Question about Nikon COOLPIX L20 Digital Camera
I put in new batteries...the camera works fine for four or five pictures and then the battery message comes on that I need new batteries. Sometimes that message comes on before I even get to take a picture. I have inserted 4 sets of new batteries....it's like the batteries are draining instantly.
Same here, not the batteries
1.2v rechargeable Radioshack 1600mah & 1500mah did work though...
If you eventually get it to boot, go to menu and pick coolpix batteries.
Posted on Apr 16, 2011
Camera overheats and shuts off after taking four or five pictures
Hello ksmith1171,
Please be sure that you use 2 fresh AAA batteries. Do not mix a new and used battery or use different battery types as this can cause the batteries to overheat.
Jul 13, 2011 | Intova CP9 Digital Camera
Every time i turn on my sony cyber-shot DSC-N2 now it says "For use with compatible battery only" and then turns off? Never happened before in last 4 years of use? Any suggestions... maybe need a new...
Your camera uses a proprietary Sony InfoLithium battery which I presume you are using. The message normally only comes up when using non-genuine batteries though the chip in genuine batteries sometimes gets corrupted. Four years is a fair lifespan for a rechargeable lithium cell so even without any faults you may already have noticed that the battery needs recharging more frequently.
Check that the battery contacts are bright and clean, and use a torch to look inside the battery chamber to check that the camera contacts are intact and clean. If all checks out then borrow or buy a replacement battery. If you buy a battery then you'll have to try and resell it if the camera proves to be at fault.
If the ultimate conclusion is that the camera is faulty, then it's cheaper to just replace it rather than repair. It was only designed for a minimum five year lifespan, so if it's failed prematurely you've been a bit unlucky. It's worth complaining to Sony anyway, but as they'll want to inspect the camera and will charge you for shipping with no guarantee of a favourable outcome you may decide that you'll just be gambling more money which could go towards a replacement camera.
Sep 20, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
Olympus sp 500UZ digital camera: the camera eats batteries.
Yes. Like all rechargeable batteries they don't last forever and four years is longer than I'd expect.
Replace them with new batteries. You need a 3v lithium ion CR-V3 and if you're in the UK I highly recommend buying them from the Small Battery Company, but they are widely available. Avoid generic "no-name" brands as good quality examples are not very expensive.
Please rate my answer if I have answered your question satisfactorily.
Feb 16, 2010 | Olympus SP-500 UZ Digital Camera
Battery Problem
the problem for the camera turning off or acting weird is the batteries. you need Alkalyne Batteries
Nov 19, 2008 | Olympus FE-210 Digital Camera
Kodak CX7430 can only take 10 pictures with a new battery
Chances are that the problem is corroded battery contacts inside the camera. Remove the batteries and clean the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue that's in the camera from the cleaning, then reinstall your batteries. Hopefully this will cure the problem and get the camera back up and working the way it should.
If that doesn't do the trick, you might want to try your luck with the Kodak Troubleshooting guide at:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=10&pq-locale=en_US
Mar 08, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Short battery life?
I had a smiler problem with Alkali batteries. Thereafter I started using rechargeable batteries and also changed the setting to Ni-MH. Its working fine now.
Feb 26, 2008 | Nikon COOLPIX L10 Digital Camera
Everything seems fine but won't take a picture, no error message
First of all, you should know that when someone advises you to buy more stuff because of a problem you have, it's very possible they're ripping you off! It's a disgrace that they took advantage of you and sold you all that stuff..
Now, to your problem..
First of all, are you absolutely sure that the camera autofocuses properly? That would be the first thing to check. To make sure, turn the focus selector (on the lens) from auto to manual, try to focus manually (it doesn't matter if it's not 100% accurate) and press the button.
If that's not the case, try other modes. Try the camera in (M)anual mode, for instance. Also, just in case, try to clean (with a dry fabric) the battery contacts and also the battery contacts of the camera.
Dec 16, 2007 | Canon Rebel XT / EOS 350D Digital Camera
FujiFilm FinePix A500 screen turns off when trying to take a picture
I had the same problem with a fujifilm finepix... It didn't take pictures with 2 sony batteries, just turned off after pressing the shutter. Then I tried 2 panasonic batteries and it worked fine....
My solution: try panasonic rechargeable.
Oct 24, 2007 | Nikon COOLPIX P4 Digital Camera
Battery Problem
I figured out the problem. My AA battery recharger was not making good contact, so although it said the batteries were recharged, this was not the case. After fixing this and getting full recharges, the problem went away.
Aug 31, 2005 | Canon PowerShot A70 Digital Camera
Nikon COOLPIX L20 Digital Camera Logo
77 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
