Question about JVC TH-A25 System
Protection flashing and the system turns off
Hi, I've insert a cd with movie clips taken from camera. When I tryed to play the contnet, the dvd showd it as unknown format. And when I pushed the play button, the dvd turned off. After that I tried to turn on the system, but then I get only the word PROTECTION on the display and the system shuts down in 2 sec.
I unplug the system from the power outlet, and took out the cables from the speakers, left if for 2 days, but still have the same problem.
Could someone, help. Or should I take it to the service. Thanks.
  • apai_v Aug 15, 2008
    when I turn on will have word Protection and then trun off again ,Can not open it alway
    AMM
    President:
  • 624 Answers
You need to take it in for service. I work at an authorized JVC service center and can tell you that you now have a serious problem. It could be the amplifier or the power supply causing it. The protect circuit will activate for several different reasons and only a properly trained technician with the right tools can determain just what the problem is. I don't berlieve that trying to play the disc you mentioned would have any relation to the cause of the problem, it is most likely just a coincidence that it happened at the same time.
Before you take it in, try this.
Unplug all the speakers and then see if it will turn on and stay on. If it does stay on you may have a bad speaker. Turn it back off again and then connect one speaker at a time and turn it back on. If it shuts off in protect when you connect the first speaker, unplug that speaker and try another. If it still shuts off and goes to protect with a different speaker you have an amplifier problem. If it stays on with another speaker it may be the previous speaker is causing the problem, so take it in to be checked. Whenever you connect a speaker and then the unit goes to protect, it may be the speaker that was just connected that is causing the problem. This is not 100% all the time, but it is a pretty good indicator that is worth trying before spending money on a repair.
If the unit goes to protect even with no speakers connected you have an internal power supply or amplifier problem for sure.
Le tme know if you need any more help.
Dave
Posted on Aug 06, 2008
I am not able to remove disc protection
format it useing nokia 6120c,6220,and c5-00 phone.. or view this site= http://www.makeuseof.com/tag/format-write-protected-usb-flash-drive/
Oct 07, 2014 | Electronics - Others
Dvd drawer locked and dvd wont play
Is it a store purchased dvd movie or is it a dvd that someone made and gave to you? Computers sometimes have problems reading cd's and dvd's that someone made. Try a store purchased movie dvd or music cd.
When you press the button on the dvd drawer it does not eject? Clcik Start/My Computer then Right Click on the DvD Drive and click Eject.
If it still does not open, take a Gem Clip (Paper Clip) and straighten it out as much as possible. Then look at the DvD Drawer and you will see a tiny hole that you can insert the Gem Clip (Paper Clip) into. Push the Gem Clip (Paper Clip) while you press the button on the Dvd Drawer and drawer will open. Don't worry about damaging or breaking something, that is why that tiny hole is there.
May 16, 2012 | Computers & Internet
How can i watch video from Samsung s1050 in my computer?
Hi, Here is the procedure on how to play the video clip on your camera. Play mode If you have turned on the camera by pressing the POWER button, you can press the PLAY MODE button once to switch to Play mode and press it again to switch to Recording mode. You can turn the power on with the play mode button. The camera is turned on in play mode. Press the play mode button again and the camera will be turned off. You can set up the PLAY mode function by using the camera buttons and LCD
monitor. Playing back a still image
1. Select the PLAY mode by pressing the play mode button.
2. The last image stored on the memory is displayed on the LCD monitor.
3. Select the recorded movie clip and press the Play & Pause button to play back.
- To pause a movie clip file while playing it back, press the play & pause button again. ac0dd93.png
- Pressing the play & pause button again will cause the movie clip file restart.
- To rewind the movie clip while it is playing, press the LEFT button. To fast forward the movie clip, press the RIGHT button.
- To stop playback of the movie clip, press the play & pause button, and then press the LEFT or RIGHT button. 0e83d9c.png
Apr 13, 2010 | Samsung S1050 Digital Camera
Want to save video clips to a DVD.
can you view the camera on the movie maker?have you selected the correct source in the options set up?go to capture from video device and select your device .good luck farr64
May 03, 2009 | Nikon COOLPIX S60 Digital Camera
DVD movies not playing but CD-ROM games and CD's do?
With the disk inserted, 1) double-click on MyComputer, 2) right-click on the DVD, and select Auto Play from the resulting menu; a window will appear, 3) click on your favorite DVD playing software and 4) check the little box below to do the same every time you insert a movie (as it used to be).
Apr 15, 2009 | E-Machines eMachines Desktop PC
Burning a CD/DVD wil not play in player
Hello drear sir
you have this ploblem because u burn your DVD or CD wrong if u want ur DVD movie play on player u have to burning by (for example if u use nero) DVD video file and it will convert file that a player can play it
Apr 10, 2009 | Microsoft Computers & Internet
Move dvd to movie maker
Finalise the disk in your camera. Run WMM and insert the disk in to the PC's drive. In WMM under "Capture Video" select "Import". Click "My Computer" on the next prompt and then click your DVD drive. That will get you started - use Help to find your way around WMM which allows you to write your edited video to CD/DVD etc. Have fun!
Jan 05, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
My system cannot find the dvd/cd-rm
check in my computer if theres a cd/dvd near with drive C: or D: etc...
if not there, you reboot the laptop and press F2 to bios setup and check the cd/dvd setting if detect,if not, hardware problem...if it is detecting and not showing in windows,theres a virus in the regestry,i think so..try to scan..if not come...format..finish
Jan 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
DVD player won't work for Panasonic SC-HT680
la tarjeta de elcctricidad se me quemo y no encuentro respuesto
Oct 11, 2008 | Panasonic SC-HT680 System
Panasonic VCR/DVD Player
You need to convert the .avi files to the MPEG format with software. Just renaming the file will not work.
May 29, 2007 | Panasonic PV-D734S DVD Player/VCR
JVC TH-A25 System Logo
309 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
