Samsung tv ln26a330 won't turn on red light blinking
  • 2,098 Answers
This is an indication of out-of-regulation in the power supply section. The very common caused of this fault was the dried/leaky electrolytic capacitor in that section. It will drop the supply from normal voltage and will disable the unit and blinking error appear. Sometimes it has a bulged/dome at the top but not all, you must have a capacitor checker/tester to determine its condition to pinpoint where the faulty one. Also, bad solder joints can produce the same symptom, it is hard to spot, you should use table lamp/portable lamp for finding the cold solder. Another reason of fault is the open fuse/fusible resistor in series with the output of regulator IC/transistor, shorted/openRegulator IC/transistor, shorted zener diode(all are in the power supply section) and the microcontroller. Best that you check the output voltage of each regulator to determine where the fault came from and narrow the job.
If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Also check if your unit is under warranty /extended warranty, avail it because the manufacturer of your unit will fix it for free. Don't open the back panel, this will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 06, 2011
When I turn on the tv it beeps 4 times then the power button light will flash 3 times in a row but the power will not come on it just keeps flashing 3 times
power will not come on Linda, could be bad capacitors or cracked/bad solder joint,bad main logic board.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung TV won turn on blinking red light explained fix 18
Sony Bravia TV kdl red blinking led light error codes solutions
Apr 02, 2016 | Televison & Video
Samsung plasma blinking red light, tv won't turn off
Hello, The real problem is on your TV 'scircuit. Due to high electric power supply there might be a short circuit damage. It's better you call up your service technician and ask him to offer you a onsite support.
Nov 11, 2017 | Samsung PN51D7000 3D Plasma TV
Tv won't turn on
Replace the power supply board the blinking power indicator is usually indicating the power supply needs replacement or repair. You can get the replacement power supply boards from www.tvcircuitboards.com
Oct 20, 2012 | Samsung LN-S3241D 32 in.LCD HDTV
Samsung TV won't turn on. Red light is solid, won't blink when pressed. All capacitors seem fine (none swollen or vented).
That model is covered under a class actions lawsuit settlement over bad power supply boards. You need to contact Samsung about this and get a warranty claim started, even if the original warranty is over the settlement terms will cover parts and labor. You can get additional information about this along with contact information here: http://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/
Sep 24, 2012 | Samsung LN32A330 32 in. LCD TV
The red "on" light is blinking and the TV
a suggestion: unplug set and try to turn on again; if power light blinks does it blink in a sequence?
3 blinks repeated will mean a problem in the Convergence area.
5 blinks repeated will mean a short on the 140 volt line.
These are the two most common error codes.
SD TECH
Aug 31, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Samsung 56" Model HL56A650C1FXZA will
Mine is doing the same... anyone find a solution?
Jul 05, 2011 | Samsung HL56A650 56 in. TV
On/off button flashing red will not turn on.Model # LN26A330 bought 1yr.and 6months ago. I am not located near a certified dealer.
This problems alway the causes and the problems of the power supply board is dying.That the tv board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 17, 2010 | Samsung LN26A330 26 in. LCD HDTV/DVD Combo
The television will not turn on. the power button on front of tv has red light that is constantly blinking. why cant we power it on.
It is sensing problem and staying in safety shutdown mode, it can be due to bad DC power due to bad caps, shorts circuits in the backlight inverter board, main laogic board problem. Power supply voltages should be check first. You will need to do in-depth troubleshooting.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Oct 26, 2010 | Samsung LN26A330 26 in. LCD HDTV/DVD Combo
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
