Question about Kicker Car Audio & Video
I have 2 kicker cvr15 4 ohm duel voice coil speakers how do i wire them to a kicker zx1000 amp??????????
    Problem Solver:
  • 13 Answers
The ZX1000 is a two ohm stable amplifier, so this means that you have to connect your two voice coils in series to give you around 8 ohms impedance per speaker, then connect your two speakers in parallel to give you 4 ohms impedance on the single mono channel on the amplifier. I recommend you connect it up in the following manner:
Posted on Apr 07, 2011
How do you wire a single 15 L7
Depends on a few things. What is the impedance of your speaker? I will assume it is dual voice coil with each voice coil having a characteristic impedance of 4 ohms. Next what amp are you driving this speaker with? What is its minimum stable load it can run at in bridged mono? If it is 2 ohms stable then you can wire the voice coils in parallel, + to + and - to -. Then wire the + and - to the amp in its recommended bridged configuration. If the amp is not stable down to two ohms you will have to wire the voice coils in series, you will not have effective power from the amp with an 8 ohm load.
Here is a diagram from kicker to aid you.
http://www.kicker.com/dvc_wiring
Jul 20, 2011 | Kicker Car Audio & Video
How do i install 2 ckicker cvr to my amp
Here are a couple of diagrams 2+4 ohm dual voice coil wiring.
Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
Option 1 (parallel/parallel) = 0.5 ohm load
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif
Apr 12, 2010 | Kicker CVR12 Car Subwoofer
How do i hook up kicker solo baric in the box
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif Option 1 (parallel/parallel) = 1 ohm load
Apr 10, 2010 | Kicker Solo-Baric L5 Car Subwoofer
I have an Audiobahn A8000T amp and 2 12" Kicker CVR (DVC) Dual voice Coil. The Subwoofers are 2OHM a peice. What is the best way to hook this all up to run a 2 OHM load to my subs?
This is a link to Kicker for your CVR12 Subs...if you have the 2 ohm version (2 ohms per voice coil) and you have 2 speakers ....you will need to wire EACH speakers voice coils in series to get 4 ohms from each speaker and then wire the 2 speakers in parallel.....as in....2 ohms in series with 2 ohms = 4 ohms....both speakers wired same way, then in Parallel with each other = 2 ohm load. Page 2 of this link gives examples of both series and parallel wiring of your speaker.
http://www.kicker.com/sites/default/files/2006CompVX.pdf
If you are still not sure as to my description of ' How To',
PLEASE respond and I will attempt to explain it EXACTLY via wiring directions.
Nov 18, 2009 | Kicker CVR12 Car Subwoofer
How do i wire a duel voice coil speaker
First you need to know wether it is dual 4ohm or dual 2 ohm voice coils. There are many configurations. I would aslo need some information and specs on the amp you will be using. You can run the sub in parallel or in series. Basically that determines the load to your amp. Post up some specs on your speaker and amp and I will be able to further assist you.
Nov 03, 2009 | Kicker CVR12 Car Subwoofer
Logic soundlab cpx1400 need to wire to a kicker cvr 15
Hello discrete01,
The Kicker model number 07CVR122 has dual 2 ohm voice coils, and can be wired for either 1 ohm or 4 ohms. Model number 07CVR124 has dual 4 ohm voice coils and can be wired for either 2 ohms or 8 ohms.
Kicker's wiring page is here: http://www.kicker.com/dvc_wiring
If you have the version with 2 ohm voice coils, you want to use the 2nd diagram for a final load of 4 ohms to the amp. The 1 ohm load is too low for the amp and will cause it to overheat and possibly fail. If you have the 4 ohm version, use the wiring shown in the 3rd diagram which is a perfect match for the amp.
Hope this helps.
Aug 11, 2009 | Kicker CVR12 Car Subwoofer
I need to know how to bridge a a 4 ohm 15 inch sub down to1or2ohm
Hello solo7908,
With a single 4ohm DVC sub there are only two possible wiring solutions, parallel the voice coils for a final 2ohm load or series the voice coils for an 8ohm load. In your case, you want to wire them in parallel, both positives and both negatives connected to the amp terminals.
Here are the diagrams: (-) to (-) and then to the amp - (+) to (+) and then to the amp. Impedance = 2ohms.
Hope this helps.
Jun 06, 2009 | Kicker CompVR 12" Subwoofers/Enclosure...
I have 2 kicker l7 12 dual voice coil subs.. i just friend a hifonics 1600w amp and am wondering if a kx 1200.1 kicker amp will be enough to power them they are 750w rms a piece .. can these be run at 1...
it all depends on the impendance of your subs if u have duel 4ohm or duel 2ohm, 2 duel 4ohm speakers can be wired at 1ohm to the amp, and with a kx1200.1 that would be pushin 2400 peak and 1200rms
if ya have 2 duel 2ohm speaker than you can only wire them to 2ohm and would be pushing 1200 peak and 600 rms with the kx1200, so if you have the duel 4ohm i would go with the kx1200.1 and if u have the duel 2ohm i would go with the hifoncs
Apr 23, 2009 | Kicker KX1200.1 Car Audio Amplifier
How do i wire 10' kicker cvr
dual 2 or dual 4
dual 2 wire vc's in series for a 4 ohm load each. Hook each speaker seperate channels on the amp.
dual 4 wire vc in series for an 8 ohm load each. Hook both + to the right + on the amp and both - to the left - on the amp. or
dual 4 wire vc in parallel for a 2 ohm load each and hook each speaker to seperate channels on the amp.
Dec 18, 2008 | Kicker CVR12 Car Subwoofer
My kicker amp turns off
It sounds like you may have the load impedance too low. How many voice coils per woofer? How many ohms is each coil? If you have DVC woofers, are the coils for each woofer wired in series or parallel? Are the speakers wired in series or parallel. Let me know if you need me to clarify anything.
Oct 05, 2007 | Kicker ZX10001 Car Audio Amplifier
Car Audio & Video Logo
99 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
