Question about Toshiba Computers & Internet
How do i get the floating scroll bar off my computer. the worst thing i've ever seen on a computer. it's wild, sometimes uncontrollable.etc. hey toshiba if your buying **** programs for your computers i'll gtot a couple to sell you. the company who sold you the floating scroll bar really took you boys. it's too bad that thew customers have to put up with such ****!!!
  • Toshiba Master
  • 27,725 Answers
Click start control panel add or remove programs or uninstall a program this may vary depening on your operating system scroll to see if floating toolbar is listed select uninstall or it might have its own uninstaller click start all programs look for floating toolbar select it and see if it has the uninstall capability
hope this helps
Posted on Apr 07, 2011
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
Expant Shield does not connect anymore. One day it worked fine and since about a week it does not connect anymore. No changes to location, computer, internet connection, etc. Possible that my ISP (I live...
That is a typical problem/issue. What happens is the ip block gets blacklisted and no longer works. All you need to do is wait a few days and it should work again. I think the longest I've seen it down lately is about 4 days or so. Hotspot is pretty proactive on fixing the connections so it usually is much faster. There are a few things you can try such as disconnecting, wait a minute and then reconnect to get a different ip. If the ip is out of the blacklisted range you should be able to watch the BBC/IT4 etc again right away. If not then about all you can do is wait and keep trying to connect. The disconnects I've seen recently are very short compared to when they first started. Those lasted weeks sometimes.
Oct 15, 2011 | AnchorFree Expat Shield
This 2003 harley sportster has a tilt sensor where is it on the bike and can i disable it?
They used to put those things on the backside of the oil tank and if it's a "normally closed" switch, you should be able to jumper it out. But, I have never disabled one of the switches. I've never had anyone that had a problem with one. As far as I know, it's a safety switch so that the engine does not "run away" if the bike is dropped. I've seen plenty of Sportsters do this back in the days when we rode them in the woods. Drop the bike and the engine would scream wide open for a short period of time before it quit. The old Sportsters (69-70) with the Tillotson carb was the worst about it. That carb had no float bowl and would run in any position. They use the same design on chainsaws.
Steve
Aug 13, 2011 | 2003 Harley Davidson XLH Sportster 883...
The most common cause of the problem is a stuck/shorted button either on the television or on the remote. The worst case scenario is a faulty key control board. Remove the remote control battery or put it away from the television. Press the menu button on the television and check if the menu scrolls by itself. If yes, the DOWN button is stuck or shorted. You can actually hear or feel it click when pressed if it is not stuck.
Open the back of the television to gain access to the key control board. You can either repair/replace the faulty button or replace the key control board. Remove the screw holding it to the television casing. Disconnect the old board and install the new one.
Replace the remote control if the buttons on the television control are working properly.
Jan 16, 2010 | Haier HP42BB 42 in. Plasma TV
Curser problems and more!
check your mouse settings in Control panel, adjust accordingly...
Oct 06, 2009 | Dell Inspiron 2650 Notebook
My chain keeps binding up, i get it back on, start running my wild thing and with in 10 seconds it binds up
Try putting a new bar on it. Sometimes during use the grove in the bar gets a kink in it. This will cause the chain not to move like it should. Also, the sprocket at the end of the bar can go bad also causing a malfunction.
Best bet!!!!!! Buy a new bar...
Aug 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Hey i need help!
The best course of action is to perform a driver update of the device and see if this clears things up. Since your touchpad freezes the computer, I would find a mouse to plug into the USB port and use the HP Update utility.
Since that program is known to be iffy at best, Check Windows Update and see if a touchpad driver exists as one of its updates.
And if you still encounter problems, you may want to call HP for some ideas.
When worst things comes to worst, you can attempt a factory system recovery which is used as a last resort.
Aug 21, 2008 | HP Pavilion dv2000t Notebook
My guitar wont work properly
my scroll bar does the same thing sometimes, it moves up and down uncontrolably without me doing anything. i just recomend restarting and making sure the connections are all right. after i did that it seemed to work fine, but maybe if it keeps happening then you may need to replace it!!
Jan 09, 2008 | Activision Guitar Hero II for Xbox 360...
Uncontrolled scrolling in excel
You System has been attacked by a virus or bug try scanning your PC in safe mode with the latest dat file of MC afee or trend micro. I have faced a similar problem recently and and have got rid of it this way only. Good Luck
Oct 08, 2007 | WYSE Winterm S30 Network Terminal
Uncontrolled scrolling within excel app
Try pushing in on the scrolling ball on the mouse.
I just had the same issue and that's what I did and it quit.
Hope this helps!
Sep 11, 2007 | WYSE Winterm S30 Network Terminal
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
62 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
