Question about HP Compaq Cooling Fan
Cooling fan is not working properly - HP Compaq Cooling Fan
  • HP Master
  • 27,725 Answers
you will have open up your computer to check the electical lead/s that attach to the fan make sure the connection is good and secure and there is no dust built up be sure to wear an earth strap before touching any parts inside your computer if you find it to be fauty you might need to buy a new one also if its a laptop you could get your laptop a usb cooler pad they are very cheap and your laptop will love it you can get both of these on Ebay
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit dust causes static to build up in a computer causing it to overheat any many other problems
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
Posted on Apr 06, 2011
C550 cooling fan not functioning, what can i do to make work?
Konica Minolta bizhub cooling fan not working Questions ...
www.fixya.com/tags/cooling_fan_not_working/printers/konica.../bizhub
Konica Minolta bizhub printers & copiers cooling fan not working related questions and answers. Ask your Konica ... Question about Bizhub C550. 1 Answer ...
Konica Minolta Bizhub C550 Cooling fan power - Questions ...
www.fixya.com > ... > bizhub > Konica Minolta Bizhub C550
konica minolta bizhub c252 error c-5351 C - 5351 Is power cooling fan problem.Verify the cooling fan connectors and clean.For reset open/close the front door.
cooling fan not operating properly - HP Support Forum
Nov 29, 2015 | Cars & Trucks
Lumina cooling fan
Hi Dan:
If the cooling fan is not working the normal routine would be to replace it. Before doing that be sure that all of the other components (Radiator, thermostat, water pump, coolant, hoses) are working properly.
Mar 11, 2015 | Chevrolet Cars & Trucks
915 service motor error
The error means that the printer is detecting that there is Fuser cooling fan failure. Check if the fuser cooling fan is installed properly. If it is, check the fuser cooling fan for operation. Follow the steps below:
1. Enter Diagnostics mode.
2. Select MOTOR TESTS.
3. Select Fuser cooling fan.
Does the fuser cooling fan RPM increase? If yes, perform a print test, and if the error continue, replace the printer engine card assembly. If no, check the fuser cooling fan for proper connection.
Nov 30, 2012 | Lexmark W840 Printer
Fridge not cooling properly. Fan not coming on also when put in super cool mode no fan comes on
then its probably a defective evaporator fan in the evaporator coil section of the freezer,if the fan doesn't run it won't move the cooled air and can't cool anything properly
Jun 22, 2010 | Refrigerators
Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Mar 18, 2010 | Refrigerators
Cooling fans dont work
check for cooling fan relays
Dec 26, 2009 | 2002 Chevrolet Impala
Fan error but fan is in there
first u have to go the biso and increse the speed of cooling and also u can remove the fan and clean because the fan is not properly working and and not properly cooling that's why fan error detect. ok u have clean the fan and some setting in bios. i hope your problem is solve
Mar 20, 2009 | Computers & Internet
Problem with cooling and fan on frige
no fan then no cooling!
try to localise the problem by removing the fan and powering it up direct from mains. if it works then problem is not with fan
Jun 25, 2008 | Refrigerators
HP Compaq Cooling Fan Logo
295 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
