Question about Baby Lock Esante
Lcd screen has lines in it and can't read. It is straight sewing fine, I just can'tread screen.
  • 5,370 Answers
The lcd screen gets power from main board.At the back of the LCD screen there is a ribbon cable.That cable is communication between screen and control board.If this cable gets loose or if the cable is getting shorted then, this problem can occur.The lcd screen front panel has to be removed out.Then this ribbon cable connection has to be checked.This cable is is a plug in cable.You can just pull the cable out from lcd screen.Check the cable and reconnect it.Keep the machine unplugged, while doing this.Then see.If the same problem is there, then the other end of the cable, which is connected on main control board is causing the problem.For that the machine has to be disassembled, to reach main control board.If the cable is checked ok, then it can be problem with lcd screen itself.But in most of the cases, the ribbon cable gets loose or shorted.------ Check out.This should help.Keep updated.Thanks.Helpmech.
Posted on Apr 06, 2011
Requesting support: juki HZL F6000 suddenly stopped sewing straight stitching in a straight line. Also stopped automatic treading.
the machine may need to be serviced, the needle bar may need adjusting, also could be something wrong with the motherboard
Dec 08, 2014 | Juki Sewing Machines
Why is it not sewing, it's treaded right the bobbin is wound right, but it does not work
THREADING a machine can vary from machine to machine. THEN the kind of and quality of the thread will make a big difference. Don't stop with the cheapest thread. Make sure it has poly cotton instead of straight cotton. Some wear the fibers and they fall into the threading mechanism area. Resulting in having to have it taken apart.
Aug 30, 2014 | Sewing Machines
My singer 4423 wont pick up the bobin tread
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is inserted correctly into the bobbin case
if these suggestion don't help,,then the machine needs to be
checked by a sewing machine technican to see if it's out of time
Jul 31, 2012 | Singer 4423 Sewing Machine
Need LCD screen for Baby lock esante sewing machine. Anyone know where I can find one?
When your BabyLock Esante ESi2 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the BabyLock Esante ESi2 LCD screen, or buy a new machine. BabyLock no longer stock this item direct, but there is an affordable replacement available....Check this Link
Oct 19, 2011 | Sewing Machines
Zig zag problems
oh my i think you need to open your machine sir. i already tried it. kinda hard to explain it here
Sep 05, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
44 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
