I am trying to get rid of the xp home security 2011 virus.
    Novelist:
  • 144 Answers
Hi there!
unfortunately, that virus needs to be removed manually, meaning a local technician. or if you think you're technical enough, you can download and install malwarebytes to remove that virus for you. but you have to make sure you know how to use it to avoid further errors on your pc.
http://www.malwarebytes.org/
Posted on Apr 06, 2011
    Novelist:
  • 107 Answers
1. Check Task Manager for running processes associated with XP Home Security. Press Ctrl+Al+Delete on your keyboard or press the Windows button+R to open the the Run dialog box and type in "taskmgr" then press enter. Once the Task Manager windows is open, check the Applications Running and if you see XP Home Security or any program that you do not know, click on each of them then click End Task. Next, go to the processes tab, check if you see XP Home Security in the list and if you see it select it then click End Task. Also, check for processes that are named in random characters, example "qwertygsdfgrtyhsr.exe", if you see any select each of them then click End Task.
2. Next, look for files associated with XP Home Security and delete them. It usually creates files in these directories:
c:\[random].exe
c:\Program Files\XP Home Security 2011
c:\Program Files\XP Home Security 2011\HS2011.exe
c:\WINDOWS\system32\[random].exe
c:\WINDOWS\system32\winhelper86.dll
c:\WINDOWS\system32\winlogon86.exe
c:\WINDOWS\system32\winupdate86.exe
3. Check the Registry and deleted associated enties, press Windows button+R on your keyboard and type "regedit" in the Run box then press OK. XP Home Security 2011 creates entries in these directories:
HKEY_CURRENT_USER\Software\HS2011
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "XP Home Security 2011?
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run "winupdate86.exe"
4. Delete temporary files, you can use Ccleaner for this. You can download Ccleaner from http://www.piriform.com/ccleaner/download.
5. You need to update your installed antivirus application to have the latest database then run a thorough scan on your computer. If you don't have security software yet you can try Malwarebytes. You can download it from http://www.malwarebytes.org/mbam.php.
6. After the scans finished, restart the PC.
Hope this help.
    President:
  • 1,623 Answers
Manual Removal:
1. Press Ctrl+Alt+Del on keyboard to stop process associated to "XP Home Security 2011?. When Windows Task Manager opens, go to Processes Tab and find and end the following process:
(random characters).exe
2. You need to update your installed antivirus application to have the latest database.
3. Thoroughly scan the computer and any detected threats must be removed. If removal is prohibited, it is best to quarantine the infected item. Manually locating and deleting of malicious files should also be performed. Please see files below that are related to XP Home Security 2011 Virus.
4. Registry entries created by XP Home Security 2011 must also be remove from the Windows system. Please refer below for entries associated to the rogue program. [how to edit registry]
5. Exit registry editor.
6. Get rid of XP Home Security 2011 start-up entry by going to Start > Run, type msconfig on the "Open" dialog box. A windows containing System Configuration Utility will be launched. Go to Startup tab and uncheck the following Start-up item(s):
7. Click Apply and restart the computer.
XP Home Security 2011 Removal Tool:
In order to completely remove the threat from a computer, it is best to download and run Malwarebytes Anti-Malware. Sometimes, Trojans will block the downloading and installation of MBAM. If this happens, download it from a clean computer and rename the executable file before executing on the infected computer.
Using Portable SuperAntiSpyware:
To thoroughly clean a computer, it is best to do a separate scan of another security program so that other infected files not detected by anti-virus application can be remove as well. Download and run SuperAntiSpyware Portable Scanner.
I would like to get rid of Recommended for you Pop-Up messages
You need a proper security on your computer and browser to block them out.
I recommend Virus Eraser (1-877-805-1027) for the computer and will need ad blocker for the browser.
Oct 05, 2015 | Microsoft Windows XP Home Edition
Everytime i try to install norton internet security 2011 on my computer running windows xp it says the program that you try to install has detected as malware and it cancelled the installation..
Seems like you have virus or malware on your computer. Download malwarebytes from www.malwarebytes.org and run a scan. Remove anything that malwarebytes suggest. You should also run a scan in safemode. After you have done this you should try to install Norton Internet Security 2011 again.
Jun 07, 2011 | Symantec Norton Internet Security 2011 1...
My computer has been infected with an advertisement called system tool 2001 how do i get rid of it
You will need to download Malwarebytes at http://dw.com.com/redir?edId=3&siteId=4&oId=3000-8022_4-10804572&ontId=8022_4&spi=5140d1b496d649f9fd6a1753b6b61dfd&lop=link&tag=tdw_dltext&ltype=dl_dlnow&pid=11665648&mfgId=6290020&merId=6290020&pguid=bSHb7goOYI8AAEDK-YkAAAAs&destUrl=http%3A%2F%2Fdownload.cnet.com%2F3001-8022_4-10804572.html%3Fspi%3D5140d1b496d649f9fd6a1753b6b61dfd%26part%3Ddl-10804572
. Here instructions: a) Burn these programs to CD or write them to USB disk (you can use an MP3 player):
Spyware Doctor ( http://www.2-viruses.com/spdoc.exe ) Registry fix : http://www.2-viruses.com/wp-content/uploads/exeregfix.reg to restore normal execution of registry You might want to download Hitman Pro or Malwarebytes as alternate scanners. Though you are likely to be able to download them later on. b) Boot normally. Wait for XP Security Tool 2011 to launch, and run exeregfix.reg . This should allow launching legitimate programs c) Delete or remove the files that are mentioned in our files box. You can use Spyware Doctor to identify the infected files and additional infections. Do not forget update it before scanning. Remove what it finds. d) Scan with Spyware Doctor and secondary tools and reboot your PC. This should fully get rid of XP Security Tool 2011.
Jan 08, 2011 | YouTube Videos
I have a virus and I can't get rid of it because it won't let me download any anti virus programs or restore it to a earlier point
You need the F-Secure rescue disc which will scan and clean your system efore it boots up. You will need to download it on another PC and burn it to disc then boot your PC with the disc. Full instructions and download here
http://www.techmixer.com/free-f-secure-rescue-bootable-cd-to-clean-virus-and-malware/
Apr 24, 2010 | Microsoft Windows XP Home Edition
I would like to know how to remove Parcel win.32
Visit http://www.malwarebytes.org/ and download, install and run their free software. It is capable of getting rid of that trojan/virus.
Oct 27, 2009 | Microsoft Windows XP Home Edition
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
