Maytag centennial washer won't spin - Washing Machines
SOURCE: My Maytag Centennial washer jumps around during
Have to keep the loads a little smaller and better balanced. Does not appear to be a particular problem with my machine.
Posted on Jan 21, 2010
SOURCE: Overfilling maytag centennial - brand new?
My Maytag has a load size sensor that automatically fills the tub with the appropriate amount of water. This sensor gets over-ridden if the lid is opened while filling. In other words, don't open the lid during the cycle. If you do, the machine will fill to the top as if there is a huge load in the tub.
Posted on Jun 21, 2010
Daniel S
  • 4323 Answers
SOURCE: Maytag Centennial will not spin
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 22, 2010
richroth
  • 9472 Answers
SOURCE: I have a Commercial Series
Replace the "water inlet valve" on your machine. If you could post your model number I can point you to the part you need.
Posted on Dec 26, 2010
richroth
  • 9472 Answers
SOURCE: Washer immediately goes into wash cycle when
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Posted on Jan 26, 2011
Wash cycle will agitate 3 spins then nothing for a few minutes then 3 more and nothing again and repeat over and over
you may want to put it through a diagnostics cycle and check for error codes... Maytag Centennial Washer Repair Guide
The tub sensor can cause the washer to act strangely like that. Also there are two mechanical styles of washer branded Maytag Centennial. The model number would help to know we are talking about the one I think we are talking about.
Hope that helps!
May 27, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
My Maytag Centennial elec dryer won't dry well
could it be the thermasat are all the wires connected
Jan 01, 2012 | Maytag Dryers
Washer wont start, it will spin but will not begin the wash or start to fill
It won't wash till the water fills to the point of tripping the water level switch. Check your screens for clogsthemobilian_3029.jpg
Service manual and more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 22, 2011 | Maytag Centennial MTW5800TW Top Load...
Centennial washer, will fill with water, wont spin or agitate, power is good
Easy fix. Lid switch is bad. This is a direct drive machine. Older models would wash but not spin these latest babys won't wash or spin with the lid switch broken. To access te switch you flip up the control by using a putty knife to release each end. Older models had a screw that needed to be removed, not so with the newest ones. The switch has 2 hot wires and a ground wire. Jump them 2 hot wires and see if she runs
Video: How to get into these machine:
How it works
Apr 30, 2011 | Maytag Centennial MTW5800TW Top Load...
Washing Machines Logo
380 people viewed this question
Top Washing Machines Experts
