Question about GE Advantium 120 Convection/Microwave Oven
My inside bulb has burned out in my GE Profile Microwave JMV1870SK04 how do you relace it
    President:
  • 1,273 Answers
Hi, W/D here.
Sorry, but changing the bulb on this one is a bugger. I have done it several times myself, so I speak with some authority..... But, there is good news as well....we'll get to that in a moment.
You'll need to open the door, and remove the screws that hold the microwave face to the cabinet face.
Next, you'll need to remove the microwave from the enclosure. Remove the metal shroud that encases the microwave, and the bulb may then be replaced. Reversing the process gets you back to where you started.
After the second time of pulling the microwave out, I measured and cut a hole in the sheet metal shroud, larger than the access to the light fixture. I bought a metal electrical box cover, and used sheet metal screws to completely cover the hole. This allows me to slide the microwave out about 6" to access the light, instead of the lengthy process of removing the microwave entirely. If you decide to do this, I recommend that you mark the sheet metal while the shroud is loosely fit on the microwave, and cutting your hole away from the microwave, to avoid getting metal filings into the microwave.
Your bulb is a 120 volt halogen, 35 watts with a GY8.6 base. I bought mine at Lowe's, and their item number is 15797, manufactured for Bright Effects. When installing the new bulb, be careful not to touch the bulb, as the oil on your fingers is enough to degrade the bulb, and it will not last as long as it should. Instead, wrap the bulb in toilet paper or a paber towel, leaving the terminals on the base protruding.
Sorry for the bad news, but glad that I could offer a better alternative. By the way, a technician will do the same thing, without the hole, for about $200.
Best regards, and enjoy your savings, --W/D-- Please rate this solution if you have found it to be of use to you. Thanks.
Posted on Apr 07, 2011
  • 59 Answers
Remove the screws above the grill. remove grill, unscrew control panel, bulb is behind control panel or behind grill.
I have a GE profile oven/microwave combo appliance. Microwave is 1.4 cuft and needs megatron and transformer. Will those parts for any ge 1.4 cuft microwave work in my microwave?
GE profile is a series, not a model. Look inside the microwave and you will see a sticker with the model number on it. Take that number and look it up online you will find many options for the part for your unit. Why do you need both? typically with GE it is usually the mag and maybe the rectifier. If a transformer goes bad it typically burns up and smells horrible. I mostly find bad mags on GE, the ones they use are not very good. OM75P = junk
Aug 12, 2017 | GE Microwave Ovens
The lights on the bottom of my microwave will not turn off. This started when I changed the bulbs due to the old ones burning out. Anyone ever heard of this? Thank you.
If you put in higher wattage bulbs than designed, your bulbs may have caused the control device (relay contacts/triac/diac) to permanently fail thus allowing the circuit to always remain energized.
Apr 30, 2015 | GE Profile Spacemaker XL 1800 36"...
Changing the lamp in microwave of GE model pt970srss
If it is at all like a plain microwave oven, you will have to remove the screw for the cover to access the insides and likely will find that the light is not a simple screw-in bulb but a sealed package with a spare of spade terminals on top. It may be held in by one or more screws.
It is possible that this could be like a new conventional oven where you have to remove a light cover inside the cavity to access the bulb and change it
May 13, 2014 | GE Profile PT970 30" Built-In Double...
Bulb on ge microwave keeps burning out
Hi anything is possible being that you even replaced two different brands of bulbs. I don't think the wiring harness is the problem but like I said anything could be the problem. Might I make a suggestion. Why not replace both the left and right side bulbs with LED bulbs with the same base configuration. Maybe that just might be able to solve your problem. I would like to know if it does. It also seems that a lot of others are having the exact problem. Good luck.
Marty
Apr 14, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
Change inside microwave light GE profile microwave
open the screw and then full out the side and top cover
Apr 21, 2010 | GE JNM1851SMSS Convection/Microwave Oven
GE Profile Spacemake 2.0 fan stayed on and started to burn. Significant smoke damage to the house. Recalled?
check inside to see if the wave guide cover is burnt. If it is you must change.Check for recalls at ge recalls to verify fan recall.
Feb 24, 2010 | GE Profile Spacemaker Over-the-Range...
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, lvinci@gmnew.com
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker Microwave
Absolutely. That's why they make shop bulbs to use in one's portable garage work light and garage door opener.
Slamming the door of a microwave is never good idea!
Another factor is touching the new bulb with your bare skin, as the oils will shorten the bulb life.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 26, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
147 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
