Question about Kitchen Ranges
Need instructions diagram to install part number 408714 (clutch cable). Ordered replacement part and now husband can't figure out how he took old one off.
  • 436 Answers
This should be the correct instructions:
http://media.fotki.com/1_p,wtdbsgfbbbdwkwrxgtqsskgwtqkq,vi/dwgbwdfkbxtwqdkttgq/1/1303472/5961857/image54790img-or.gif
I hope it helps
Thanks
Please rate FIXYA
Posted on Apr 07, 2011
Replacement clutch is too small? Thought there was only one engine in 2000 hyundai accent, the 1.5L. Title says its been rebuilt twice. How do I find out what clutch i need to ask for?
the different clutch sizes are for the different capacity engines
The 7" would be most likely be for the 1.4 or 1.6 version engines where the 8" would be for the for the 2.0 or 2.4l engines
If the flywheel is flat across the face ( not recessed) the the clutch plate you want will fit as long as the pressure plate is the same diameter and the bolts fit the cover to the flywheel
it is possible to get a standard clutch kit or a heavy duty clutch kit which has a higher pressure plate reading to cope with heavier loads ( towing etc)
if an 8" came out , you need to replace it with an 8"
The bigger the clutch , the longer the period before replacing it
If you can get to it you can measure the shiny wear patterns on the flywheel and if the incorrect plate was fitted at some time you will see the old wear pattern outside the latest shiny surface
what you have to be aware of is the spline number and size of the new clutch plate so try it on the input shaft before fitting to the flywheel
Jan 24, 2016 | 2000 Hyundai Accent
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at khader_abu@yahoo.com........
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
Need instructions on how to install clutch cables on a 02 fxst
First, you have to drain the oil from the transmission by removing the plug located just below the chrome plated clutch release mechanism on the right side of the transmission. Then, take the bolts out of the clutch release mechanism and pull it away from the transmission. Disconnect the link from the clutch release ramp and the clutch lever at the handlebars. Unscrew the clutch cable from the clutch release mechanism. Reinstall the clutch cable in reverse of the way you took the old one out. Refill the transmission with 20-24 ounces of transmission lube.
Good Luck
Steve
May 08, 2011 | Harley Davidson FXST Softail Standard...
I have a model 21a- 410-062 MTD tiller that i had to replace the shifting forks on. The trouble is I cannot figure out hoe to get the shifting clutch collar back on the shaft or i don't know how it goes...
there's a pretty good schematic here:
http://www.m-and-d.com/pdfs/MTD/410-420.pdf
and a reference diagram here:
http://int.custhelp.com/ci/fattach/get/15094/1173195151/session/L2F2LzEvc2lkLzJPNmdRanNr
I've had mine apart twice, first time to replace the shifter fork, 2nd time to find why it keeps popping out of gear.
Apr 20, 2011 | Garden
Replace rear derailer rd-tz30
Techdocs.shimano.com is a very good source of installation diagrams and information. Although THIS LINK is not to your precise model (TZ50, not TZ30), this will get you the info you need. Visit the Shimano technical documents address at the beginning of this message to browse all the tech sheets.
Hope this helps,
matt
Sep 24, 2009 | Shimano Cycling
Geo tracker wont shift after clutch and clutch cable replaced
this is common.
it is caused because NO ON ever changes the cable at 100k miles.
it then wears a groove inside the cable and jams where you cant see.
(got my car dirt cheap cuz no one could figure this out)
the next thing to happen (toss coin) is the fire wall cracks or the clutch pedal spline strips.
full story here,
http://www.kick-fix.com/tranny/clutch/clutch-on-kick.html
now you know the why , so now correct all the damaged caused by a $45 cable.
all parts are at suzuki , every single one.
Jul 22, 2009 | 1991 Geo Tracker
Clutch cable diagram
autzone has some information on this. they dont have a diagram persay but instructions.. hope this helps
Mar 22, 2009 | 1985 Dodge Ram 50
Spacemaker xl microwave oven jvm1630
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
You'll need to remove the oven from the wall.
This is safer with two people and the installation instructions will be of great help.
You can download GE owner's manuals and installation instructions here.
Dec 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Clutch cable on 2002 VW Cabrio
The mechanic you went to was wrong, these cable have a lot of tension, sounds to me like you may need a new clutch installed as well as a new cable( they are self adjusting and chances are you wont be able to deadjust your old cable.)
Oct 21, 2008 | 2002 Volkswagen Cabrio
Check out this door frame diagram, specifically number 1805. It clips on to the door frame. Remove it using a dull table knife or something similar (be careful not to scratch or break anything). You will then have access to the bottom screw.
Mar 18, 2008 | GE Advantium SCA1000H Convection /...
Kitchen Ranges Logo
146 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
