Question about AEG Washing Machines
Bushes and bearings in the motor need replacing
Noisy washer removed back Took the belt off the drum and spun no noise Put belt back on motor and it made a noise so it identifies the bearings in the motor is the problem. Can these be repaired
can be the bushes if they at the end these can be changed not like the bearing in your other question. check the length of the bushes there should be around 8mm on them if they below 6mm they need replacing.
Jul 15, 2017 | Washing Machines
How to replace motor on 8925 riccar vac?
There is not a motor bushing on a Riccar 8925, it has sealed bearings. There is nothing that needs to be timed or adjusted in the motor.
Jul 17, 2014 | Riccar 8925
How do i fix my Ecofan ?
Does the motor have bearings or bushings? If bearings, they likely need replaced. If bushings, clean with alcohol then lubricate with 3-in-1 oil.
Jan 24, 2014 | Dryers
The coupling to the motor is loosely rotating on the motor shaft. Has the threads on the coupling worn out. it is a breville optiva cbl6 blender
The coupling bush wear out in due time and must be replaced. if there is a wearing detected it must be changed or it will result in failure of the bush/ bearings of the motor and jar. You will need to remove using anti clockwise direction, Get the correct spare part from the dealer to replace. Good day
Aug 16, 2010 | Blenders
My husband and i changed blower motor, relay. On our 81 corvette but still will not work help.
Thats because the older style GM blowers depended a lot on bushings for rotation, and as we all know bushings just cant outlast bearings. It looks like you'll need to replace that fan motor.
Mar 14, 2010 | 1981 Chevrolet Corvette
MOtor runs very loud and screetches. Brush is
If you know how to open it's inducton motor and know to replace bushing and bearings, then turn it up-side down and dis-assemble your equipment, replace the bushing and bearings,
if not just bring it to a repair shop then they will be the one who will replace it
Nov 01, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Am installing a starter motor. I have to remove
I wouldn't replace this bushing unless it's obviously worn out. I know of this recommended method when a puller is not available, pack the bearing bore with grease and use a socket and extension or similar rod that fits snug as possible in the bearing bore and hit this tool with a hammer as to use a hydraulic effect. the pressure of the grease will push the bearing out. This method is used on, rear wheel driven, flywheel bushing removal. Good luck!
Sep 04, 2017 | 1985 Volkswagen Quantum
Dryer is sqeeling....Are there bearings that need replacement???
Yes, there are bearings and bushings. They most likely just need oiling with machine oil. I would use the machine oil for small motors (hardware store). Oil the motor bearings as well.
Pop the top of the dryer with a large slotted screwdriver prying up on each of the two front corners. Remove the screws holding the front panel of the dryer. You'll see al the stuff whcih needs oil.
Apr 29, 2009 | Dryers
Kenmore 110.86874100 Motor (?) Squealing
I don't think they can be, but, also take a look at the fan bearing assembly too. You should be able to isolate if the noise is from the motor bearings or blower bearings.
Jan 26, 2009 | Dryers
While ac is running, the fan blower comes on for a couple of minutes then stops and there is a humming sound at the blower motor. Is it the blower motor?
yes the blower motor is trying to go out. you can probably take it out of the casing and spin it with your hand to get it going again but it will only last a few min. i would suggest to by a new a/c
Aug 13, 2008 | Goodman Heating & Cooling
Washing Machines Logo
18 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
