Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
I have a TI-84 Plus Silver Edition graphing calculator. I bought it less than two years ago. Today, while I was graphing functions on the calculator, the screen suddenly faded. The calculator works perfectly, except for the fact that the screen is very light. I have already tried adjusting the contrast, but nothing happened..
    President:
  • 566 Answers
Change the battery
Posted on Apr 07, 2011
Equations
You can't simply enter 7x+9=30 into the calculator, there is a way to calculate what the x is but its been a few years since I've done these..
Oct 03, 2008 | Texas Instruments TI-83 Plus Calculator
Conflicting app error on TI-84 plus silver edition.
When either of them is loaded in memory once, it remains there and takes over the graphing features of the calculator. If one is loaded in memory it must first be unloaded before you can use the other.
To recover the normal calculator behavior both must be unloaded from RAM. Overwrite one by the other, and uninstall the other. That will not delete them.
May 13, 2012 | Texas Instruments TI-84 Plus Silver...
How do i graph an equation on a ti-84 plus silver edition calculator?
1. To graph a function, Press [Y=] to enter the function editor.
2. Type in a legitimate function.
3. Press ENTER to validate the function.
4. Press the GRAPH key to draw the graph.
5. Play with the window dimensions or use the ZOOM feature
to see more of the graph (or less).
Try your settings by drawing the function y= x
If you have problem with Invalid Dimension or other errors, turn the
Statistical Plots OFF.
To do so, press [SHIFT] [Y=] to open the Stat Plots.
Type in the number to the left of the Option PlotsOff. Then press ENTER.
Sep 20, 2011 | Texas Instruments TI-84 Plus Silver...
How do I send my graph from my 84 plus silver edition to my computer?
  1. Install the TI Connect software on the computer.
  2. Connect the calculator to the computer using the Silver Link cable or the USB direct cable.
  3. Run the TI Connect software and let it recognize the Calculator.
  4. Once this is done, create the graph on the calculator, and click the screen capture button in TI Connect.
  5. Save image in jpeg format.
  6. Send it to the printer to print or insert it in a text document which you then print.
Dec 15, 2010 | Texas Instruments TI-84 Plus Silver...
My TI-84 Plus Silver Edition Graphing Calculator continues to read "ERR: INVALID DIM" whenever I attempt to graph equations.
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Dec 04, 2010 | Texas Instruments TI-83 Plus Calculator
I can't select more than one function to graph It only will let me select one function
In order to select additional graphs, the Transformation Graphing Application will need to be uninstalled from the TI-83 Plus Family and TI-84 Plus Family.
More information regarding this matter can be found in the Knowledge Base. The Knowledge Base can be accessed by clicking on the URL below:
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=65121&nUsePub=NO&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZG14E1108A3A0CD3ABADCD67260B59BDE0CEEA20790F80F708D8A4FDACCD82D31F792BC1B01D2F67ECAE6718104B82CC1C8F
Apr 09, 2010 | Texas Instruments TI-84 Plus Silver...
How would you enter the following equation to graph on a TI-84 Plus Silver Edition calculator? 2 <= t <= 9
To enter the inequation you split it into two inequalities
Graph is as follows
Use [2nd][CATALOG] to access the relaional operators less than or equal, greater than or equal, and the operator AND.
To access the inequality signs scroll upwards from abs( to reach the bottom of the catalog.
Note: You can use t as variable only in parametric graphs. Use x.
Hope it helps.
Oct 19, 2009 | Texas Instruments TI-84 Plus Silver...
Graphing
Hi, you can try uninstalling the transformation app in your calculator. This does not really uninstall your application, it only prevents it from interfering with it. You should be able to graph multiple functions after that.
1) Go to APPS
2) Press Transfrm
3) Click Uninstall
Mar 04, 2008 | Texas Instruments TI-84 Plus Calculator
Graphing trig functions
Put the calculator in radian mode and it will graph trig functions just fine. If you don't know how to change it to radians, then go to mode and cursor over to select radians. I am assuming you know where the sine, cosine, tangent, etc. keys are.
Dec 31, 2007 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
293 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
