Question about Nikon COOLPIX S6000 Digital Camera
My Nikon Coolpix s6000 freezes up and gets glitchy, and gets to where I can't turn it off unless I take the battery out, and when I do, I put the battery back in and the camera won't turn back on.
SOURCE: Nikon Coolpix 2100/3100/3200 battery compartment door latch broken (again)
I just purchased a new battery door for $15 with shipping from nikon. They sent a simple assembly diagram and I was able to replace the door in 30 minutes. I used a dremel to cut the old door off, but you dont have to do that. I got a little impatient.
Just buy the plastic piece and u can reuse the metal parts for your old battery door.
Posted on Mar 26, 2008
PCBuilda
  • 101 Answers
SOURCE: nikon parts
Try 7dayshop.com they have allsorts.
  • 5 Answers
SOURCE: Nikson Coolpix L5 Camera will not power up.
i had someone with the same camera have a problem like yours but it wouldnt turn off and the only way to power the camera on was pressing the power and blue play button. i called nicon and they said try a reset all in the setup menu but this didnt work. i then played for a little longer with it and found if i gentally twisted the body of the camera it would turn on and off as per it should. so i removed the back of the camera ( coution very small screws) and found that the blur control ribbon cable for the top control board had come loose.take something non conductive and not sharp and carfully push the ribbon cable back into is socket. once i had done this everything worked ok.
a few other words of caution while doing this keep track of where the screws come from as they are different lenghts.do not have the batterys in the camera as the flash caps will be charged and if you touch the wrong thing ZAP you could get a nice supprise. and finally when repacing the back of the camera make sure the selector switch for movie , scene and camera is connected right otherwise you will have to remove the back again and fix this issue
i hope this works for you
Posted on May 14, 2009
SOURCE: Removing battery from Nikon Coolpix
i have a nikon coolpix 8400 camera which felldown on the floor and stopped working.how much it cost to repair it? is it worthy?
Posted on Dec 12, 2009
virtualhost
  • 2185 Answers
SOURCE: The latch on the battery door of my Nikon Coolpix
You can get that replaced or repaired thru the list of Nikon Authorized service centers near you area. Just click the link::
http://www.nikonusa.com/Service-And-Support/Nikon-Authorized-Repair-List.page
Hope this helps.
Posted on Dec 29, 2009
How to do hard reset for nikon s6000
Remove the battery for 15 mins. Replace the battery and go to the menu settings and set the date and time.
Mar 10, 2012 | Nikon COOLPIX S6000 Digital Camera
I recived the Nikon Coolpix S6000 in December. It has been working fine up until today. It will not turn on.. I have charged (which the light does show its charging), removed and reinserted the battery. I...
Have you tried checking if the battery door is completely shut and flush with the body of the camera? Try cleaning the contacts where the batteries touch and make sure that there isn't any dust or dirt obstructing the plates. If your camera still doesn't turn on, the battery has probably short-circuited or fried. You can easily order another one for under $10 via Amazon here:
Good luck.
Apr 03, 2011 | Nikon COOLPIX S6000 Digital Camera
My brand new Nikon s6000 won't charge, turn on, it does nothing but lay there and look pretty.
Most of the time the battery does not come charged and manufacturers recomend to charge them for 24 hrs before 1st use or the camera could not recognize it.
Also you can try connect it with the AC-DC adaptor directly if it comes with one just to to test if it works.
Charly Brown
Feb 11, 2011 | Nikon COOLPIX S6000 Digital Camera
When turn my camera on (Nikon Coolpix S6000 I get a Lens Error!
Hi, usually caused by a lens jam or sand/debris getting into the lens mechanism. Lens
replacement will probably be the best solution for permanent results.
Jan 24, 2011 | Nikon COOLPIX S6000 Digital Camera
I was taking pictures with my new Nikon coolpix s6000 and it died. When I plugged it in it just said battery exhausted!
A newly bought camera is not necessarily fully charged. Read instructions about first charging. Enjoy your camera.
Dec 03, 2010 | Nikon COOLPIX S6000 Digital Camera
Four hours old nikon l100 is freezing. also videos
Are you using rechargeable batteries and are they fully charged? If so, take the camera back.
Nov 13, 2009 | Nikon COOLPIX L100 Digital Camera
Nikon COOLPIX S6000 Digital Camera Logo
140 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
