Can u help me as im havin trouble with loadin up my pc all i get is the safe mode options screen all time
  • 2 more comments
  • garside1984 Aug 06, 2008
    wen i power up my pc it starts loadin up the windows xp screen with the bar at the bottom then i get a blank screen then it gose back to the safe mode and last know good configuration screen and it dose that all the time and i can not load up pc in safe mode to system restor my comp. i dnt no what to try
    i can not find the hard drive diagnostic in the F8 or F12 is it called something els?
  • IQUIT May 11, 2010
    Sure we can help, if you provide us with detailed information.
    1. When system boots to "Safe mode options all the time" exactly what does this mean? Are you getting a Windows Startup menu? Does the system boot to the desktop and say "SAFE MODE" in each corner of the screen?
    2. What version of Windows? (XP Home? Vista Ultimate?)
    3. What brand PC? What Model? What Video Card?
    4. By "Loading up my PC" do you mean you are installing Windows and need assistance with installing drivers?
    DETAILS, lots of Details will help us fix your issue, a 20 word sentence is not enough information.
  • 3,940 Answers
OK, we have Windows XP and we cannot boot to the Desktop in Normal, Safe or last known good configuration.
You definitely have a windows OS issue, and you may have a hard drive problem.
If you post the Brand and Model of the system, that would help us to be able to give better info on running a diagnostic on the Hard Drive.
Many brands have an option for diagnostics on the F8 or F12 menus. See if you can run a hard drive diagnostic. It the hard drive fails diags, then you'll need to replace the drive. If it passes diagnostics, then try booting to the XP CD, entering recovery console and run CHKDSK /R
Posted on Aug 06, 2008
  • IQUIT Aug 07, 2008
    Since you've never identified the system brand and model, I'm limited in the advise I can give you on diagnostics.
    If you don't have diags listed on those menus, boot to recovery console using the Windows XP cd AND RUN THE COMMAND chkdsk /r
    If it's a damaged file system case then:-
    1.Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
    2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
    3.If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
    4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
    5.At the command prompt, type chkdsk /r , and then press ENTER.
    6.At the command prompt, type exit , and then press ENTER to restart your computer.
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Gateway desktop wont boot up into OS XP just blinks with cursor on black screen
try this strt the pc when you see setup on screen press F8 key a few times then you will see options like safe mode and safe mode with networking and you will see an option to boot from last known good configuration use keyboard arrows to select this option your pc will reboot if this doesnt sort it the repeat these steps and on the screen select safe mode and hit enter key or return key let the files load on the screen when th pc goes into safe mode the screen will look different clik on strt then select alll programmes then select accessories then select system tools then select system restore ....select a date when your pc was last working correctly and clik next let the computer do its work when it restarts it should be working correctly (NOTE) any progrmms you downloaded from the date you selected will be eresed but not your documents or downloads like movies ...hope this helps
Dec 19, 2010 | Gateway GT4016 Desktop PC
I have an asprie one and it went to a blue screen and will don't come on? help!!!
Restart the computer press F8 key till the option for safe mode screen comes up.
Select the option safemode with networking. Hit Enter.
Connect to the internet and run a free registry cleaner. Im sure this should resolve the issue. Thanks.
Jun 20, 2010 | Acer Aspire One PC Notebook
Computer keeps returning to "safe mode" options screen
If you choose Start Normal and it boots into safe mode again then you should get professional help if you value any of the files on your computer and don't want to loose any data.
Jun 01, 2009 | Sony VAIO VGC-V617G PC Desktop
Computer wont log in
Try switching on in safe mode. When you power on continuously press the F8 key and it should enter safe mode. you will then see anumber of options. try logging on under "last known safe configuration" (or similar). After that im outa ideas
Feb 06, 2009 | Acer TravelMate 2300 Notebook
Im having trouble starting my acer laptop, iv tried pressin f2 and f8, and tried pressing safe mode options and others available, but it just goes onto the windows loading page and then to a black screen...
Try use last known settings that worked. If that doesn't work,reload your operating system, sounds like something might be corrupt.
Please rate my awnser. Thank you.
Jan 22, 2009 | Computers & Internet
PC notebook will only start in safe mode.
Try doing a System Restore, once you have booted up in Safe Mode, to a time before you had the problem.
Hope this helps
Chris (ziraffa)
Jan 02, 2009 | Computers & Internet
Help!!!!!
when you turn on the computer, press F8 before the xp logo shows up. then choose "Safe Mode".
if widows loads ok, a window will come up. click no to restore to a previous date.
If windows does NOT load, you have to re-install windows. Put the CD that came with your computer and run the setup.
NOTE: if you want to keep your files, do not choose any options that format your drive.
Aug 06, 2008 | Computers & Internet
Tom
You should go into the safe mode and try to uninstall or undo the previous work. Else use the system restore. But if it continues again with a blue screen error, then u should format ur pc, further if u experience blue screen error then u should note that one of ur hardware is damaged.
Thankyou...!!!
Feb 08, 2008 | Acer TravelMate 2300 Notebook
Down loadin music
I would personally recom' you to not use the PSP media manager, you should use the explorer of windows os directly to transfer your music to your psp.
Well, for audio cd ripping, you can use many free softwares, for instance, foobar with proper pluggins install can do the right job for you.
Dec 20, 2007 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
