Question about Kyocera Mita FS-3800 Printer
The check waste toner bottle message keeps showing up,even though its empty
Check toner bottle keeps coming up emptied bottle and still comes up
Posted on Jun 25, 2013
  • 52 Answers
Check that the bottle is also clean from toner residue especially around the top where the lid is.
Use a clean rag or paper towel to wipe away all the toner.inside and out.
This should make the message go away
Posted on Apr 07, 2011
Waste toner bottle full so replaced but will not reset and says still full
then the clear section of the waste toner bottle is not clear some toner is left blocking the sensor that monitors the waste toner level
Apr 02, 2014 | Konica Minolta New Bizhub C25 Color Laser...
I am getting the Replace Waste Toner error on my Ricoh CL3000. I have already emptied and cleaned the waste container, and blew off the section of the printer I install the waste bottle onto, but I'm...
not a solution - but a problem... i emptied the toner waste bottle in my MPW2400 and a new error message appears...says there is no toner and it keeps dumping toner from the new cartridge until it is coming out of every orifice of the machine. What is that about?
Sep 06, 2011 | Ricoh CL3000E Laser Printer
Our imagistics 8130 has the replace waste toner bottle error message on but the waste bottle is empty and I turned a wheel above the waste toner bottle and nothing.
Hi how are you this is jack ... jack_pak@hotmail.com
Dear you wash the waste toner bottle clearly. But error still your copier you check the waste toner bottle dection SENCER OR IS DIRTY CLEAN IT..
PLEASE VOTE ME .
Thanks
Best Regards,
Aug 14, 2010 | Toshiba E-Studio 3511 Color Copier
I dispose of toner and still keep getting messages
I assume when you say you dispose of toner you are emptying out the waste toner bottle and putting it back in the machine. if so here's your problem.
There is a sensor, mounted to the copier, just behind the waste toner bottle (on the upper righthand side). This sensor shoots a beam of light through a small portion of the waste bottle - if the beam is not received on the other side then the copier thinks the waste bottle is full. NOW...even if you have emptied it the interior of the bottle may still be dirty/black enough (leftover residue) to stop the beam from making it through the bottle - this gives you the message. You will need to put in a new bottle.
Jan 23, 2010 | Toshiba e-Studio 350 Copier
Cannon imageRUNNER 3570 - Erroe E000019-0000
You need to clean off the two little soft spots on the neck of the waste bottle. A sensor looks through these soft spots to let it know to replace toner. If the soft spots are dirty then the message will never go away, even though the bottle is empty. If this doesnt help, then contact the seller of the machine and ask for tech service.
Sep 22, 2009 | Office Equipment & Supplies
Where is the waste toner bottle located?
Remove the small cover on the lower left hand side( one screw only) and remove the waste toner bottle and emptied it ensure that bottle neck is not clouded with toner otherwise even the bottle is empty still it will detect waste toner is full .hope this will help
Jul 09, 2009 | Canon imageRUNNER 2000 Copier
Waste tonner tank
The waste toner container is inside the front cover at the bottom right. If you work for a business you should purchase a new one. If not you may be able to empty it into a another container and seal it before putting into the bin.
Jun 29, 2009 | Samsung CLP-510 Laser Printer
I have Canon ir5075 and it asks me to change waste bottle. I empty the bottle. But do not know how to tell the printer that it is empty.
I am not familiar with this model but usually Canon waste bottle has:
1. Check if the waste toner botlle has some clear portion near the neck, (as in IRC3200) or other part of the bottle ,even the waste toner was removed but if this portion is still clouded by toner the sensor will still detect the waste is full
2. If the situation is not like this some Canon Ir machine needs to reset waste toner counter in the service program mode even the waste toner bottle was emptied
Jun 09, 2009 | Canon imageRUNNER 5000 Copier
Check Waste Toner Box message
Clean the neck of the bottle and the black sensor the neck sits in.
Feb 04, 2009 | Kyocera Mita FS 1900 Laser Printer
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
Oct 24, 2007 | Samsung CLP-510 Laser Printer
Kyocera Mita FS-3800 Printer Logo
338 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
