Question about 2wire (2701HG-B) Wireless Router
We have a 2 wire system. we have an additional 2 wire If we put pc's in 2 separate areas of the house, can one be hooked into each of the units and function properly?
    Master:
  • 395 Answers
If all four connect to the same internet router. They should be working or functioning properly.
Posted on Apr 06, 2011
I have a 200 amp main with sixteen seperate rooms
You've already exceeded 200 amps . You should put in a 125 amp sub panel in the shop. You should get a copy of the electrical code book so you won't run afoul of the electrical inspector. The book also spells out correct wire size for the distance and how many outlets on each branch circuit. Dint forget GFI's for wet areas.
Aug 28, 2014 | Electrical Supplies
I have a 200 amp main with sixteen seperate rooms each with two or three light fixtures and four power outlets. In addition I need to have six or seven 220 lines for the house. For the dryer stove furnace...
Hard to tell from your description but the best way is to add a separate box if the main breaker box doesn't have the capacity. the separate box would be done with #4 copper to the main lugs and it would need a main. You could also put in a larger 220 in your main panel depending on the demand of the subordinate panel you'll be installing.
I have a"performance technique ICBM-9774" does anyone know how I would hook it up in a motor home for my aunt? There are just a positive and negative coming from the wall and im not sure where to hook
This looks like a job for Superman or maybe you! Connect an alligator clip test wire to the chassis of the unit for a good ground. Get a 12 volt battery and hook the other end of this ground wire to its negative pole (-). Hook a second wire to the positive pole of the battery. Put that modular plug back in the unit making sure that all the wires coming out of it are separated. Then, trying the THICKER RED wires first touch each to the positive (+) wire from the battery. When the panel light of the unit is on...you got it! The thinner wires are mostly for the speakers with black for negative an red for positive...the antenna is anybody's guess!
Jan 15, 2013 | Cars & Trucks
Thermastat diagram install
Thermostat - 3.0L (2V) Removal and Installation
  1. Partially drain the engine cooling system. For additional information, refer to COOLING SYSTEM DRAINING, FILLING AND BLEEDING .
  2. Remove the three thermostat housing bolts. Fig. 25: Removing Thermostat Housing Bolts
    Courtesy of FORD MOTOR CO.
  3. Remove the thermostat O-ring seal.
  4. To install, reverse the removal procedure.
Thermostat - 3.0L (4V) Removal and Installation
  1. Raise and support vehicle. For additional information, refer to JACKING & HOISTING .
  2. Remove the front splash shield. For additional information, refer to FRONT END BODY PANELS .
  3. Drain the cooling system. For additional information, refer to COOLING SYSTEM DRAINING, FILLING AND BLEEDING .
  4. Remove the cooling tube bolt. Fig. 27: Removing Cooling Tube Bolt
  5. Lower the vehicle.
  6. Remove the radiator upper cooling tube bolt. Fig. 28: Removing Radiator Upper Cooling Tube Bolt
  7. Disconnect the upper radiator hose and engine vent hose. Fig. 29: Disconnecting Upper Radiator Hose And Engine Vent Hose
  8. Remove the two bolts, and separate the radiator tube from the thermostat housing. Remove the thermostat. Fig. 30: Removing Bolts And Separating Radiator Tube From Thermostat Housing
  9. To install, reverse the removal procedure.
Apr 22, 2012 | 2002 Ford Taurus
I have a deluxe wired heat pump and am enquiring what the 2 zones" are
Debi - "2 zones" usually indicate, 2 separate areas of the house(upstairs & downstairs). But, this usually requires two separate heat pumps for each area. That is unless, you have an electronically controlled damper system in your home's duct work. If that's the case, when one area calls for heat or AC, the damper closes to the other area and vice versa. If both areas call for heat or AC, the damper stays in the neutral position.
Hope this helped you. Please let me know. Thanks.
Jun 20, 2011 | LG Heating & Cooling
Motor removal
The body on this unit split apart at the bumpers. You will open the front lid and slide the bumpers and the internal slides forward to separate the panels then the rear housing will drop off. At that point you must gently separate the halves by opening back to front. Pay attention the the hinge area for the bag chamber door as there.are 3 tabs which will lock together during reassembly. Note how each component slides into a body channel for positioning for reassembling
Do not yank apart, look inside to where the tubes and wiring harness are located and disengage the bag lockout switch from the bag cage if equiped, being carful not to lose the spring.
The wiring harness in this unit is designed so the longest wires reach the furthest terminal, but you should mark each lead in the body and also in the motor shroud
**** Also note the position of the thermal couple on the motor as you remove it***. The motor and rewind will separate form the bag cage by lifting up and back with the vac laying upside down. Then gently separate the shroud from the rewind where they are clipped by prying with a flat screwdriver. Reassemble in reverse order tucking the cord grommet into the body, then closing from the hinge area back.
Best of luck. Let me know if you need more help.
Oct 14, 2009 | Electrolux UltraLux 2000 Bagged Canister...
This is ''pops'' moore again!trying to save a $ You helped me before on the firing order.went to a/c guy.he tested system,said evaporator was bad and needed to be changed.his est.was my first born and a...
I assume he used a leak tester and found a leak in the evap which is inside the plenum housing. Need to remove the plenum to get access to the evap. big job. If you are technical, you could remove the plenum assembly and let him replace the evap & then let you out the plenum back in. Then take back to have him evacuate and recharge system.
SECTION 412-03: Air Conditioning 1999 Town Car Workshop Manual
REMOVAL AND INSTALLATION Evaporator Core Removal and Installation
NOTE: The evaporator core is not separately serviceable. It is serviced only with the evaporator core housing assembly.
NOTE: Installing a new suction accumulator is not required when repairing the refrigerant system except when there is physical evidence of system contamination from a failed A/C compressor or damage to the suction accumulator.
NOTE: If an evaporator core leak is suspected, the evaporator core must be leak tested before it is removed from the vehicle. For additional information, refer to Section 412-00 .
  1. Remove the evaporator core housing. For additional information, refer to Section 412-02 .
  1. Transfer the components from the old evaporator core housing to the new evaporator core housing
  1. Install the evaporator core housing. For additional
  2. information, refer to Section 412-02
Evaporator Core Housing Removal
  1. Disconnect the battery ground cable (14301).
  1. Recover the refrigerant. For additional information, refer to Section 412-00 .
  1. Drain the radiator. For additional information, refer to Section 303-03 .
  1. Remove the screws and the RH cowl vent screen.
  1. Disconnect the vacuum hoses and the wire harness connector from the evaporative emission canister purge valve (EVAP canister purge valve) (9C915).
  1. Remove the nuts and remove the evaporative emission canister purge valve.
  1. Remove the heater hoses from the heater core.
  1. Remove the screw and reposition the windshield washer fluid reservoir.
  1. Disengage the four wire harness retainers from the top of the RH fender apron.
  1. Remove the RH front wheel and tire.
  1. Remove the screws from the RH fender apron and remove the fender apron.
  1. Disconnect the wire harness connector from the A/C cycling switch (19E561).
  1. Disconnect the wire harness connector from the blower motor (18527).
  1. Disengage the wire harness connector from the retainer.
  1. Disconnect the evaporator to compressor suction line from the suction accumulator/drier (19C836). For spring lock couplings disconnect and connect general procedure, refer to Section 412-00 .
  1. sxg~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To prevent damage to the fitting and the tube, use a backup wrench when removing the suction accumulator/drier.
    Disconnect the suction accumulator/drier from the A/C evaporator core.
  1. Remove the clamp screw retaining the A/C accumulator mounting bracket to the A/C evaporator core housing and remove the suction accumulator/drier.
  1. Disconnect the condenser to evaporator tube from the A/C evaporator core (19860). For spring lock couplings disconnect and connect general procedure, refer to Section 412-00 .
  1. Remove the RH instrument panel insulator.
    • Remove the pushpins.
    • Disengage the courtesy lamp holder.
    • Disconnect the power point wire harness connector and remove the RH instrument panel insulator.
  1. Remove the in-car temperature sensor hose and elbow from the evaporator housing.
  1. Remove the nuts at the top of the evaporator housing.
  1. Remove the nuts at the bottom of the evaporator housing.
  1. Remove the screw and nut near the blower motor.
  1. Remove the screws.
  1. Separate the housing and remove the blower motor and A/C evaporator core.
  1. Disconnect the wire harness connector.
  1. Remove the evaporator core cover.
Apr 06, 2009 | 1999 Lincoln Town Car
No power to subs
I think the blue wire is a standby "on" to be hooked to separate or system switch. Without knowing how you have system wired, I can' offer much. A bit of caution; having a thousand watt amp hooked to 6x9 dooms their fate
May 06, 2008 | Legacy Audio Blue Diamond LA1880 Car Audio...
2wire (2701HG-B) Wireless Router Logo
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
