Question about Pool & Spa
I have a dead short between active and neutral on my hayward pool pump
    President:
  • 1,378 Answers
Dead short? What type of meter are you using? Resistance between the line terminals when the motor is not running is often less than one ohm; I assume by 'active and neutral' you are refering to the two line connection terminals.
What is the problem or question you have? If you actually have 0 ohms line-to-line then the breaker will keep tripping and the motor needs to be replaced. If the motor buzzes and fails to start and then trips the breaker it MAY be worth fixing depending on where the trouble is:
It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
Start with the capacitor. Use a digital multi-meter (DMM), preferably with a capacitor setting, or an analog meter set for Ohms. With an analog, you should see the needle deflect as if testing a closed circuit then it will slowly drop to 0 if the capacitor is good. If it doesn't move or moves and stays to the side showing a closed circuit the capacitor is bad. If you notice a burn hole near the terminals on the end of the capacitor do not bother to test it. If you do not have access to a meter you can try grounding the posts together with a screwdriver to see if they arc although It is not a very reliable test method. Be sure you are holding on to an insulated handle for the tool you use to short the terminals together or you can get a good poke.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage. If you wish to continue to try to repair it yourself please comment with any questions you have as you work thru the pump and motor.
If this answer does not fix your problem, please comment with additional details or contact me thru our site at www.arrowpools.net prior to rating the answer; I'll do what I can to help. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 08, 2011
Where does the neutral hook up go for the pump
Assuming you are connecting the pump for 115V the L1 and L2 terminals in the motor get the black (hot) and white(neutral) leads and the ground goes on the green screw. It does not matter which L post gets hot or neutral as long as one wire goes to each terminal.
John
Mar 02, 2011 | Hayward Maxflo Ii 15 Hp Swimming Pool Pump...
I HAVE A HAYWARD SUPER PUMP SELF PRIMING MODEL : C48L2N134B1 1 1/2 HP 115/230 VOLTS IT IS BROKEN AND I WANT TO KNOW WHAT MODEL I SHOULD BE BUYING TO REPLACE IT WITH. THE MODEL NUMBERS ARE DIFFERENT...
What is broken in your motor? Don't count it out until you have your pool place give it a check. If it is dead, get a 1 1/2 Hayward Super Pump just like the one you have.
Thanks for your interest in FixYa.com
Aug 11, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
Have voltage to the Hayward Tristar pool pump but it won't run!
SOUNDS LIKE YOU HAVE A BAD BREAKER.. THIS IS A GRAVY FIX.. I SEE A VOLT METER IN YOUR FUTURE YES ITS ONE TO CHECK 230 V AC .. YOU LOCAL CAR PARTS STORE HAS THESE CHEAP .. ASK HOW TO USE IT AND YOUR OFF.. WHAT WE ARE LOOKING FOR IS 230 240v IN THAT RANGE ON THE 2 WIRES ON THE BACK OF THE MOTOR... OR EVEN THE TIMER.. NO?.....BREAKER NO? REPLACE BREAKER... BREAKER YES.. CHECK TIMER CONTACTS .. don't forget to prime your pump after a repair !!!!!!!!.. did i help ? well then please vote.. I got to get back to fix'n the pool pumps here in Florida ... Jay .. PPRG
Jul 08, 2010 | Hayward TRISTAR INGROUND POOL PUMP - 2 HP...
Hayward Swimming PoPump is 4 years old - when I opened pool, pump
it you've inspected all the wiring for possible shorts, the most likely problem is that the motor has developed a short in the windings. You may have to replace the motor. First check for loose connections and make sure the wiring going to the pump is good. Also, check the start capacitor, should be under the hump or under the end cover on the motor. If it's bloated or leaking, it's bad.
Most likely the winding have a direct short.
Apr 05, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
I am installing a Hayward Pool pump max flo II at 120 volt. I have 2 connections L1 and L2. Which one does the black hot wire go to.
Either one. Neutral to the other post. Be sure to set the voltage change device to 115V to match your incoming line voltage.
Sep 15, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Does the live black wire need to be on the jumper side of the hayward super pump direct wiring ??
It does not matter which side it is on as long as hot is on one side and the neutral the other.
Jul 01, 2009 | Hayward 1HP Super Pump II Inground Pool...
Hayward pool pump for S-200 filter only hums and then blows the circuit?
The motor winding is probably shorted -- needs rebuilding/replacing.
May 09, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Pool & Spa Logo
56 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
