My Brother 4100e jams paper at the end of the paper rout.
    Novelist:
  • 144 Answers
Hi there!
dont pull the paper out the next time that happens, please click on the link for paper jam issues with Brother printers:
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/000400/000095/faq000495_014.html?reg=us&c=us_ot&lang=en&prod=fax4100_us
Posted on Apr 06, 2011
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
Jan 30, 2016 | Brother IntelliFAX 4100e All-In-One Laser...
Why is my Brother Intellifax 4100e error says check paper size?
your paper error message means you probably received a document that wasn't the size of paper in the paper tray ,try legal sized paper,to dump the job stuck in your faxes memory ,this
problem happens a lot, theres reall nothing wrong with the fax/printer
Aug 13, 2014 | Brother IntelliFax-4100e Fax
We can send faxes with no issues but when we receive a fax that has multiple pages after the first couple of pages we get half pages, partial prin or blank pages. We were told it was a possible system...
Is it pulling two pages at once? Sometime a machine will start to pull a sheet normally, then the page below it will get dragged along by the friction between the two sheets. One page's print gets divided between the two. If that looks like the case, pull out the paper drawer, remove the paper, and lightly sand the little rubber or cork pad at the front, then wipe the dust off with a damp cloth and let it dry. Before putting the paper back in, grasp the stack at one end, and "fan" the other, allowing air to get between all the sheets.
Get into the machine's Paper menu to see what size is programmed for the tray. If you have Letter size in there, but it's set for some other size, all kinds of feeding problems can occur, including false jams.
The paper feed roller is controlled by a magnet lever inside the right side of the machine. It should click once to start each sheet feeding. I've seen one Fax 4100e that clicked over and over, feeding extra sheets, just like you described. It turned out to be the system board. Worse yet, Brother had switched factories in mid-production of this model, and the replacement board they sent us fed paper just fine, but wouldn't do anything right on the phone line. Couldn't dial, couldn't answer. They sent another replacement, and it was exactly the same. Brother eventually broke down and sent a replacement machine.
Oct 06, 2010 | Brother IntelliFAX 4100 Laser Fax
Frequent paper jams
Start with the paper itself. Make sure it is in the machine properly. Here is a short guide on a few things to check:
http://cincinnatiprinterrepair.com/paper-jams
Jun 27, 2010 | Brother IntelliFax-4100e Fax
My fax machine keeps jaming on the right side in the paper tray, what causese this
When it jams, does the paper get bent or crinkled? If so, there is probably something lodged in there causing the paper to stop. Could be a paperclip or staple, or maybe another piece of paper.
If there is nothing blocking the paper and it just stops feeding on one side, you may have a tension problem -- springs might be getting old and not pushing rollers together tight enough to feed the paper. If you can take the machine apart, try switching the springs around to see if that makes a difference.
May 26, 2010 | Brother IntelliFax-4100e Fax
Black streaking down one side
You need to open the front cover of the machine and remove the cartridge (drum and toner) On the top right there is a tab that you need to slide from left to right about 20 times, then bring back to home position
Apr 10, 2010 | Brother IntelliFax-4100e Fax
The copies are coming out of the back end of the machine?
There should be a door or hatch on the back that the paper is coming out on. Just close this and the paper will come out in the normal place. Some printers and faxes have these doors so you can run thicker paper through that would not be able to bend enough to get around everything.
Apr 07, 2010 | Brother IntelliFax-4100e Fax
We have a brother fax machine and it makes a loud clicking noise we think the brushes are broke
There may be several reasons for the clicking noise
1. May be paper clips or other foreign material got stuck inside
2. May be a piece of paper got stuck inside and is somewhat causing this problem
3. May be after having removed a paper jam, some parts within the machine got loose.
The most evident situation is to have a quick look, without disassembling the equipment.
If still the problem persists, then it's better to have the equipment checked by a professional.
Mar 31, 2010 | Brother IntelliFax-4100e Fax
PAPER JAMS ALMOST EVERY TIME WE RECIEVE A FAX OR RUN A COPY
Load the paper with curled side facing away from you. Hold the paper from at the top with 2 fingers. the paper should be away from you. Important also is to remove all of the remaining paper. then add addtional paper before putting back into paper set.
Jan 07, 2010 | Brother IntelliFax-4100e Fax
Brother 4100e paper jam
Can be tricky people usally damage the fuser rollers removing this jam with pliers/tweezers, it has concertined and stuck after fuser rollers and before exit rollers it will be stuck on the switch best bet is to dismantle properly and remove fuser then dismantle fuser and remove jam, another thing to be concerned about is why did it, three seneraros, Damp paper going threw fuser dries and crincles(use fresh paper from sealed packet), fuser is worn(have fuser replaced), just a bad bit of paper (just have fuser jam removed. Fusrr runs on 240v, covers break easy
Oct 15, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
jasbo
jasbo
