and valve are ok, replace the pressure switch, and pressure switch hose)
Nov 02, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Need instruction book for coleman powermate clean 1500
Apr 09, 2009 | Garden
Garden Logo
417 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
