Question about Keurig Platinum B70 Coffee Maker
Water is not coming out through the k-cup but it is coming out of the spout in the resovoir. what do we do?
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 08, 2011
Water leaking not just comming out of spout
Sounds like your water outlet is clogged. Open the head and push up the cup holder to remove. When out, clean out the tube at the bottom of the holder with a paper clip or something similar (I use a cake tester - long skinny metal rod. This will clean out any clogs in the output path. Also remove the bottom part of the cup holder and clean it too. Put back together and place back in brew head the way it came out. (Caution - some models you have to twist the cup holder to remove, and some it just comes straight out). There are many you-tube videos that will show you this also.
Mar 27, 2014 | Keurig Vue Brewing System
Verismo 580 leaks clear water in spout behind pod spout
Be sure you put the silver lever (embossed with the word Verismo) down before pressing the coffee button. (The small cup illustrated on the top right.
Mar 02, 2014 | Starbucks Single Serve Brewer, Verismo 580
Keurig troubleshooting
This problem is addressed on the Keurig website:
http://www.keurigtroubleshooting.com/Keurig-Coffee-Brewer-Problems.html
Scroll down to Partial Cup Brewing
Jan 05, 2014 | Coffee Makers & Espresso Machines
Jura-Capresso Impressa Z5 - left coffee spout is clogged the left spout only lets drips of coffee coming through yes we: 1. use only dry beans 2. have the water harshness setting below 10 (we only use...
As the coffee is dispensed, it is normal to have some residue left in the tubing and spouts. It is the reason that the machine will require cleaning on a regular basis using the Jura tablets that dissolves the coffee film. In the case the spouts get clogged, the best approach would be to dismantle the spout assembly. Since it may not always be possible, I found that filling a cup with a coffee cleaning solution such as Puly Cleaner (pulycleaner.co.uk) and having the spout dip in the solution overnight can help. Probably that dissolving a Jura cleaning tablet in a cup of warm water would provide similar cleaning power.
Dismantling the spout is rather straightforward. You start with removing the front logo by rotating it counter-clockwise. Behind it you will find a T15 Torx screw. Removing it will allow removal of spout cover by pulling the top part lightly towards you and then sliding it down below the spouts. Grab the spouts by the sides and wiggle downwards until it comes loose. You can now clean the spouts but will most likely need to soak it. See the video showing removal of the spouts @ youtu.be/9QlRGY0eX3s
Jun 08, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
My keurig only brews 1/2 a cup of coffee. I've cleaned everything and there is no clogs, but still only 1/2 a cup. I have only had the coffee maker one month.
The next time you go to brew a cup, open the lid to the water well and locate the little clear rubber spout that sticks out of the side of the machine toward the top. When you brew the cup watch the spout to see if water is coming out of it into the water well. If it is you can just put your finger over the hole and the machine should brew the whole cup.
I usually only have to do this once every time the problem starts happening, but it is clearly not a permanent solution. I assume the problem is with a valve inside the machine or something, and to fix it permanently you should probably get the unit serviced or exchanged under manufacturers warranty.
Feb 03, 2011 | Keurig B60 Coffee Maker
I have a keurig b30 and has been working great but now it will not recognize any of my cups so the flashing blue light will not come on to start brewing? none of them are clear and have all worked in the...
I haven't solved the problem, but I continue to disassemble my K30. Most likely points of failure for the blue start light not coming on appear to be a sensor to detect the cup is in place (two small holes on the left/right front edge of the cup holder) or a sensor in the resovoir lid where the blue pin presses on a pressure switch. I did find that the red wire to this switch gets caught in the lid hinge and may be damaged. I will post more if I finally discover the root cause but may just go to Bed Bath & Beyond and buy the resovoir model with a 2 year warranty. Lesson learned. Cheap switches and mechanical devices.
Nov 06, 2010 | Keurig B30 Mini Coffee Maker
Both spouts seem clogged
I have a Jura Impressa F7 that had the exact same issue. To solve it was pretty simple. Try and make a cup of coffee, and while the machine is trying to pump the coffee thru the spouts, grab the chrome handle on the spout and vigerously move it up and down rapidly. You should notice small grounds of coffee dislodge and follow the stream of coffee into your cup. If you do this a couple of times, you will be able to clear the trapped grounds within the spout. Hope it works for you as well as it worked for me.
Jun 23, 2009 | Jura Capresso Impressa F9 Espresso Machine
GE Model 169164 stops brewing
A couple of people on here mentioned he filtration system, or charcoal filter that is in the
water resovoir as being problematic. We removed it. This morning the pot brewed entirely.
Not sure how that all is inter-connected, but it worked.
Feb 04, 2009 | GE 106591 Coffee Maker
Won't Brew. No water from resovoir to fileter.
To clean your coffeemaker:
1) Pour four cups of undiluted white household
vinegar into the water reservoir.
2) Place a paper filter into the removable filter
basket and close the brew basket lid.
3) Place the empty decanter on the
warming plate.
Make sure to accurately place the
decanter on the warming plate
to avoid the possibility of overflow.
4) Start the brew cycle:
a. Turn the switch to On. Then, press the
brew button to begin the brew cycle.
b. When the water has flowed into the
decanter, turn the coffeemaker Off
and let the water stand for 30 minutes.
c. Repeat Steps 1 – 4b.
Have a nice day!
tc
Apr 16, 2008 | Mr. Coffee ARX23 / ARX20 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
77 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
