Hi my name is peter i got bit of problem what happend is my fan work at all the time even when the car is cold or hot i know that he should just switch at 90'c to cool down temp but he works all the time that bit freak me out so would u be able tell me what my coz the trouble ... Thank u Peugeot 406 coupe 2.0 99reg
  • masiuk2010 Apr 07, 2011
    what is happend fun works when i turn the engine on when the car is cold then he works works works after while he goes off even when temp is still low when he rich up to 90 fun works cool down the heat to less 70 wich is strange then work work till dont know so what my coz that problem please help me
    Genius:
  • 1,044 Answers
The temperature control unit (Thermostat) is not working properly. Have it repaired or changed.
Posted on Apr 07, 2011
  • 10,319 Answers
The fan relay is stuck on
A/c on 2010 dodge journey looses air pressure and cold temp.
Sounds to me like you've lost some freon refrigerant leaking. And yes, to all those people who read this who think freon is banned because of it's "super greenhouse gas" You're half right. Freon 11 is banned, but freon 12 and cfc 12 are still used, if anyone cares to know the actual name, it's dichlorodifluoromethane. Have a shop check it out and top it up, doesn't cost a whole lot and is almost certainly your issue. Hope this helped a bit, Grim
Aug 19, 2015 | 2010 Dodge Journey
2004 ford thunderbird< radiator fan keep running
Hi Kevin. Since your fan run even when the engine is cold,my advise is to go direct to the temperature sensor,which actually is the main culprit for causing the confusion to the ECU. Since the temperature sensor does not work correct,the message send to the ECU is wrong - like is sending that the engine is hot - the ECU order the fan to start. Also there is another possibility for the fan relay to remain stuck and leave the fan to work constantly.
Good Luck.
May 05, 2014 | Ford Thunderbird Cars & Trucks
1998 Town Car A/C Blows Hot Air But Is Charged Up
Hi - There may be 2 separate problems. On my 1991 Lincoln Town Car, there is a Thermal Blower Lockout sensor that disables the heater from blowing until the engine temperature reaches a specific temperature. This way if you have vent or floor settings and 90 degrees set and it is winter, you won't get blasted with cold air. When the vehicle warms up, the TBL circuit enables the climate control to blow the hot air. If you use the flr/def instead of the floor or vent control, the TBL should not prevent the heater from working even with a cold engine. On my car, the TBL went bad and always prevented hot air from blowing on the floor and vent settings, even when the engine was hot. Another thing to check is a thermal limitor resistor. It is designed to cut off the blower at very hot temperatures, except if the blower fan is in the hi setting.
As far as the A/C is concerned, can you verify if the clutch is engaging or not? A rapid cycling of the clutch is an indication of low freon. If you are absolutely sure that you are fully charged on freon, I think there are 2 possible causes: (1) Bad pressure switch on the accumulator is indicating low freon that is telling the compressor not to work; (2) a blocked orifice tube.
Aug 02, 2009 | 1991 Lincoln Town Car
2001 Volvo s-40 cooling fan comes on after the key is turned off. all the time. (even when COLD) ????
its normal for it to come on when its hot, but if it dose come on when its cold i wouldnt worry about it, if it dose bother you take it to a garage i sure they will say the same as i have,
Jun 05, 2009 | 2002 Volvo S60
My playstation 3 fan runs constantly and don't seem to stop unless the power is off.
Hi my name is Juan and I am here to help you on this the fan on this unit is allways on especailly that ou have the 60Gb the ps3 with the 80Gb and 60Gb models they do get verry hot and for this reason the fan won't stop it may even increase speed as heat builds up if the fan on those 2 units that I mention stop working for only 15 seconds belive me the next thing it can happend is playstation will shuft down immediately and it would not start the next time so don't worry for the fan try to make sure you have a good clearance around the ps3 to keep it cool
Mar 23, 2009 | Sony PlayStation® 3 (60 GB) Console
Heater only blows hot (well, warm) on full speed of fan
Replace the temp control on this car, it should be electrical control not cables.
Dec 03, 2008 | 2000 Ford Escort
AC Blows cold then hot
I had this happend to me on my 2004 2500 in july in S.C.I turned the key off and on 5-6 times and i have not had that problem again.
Aug 13, 2008 | 2004 Chevrolet Silverado 2500 Crew Cab
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
