Question about Weber Genesis Silver A Grill
Bought new burners and in stalled front 2 do not let in enough gas and they can not be turned up Back on works fine,
    Problem Solver:
May need to replace regulator?
Posted on Apr 08, 2011
Problem with Dacor Preference RSD30 Gas Kitchen Range
most common issue is burners not placed on proper
may have spider web in tube
possibly bad regulator if 2 large burners lazy,2 small ok ?
Dec 01, 2017 | Dacor Preference RSD30 Gas Kitchen Range
JDS9860AAP Front e-burner does not light.
follow this instructions. God bless you
    • 1
      Unplug your unit and turn off the gas supply at the saddle valve near the unit.
    • 2
      Lift up the hood of the oven. If you have sealed burners, the lid will not lift up. Locate the ignitors near the burners of the unit. Clean any gunk away from the ignitor using a toothbrush. Test the unit.
    • Sponsored Links
    • 3
      Pull the burner dials off the front of the unit if the ignitors won't work.
    • 4
      Remove the screws at the ends of the front cover, where the gas supply knobs are located, using a screwdriver, and remove the cover from the oven.
    • 5
      Slide the wires off the burner valve switches and pull them off the burner valve by sliding the switch forward. The switch will have wires attached to it. Loosen the screws holding down the wires of the burner valve. Pull out the wires carefully. Place the wires in a new switch. Slide the new switch onto the burner valve. Replace the knob, and turn on the gas supply and power. Ignite the burner.
    • 6
      Follow the switch wires into the oven if the new switch doesn't work. Locate the module box, which is usually 2 inches by 3 inches. Slide the wires out of the module terminal by pulling on the wire connectors. Remove the screws from the old module and pull the module out. Insert the wires into the new module, using the same wire orientation as before. Reassemble the oven. Turn on the electricity and gas, and turn on the burner.
Read more: http://www.ehow.com/how_7925141_repair-electronic-ignition-gas-stove.html#ixzz2ZPuc5nad
Jul 18, 2013 | Kitchen Ranges
I am renting a condo with an old Weber Grill - 2 burner / LP (I think it is a Genesis Silver A ('00-01) model . I have very little gas pressure at the burner tubes. - Front tube flickers on/off with...
Yes the best option for just for you is to buy a new burner,tube kit and a new manifold kit because all the things that you said you removed from the burner must have caused alot of rust on the burner and if you keep welding the burner there will still be linkage after awhile so the best thing is just for u replace the burner.
Jan 15, 2011 | Weber Genesis Silver A Grill
Water heater heats water, but not long enough or sometimes not hot enough. The hot water runs out too fast, does not provide hot water continually
The first thing I would do is turn up temp control on gas valve.Control is located on front of gas valve at the bottom front of heater.They usually have a indicator dial on front with an arrow pointing direction.Turn dial to higher setting when burner is not on and this should turn burner on and provide hotter water. The control is normally turned clockwise to increase temperature.If control is already turned all the way up then water heater may need to be replaced.Depending on water quality in your area heater may have a large amount of mineral build up and it may not be capable of producing enough or hot enough water. If this the case all I can suggest is to try to drain tank and flush some of the deposits out. If you have installation manual it will give you instructions on how to do this. If not see if you have working shut off valve on cold water line ,if it works shut it off and connect drain hose to drain valve on bottom right side of gas valve. Put hose to floor drain or sump basin if you have one. Turn control knob on top of gas valve from on to pilot,this will leave pilot light on but prevent burner from working while draining. Open drain valve ,flow rate may be slow or not at all. Open hot water side of some faucet to provide air to help draining. You may try opening water supply valve to heater a few times to aid in draining. If you can get it to drain,shut drain valve off when done,turn cold water supply back on and shut off hot water outlet. Then when tank is full open hot water vavle to bleed air out of heater and piping. Turn control knob on top of gas valve back to on position. This should bring burner back on .It will take about 1/2 hour to heat. If you can't get it to drain or this doesn't help you might consider getting a new 40 gallon heater. Hope this helps. Thanks
Nov 11, 2010 | Reliance Water Heater #6-30-YORT 30GAL NAT...
Back burner won't light on my Weber Genesis Silver A Gas Grill
Only front burner lights (out of three) and it only has flame comming out of half of the tube.
Apr 04, 2010 | Weber Genesis Silver A Grill
Not hot enough!
take it back to the store, natural gas is supplied at 1-2 psi, so its all up to your bbq, sounds like your burner is getting no gas(not much) it should not have a reulator at the hose, this is for propane tamks only
Jun 20, 2009 | Ducane 545 inch 2 - 3 Burner with...
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
JennAire Gas Range - 2 of 4 burners don't light
I had same problem and believe it or not it was caused by a Blue Rhino Propane tank. It was a new exchange tank and because of their "safety" features it would not release a sufficient amount of propane to heat with. Switched tanks and all burners fired up. Have found others on the web with same problem and solution.
PJ
Apr 06, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Weber Genesis Silver A Grill Logo
29 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
