Question about Microwave Ovens
Our GE dishwasher has been working fine for years. Now it is tripping the braker? all wiring is good right to the dishwasher. We did smell burnt wires but it went away.?????
    Problem Solver:
  • 16 Answers
Your dishwasher may be damaged beyond repair. When I installed the dishwasher in my home I found that there is a surprising number of wires bundled under the dishwasher. If you are skilled in that field you can pull the dishwasher out and try to repair the damaged wiring under the machine. However once you've smelled burned wiring it means that there are potentially significant problems in there. You aren't smelling the burnt wires anymore because the damage is so great it's just tripping the breaker. If you continue to try and force the machine to work in this situation you may end up with a fire and further damage.
Please be careful.
Posted on Apr 07, 2011
Burnt smell in microwave
Hi Diane, that happened to me last year my daughter burned popcorn in microwave. I washed it out with baking soda and water, hot water. Then rinse it out good and place about a tsp. of baking soda in a small bowel with a little water set timer for 10 seconds on high power, this helps to nuetrilize the air flow and now you can use it with out any burn smell.
Feb 22, 2012 | GE Microwave Ovens
Microwave smells like burnt wire
When you smell something wire is burnt..The first that needs to check is the inside wiring.You need to open the back portion of your oven to further see whats the problem behind..You can unplug from the source and using a MULTITESTER.Check both terminals setting yuor TESTER to OHMS value.If the TESTERS pointer moves a little it means its not short-circuited ans if otherwise moves to its maximum amount it means it is short-circuited that needs to be repaired..Wiring might have been burnt.If you gonna continue using it it might lead to further complications of defects.Try to check the motor that turns the turntable..check the heating filament.hope this helps.
Jul 07, 2011 | GE JE1640 Microwave Oven
Have a 10yr old ge microwave--was heating up food when it started making a loud bzz noise and then burnt plastic smell came from outside of the microwave and it didn't heat up food. It was working fine...
Yes it is definitely the magnetron and yes you could change it your self if you are good with electronics and tools (considering that the MAGNETRON DRIVER CIRCUIT is OK) but it is normally cheaper to buy a new microwave oven
Sorry!
Jan 15, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave is ge spacemaker model # jvm1650sho5. when microwave is turned on about 4 seconds later it starts making a noise and has a burnt smell. The smell comes from the vent on upper left side and the...
this sounds like the magentron may be going. have you had any issues with it not heating? check your warranty book, some mags have a 3-5 year warranty, otherwise it's probably not worth repairing.
Nov 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Smells like burnt wires
It is very possible it may have burnt wire or burnt capacitor. Remove unit, remove top cover and look inside to see if you see any burn marks or burnt wires. Also check fuse to see if it is good or not.
Aug 07, 2009 | Whirlpool MH1141XM Microwave Oven
Capacitor burned out? horrible burnt smell.
YOUR GOING TO NEED A NEW MICROWAVE . the cap may be bad but the real bad smell you have is most likely the HV tranformer , if the magntron shorts to ground there will be a small smell if you dont pick up on that and your microwave is set to run another few mins the transformer will overheat and burn , then the fuse blows and the controls shut down . the end result , you have more parts bad than you have good . if you google " GE SPACEMAKER MICROWAVE FIRE ' you will see your not the only one , its getting to be COMMON . good luck
Mar 08, 2009 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker XL1800 does not heat. All other functions appear to be working normally, the light comes on and the turntable functions. When turned on, it makes a humming noise slightly louder than normal,...
Possible bad heating element, You should remove the cover of the unit and look at the heating element with the power off. Until you get your problem resolved I would recommend not to even turn it on due to the fact that you are unsure what is going on and you smelt some burnt smell. Just for safety until you fine the problem
Feb 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Burnt smell in microwave from burnt muffin in a GE microwave
Many solutions are found here:
http://www.google.com/search?hl=en&q=microwave+smell+OR+odor&btnG=Google+Search
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 06, 2007 | GE JES738 Microwave Oven
Microwave Ovens Logo
166 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
