Question about Xerox 8825 Copier
We received a LL-06 error code on our Xerox 8825 stating needs 'Fuser Oil'. I can not get to the fuser to lubricate it. Is there a secret to opening the lid?
  • 208 Answers
SOURCE: Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Posted on Dec 03, 2007
  • 186 Answers
SOURCE: Xerox Phaser 6100- Error message - "Fuser Error Low Temprature"
time to replace the fuser assembly.
Posted on Jun 21, 2007
  • 2072 Answers
SOURCE: how do ya reset fuser code (H-4) Xc1044 Xerox?
Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Posted on Nov 26, 2008
  • 406 Answers
SOURCE: fuser temperature error for xerox 3100mfp
kindly check externally the fuser is heating or not. i SUSPECT THE FUSER MIGHT BE FAILED.
Posted on Nov 16, 2009
  • 78 Answers
SOURCE: model - Xerox phaser 3100mfp - while installation
could be faulty fuser.or you could remove and re instal fuser
Posted on Nov 30, 2009
Xerox 8850 error code LL-12
I expect you have this fixed by now.
Look closely in the fuser area, perhaps you might see the problem.
Are both fuser rods working correctly one rod has the coils in the middle and the other has them either side so as to even out the fuser temperature. You might need a meter to answer this.
This would need Xerox engineer callout.
Good Luck
Jul 18, 2014 | Xerox 8850 Led Printer
XEROX 8825 CODE LL-90
The error states that the 8825 is over-toned, too dark. The toner dispense and developing systems what the error is pointing to. Make sure your machine is on level floor.
First, Make sure the toner cartridge isn't damaged. Check for a toner. If the cartridge isn't spilling but there is a toner mess around the developer, then your developer may be old, and losing magnetism.
Second, clean the Pressure Equalizing tubes with a vaccuum cleaner, plus the Augers and Magnetic Roll.
You can also check that the sensor wires are connected and that there is not any gear damage, or incorrectly installed parts.
You may need to buy a Developer 005R00310, Main Board 160K75321, or Low Volt Power Supply 105K15863. You might be able to add the developer your self, but everything on this unit is expensive, so you may be better off getting an experienced technician to do the repair.
Whit Item, Inc.
Dec 02, 2010 | Xerox 8825 Copier
Which is better xerox 2510 or 3001?
3001 without a doubt, much more reliable.
Oct 03, 2009 | Office Equipment & Supplies
Receiving an error 920.06 Service fuser error
920 .06 Fuser is not increasing in temperature even though the lamp has been on for an extended time. Fuser page count between 0 and 99,999. • Fuser is not receiving AC power. • Poor supply line voltage.
Jun 16, 2009 | IBM Infoprint 1532n Laser Printer
I have a Xerox Workcenter M20i.
You need to replace the fuser. There is a heating coil in the fuser roller that opens. Replace the fuser and it will resolve the problem.
Jan 25, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox Phaser 7750 code 35
Somehow you jarred the fuser. Turn the machine off and reseat the fuser. Open the left side door, there will be 2 thumb screws.
Remove and reseat the fuser, if that doesnt work you have to replace the fuser.
Apr 05, 2008 | Xerox Phaser 7750DN Laser Printer
251 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
