Question about Hobart Food Mixers
Hobart M-802 mixer
Mixer runs fine ...if shut off after running a while it won't start again till it sits for a while
  • 640 Answers
Your overloading the mixer with too much product or not enough water,cut the batch down,the motor protection board is doing its job by shutting off.
Posted on Aug 07, 2008
My Hobart D-300 keep stop after running about 10 minutes and stay idol about 5 minutes then I can push start button to run another 10 minutes, it seam like control unit stop after it getting over heat and...
If your mixer's motor was built by Hobart; there are thermsiters built in to the stator's windings that can cause this problem. Check the amp draw while it is running. Also if your are over loading the mixer or using the wrong speed,, that will cause an over heating problem. You should be able to get on the ITW Food Equipment Group / Hobart web site(s) and get capacity chart.
Mar 01, 2015 | Hobart Food Mixers
I have a hobart mixer 80 quart .The motor makes a noise and would not start. It only starts if I turn the shaft and turn the on switch at the same time
Most motors of that type have a capacitor that puts the stator out of phase with the rotor. They are capacitor start induction run motors. These also have a centrifugal switch inside near the end ot the shaft to put power to the start winding for a split second to determine the direction of turn and to increase horsepower until it is up to speed. So if it fails to start either the centrifugal switch needs cleaning (or replacement if damaged) or the capacitor needs replacing to give it its original power, or the start winding has failed from overheating. There may be a thermal cutout on the start winding that may need to be replaced if it did overheat. If the start winding burned then the motor would require rewinding or replacement.
Oct 10, 2013 | Hobart M-802 80qt Dough Bread Bakery Mixer...
Motor not spinning in hobart 60 qt mixer
Check manually after disconnecting the motor if this is jammed. If so the motor must be reset as the bearings are faulty and so the rotor seems to get stuck with the coil core.
Also if there is high drain with heat it is possible that the coils are faulty and might need an insulation failure test.
Nov 22, 2011 | Hobart H600 Stand Mixer
Hobart A200 mixer won't start
My fantastic guy just rebuilt my A200. He says it's likely that your back plate is slightly off center so that the center arbor is touching the windings-- any contact and the machine won't run. The tolerances are thousandths of an inch in there.
Nov 21, 2011 | Hobart A200 Stand Mixer
Hobart m-802 mixer won't start up
call Hobart for the correct oil any way and an elcetrican will just add more problems for yoy
May 30, 2009 | Hobart A200 Stand Mixer
Hobart A-200 mixer (OLD!) runs hot & shuts down.
You have killed it by overloading the bowl. Hobart recomends no more than 65% bowl capacity on doughs & 75% on batters or icings. Replace the motor or the whole unit
May 25, 2009 | Hobart A200 Stand Mixer
Need replacement motor for Hobart M-802 mixer
Hi Dan. Two options. The first is to call Hobart and ask about a temporary replacement mixer while your original motor is being rebuilt. They'll charge you for it, if they will do it at all. If Hobart is doing the rebuilding, they might give you a better price or a free loaner.
Second. eBay often lists hobart motors for sale, you might get lucky and find one quickly. Since you absolutely must have a working mixer for your business, you might consider having a spare motor on hand for just such an occaision.
If this solution has assisted you, please rate it. Good luck! ricardok45
May 05, 2009 | Hobart Food Mixers
Hobart D300T mixer oil change.
Call your local hobart branch and tell them you need grease for a d300 mixer.Yes this mixer uses grease now.If it's older they used oil but is no longer available.
Mar 15, 2009 | Hobart D300 Stand Mixer
Food Mixers Logo
132 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
