Airlink AWLL3026 (AWLL3028) 802.11g/b Wireless Adapter Logo
Posted on Apr 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant find the driver download for the airlink awll3026 i got windows 7 now, and cannot get internet...
Alan Hohenbrink
Level 2:
Sergeant:
Champion:
  • Expert 217 Answers
  • Posted on Apr 07, 2011
Alan Hohenbrink
Expert
Level 2:
Sergeant:
Champion:
Answers
217
Questions
0
Helped
114625
Points
696
Download from this link here. According to their technical announcements the windows XP driver works on Vista and 7. There are 2 variations of the driver but not enough information from your question for me to determine which so download this one first and try it. Although they affirm their driver will work in Vista and 7 I would only install the driver and not the whole software suite. Windows does a fine job managing the wireless connection anyway.
Driver airlink awll6080
You can download driver for your airlink awll6080 from the below link AirLink101 Help Desk DownloadsAWLL6080
Awlh3026 on dell dimension 8300
here's a link at end of this message u can use to read or obtain the 3026 card's manual. or just go to manufacture's site ,,airlink.com, click tab to go to support page and do a search for ur model , then find and download the zip file for the OEM drivers and setup/config utility, extract the compressed file to ur hard drive, be sure u pay attention as to where it is going to be extracted to, then turn ur PC off, power down all the way ,, insert card into the board slot, secure it properly,, restart PC, and when new hardware install screen pops up for the auto detection asking u if u want to install drivers, be sure to click cancel, do not continue with install at this time,,, the window will close,,,then go to folder where u extracted the software files, click setup icon, when it finishes,it will close and restart PC, when it reboots, u should see the Windows lan network connection icon on lower right of screen.. left click it , go to config tab, and remove the default check from box on upper left corner of that window to disable windows from doing any of the card install or config of the wireless connection, Very important**,,, note,,, absolutly no way,, that, both of the utility programs can be enabled or run at same time,, will not work with 2 bosses,, meaning both the airlink setup/config utility and the default windows networking program.,,, this link to read smaller 4 page manual it will explain in detail,,, or u can also locate and download the original larger 20+ page instruction manual at the airlink site as well,,, I just installed same card into a Dell Dimension 8200 last night,,,, had a hell of a time myself,, totally failed at figuring it out per the usual/norm standard installs,, that is,,until I finally did the research,, determined the error was made when initially installing the drivers at detection using the plug n play from windows instead of clicking "cancel" button , as required,,at time of detection of card...then doing the complete install, setup, . and config using only the downloaded OEM Airlink software. Be sure to download the awlh3026_util_drv_winme/xp zip file download that is clearly marked for XP operating systems, two are aailable for xp,, u will need both the drivers and the utility as well as the manual download,,, and only trust software downloads if obtained from the official manufacturer's site ,, heres one set of instruction manual u can go read right now without downloading it to help explain quickly
hope this helps
http://manualslib.com/manual/206893/Airlink-Awlh3026t.html
1helpful
I installed vista ultimate 64 bit on my Toshiba Satellite A205-S5855 T5550 1.83G,3GB,160G,DVD and i need drivers for the internet so i can get the rest of the updates from windows update!!! can u help...
== Easier way ==
DIRECT LINK TO DOWNLOAD
(It's a Windows 7 64-bit driver, but it will work too)
(Vista & 7 uses the same driver)
http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_wifi_atheros_TC00190600E.exe
Download and install the driver
== Harder way ==
* Your driver can be found at THIS LINK
* Select Windows 7 64bit from the 1st drop-down menu.
(I've you select Vista, you wont find this driver)
* Select WiFi from the 2nd drop-down menu.
* Download and install the driver
Atheros Wireless LAN Driver for Windows 7 (32/64)
FEEL FREE TO ASK ME FOR HELP !
Airlink AWLL3025 usb wifi will not work with Windows 7.Is there a way to fix this?
The drivers are only available through XP, http://www.airlinkplus.com/driver/wireless_download.htm .
It might be possible to use the compatibility mode to force the driver to load. To try this, download the driver and right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator.
I do not know if this will work. A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the above site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them.
However, in the case of a wifi adapter, this doesn't help since you will not be able to share the wifi with the virtual computer. You would be better off finding a different brand of wifi adapter that is win7 compatible. See microsoft.com for the hardware compatibility as you look for models: http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
I hope this helps.
Airlink adapter and att router access problems
Make sure you have the most up to date drivers for both your mini usb adapter and your router.
The 64 bit version of windows 7 may not have the right driver for your equipment.
Will get better with time.
Good luck.
20helpful
2answers
I need a driver for Airlink AWLH4030 working with windows 7. The original driver starts error mesages about wlanapi.dll Thanks Rafi
had the same problem(awlh4030). The chipset on the adapter is mfg by Atheros.
If you use the Atheros ar5005gs wireless network adapter driver that comes with windows 7 it works with no problem.
4answers
I cant find video controller driver for gateway cx2610 for windows 7
Gateway doesn't seem to have a driver created for windows 7 The only alternative I could suggest is to try and download one from ATI's website, a Vista or windows 7 driver should work
Need driver for airlink 802.11g ethernet controller.
1. Go here: http://www.airlinkplus.com/downloads.htm2. Click on the device you have3. Download and install the Windows XP drivers
Regards,AbdielPC repair fort lauderdale
28helpful
5answers
Netopia Wireless USB Card
Download this tool driverupdate us and update all of your missing drivers in couple of clicks. I'm using it many years, and it works fine.
take a look
Top Airlink Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Airlink Computer and Internet Expert? Answer questions, earn points and help others
