Disconnected start and reset leads at the motherboard and they are marked but the mb is not need to know where to hook them back correctly
  • 60 Answers
You must download the manual for your motherboard to do this. Find the model number and manufacturer. It is printed on the motherboard.
Posted on Apr 07, 2011
Wont power up
My wont turn on too, There is a orange light on the tower, Green on the left, Battery ovel, If I push the restart button, also switch the power supply switch in the back, also unplug from it, Sometimes does it, Do ou know whats causing this to happen, Please let me know Thanks
Jan 26, 2013 | Asrock K10N78M Motherboard
I have disconnected all th ewire from my motherboard and i have installed all wire but unable to connect pw button,reset button,HDD led wire and anothed LED wire please tell me how can i install them in...
Locate the case connector pins on your motherboard. This will be a bank of two rows with 10-12 pins in each row. Each pin will be about 1 cm in length.2 Locate the power lead behind the power button on your computer case. The lead will consist of two thin wires, usually white and black, held together by a small plastic cap.3 Examine the underside of the power lead for an arrow or dot. If one is present, the marking signifies the first pin. This must correspond with the first pin on the motherboard, which will also be indicated by an arrow, dot, or number. If no markings are present, the lead can be installed in either orientation.4 Place the lead over the power pins within the pin bank. The correct pins will be indicated by a diagram on the motherboard, or by a picture in your motherboard's instruction manual.5 Connect the power cable to the back of your computer, and turn the computer on.
  • Oct 14, 2011 | ASUS P5PE-VM Motherboard
    I have a HP m7388a PC and the mb is faulty (video card doesnt work) (i tried it with a similar card and still didnt work) I dont want to buy a different mb as it will probably result in me having to...
    you should not think about replacing the motherboard until you have exhaused all of the troubleshooting on your computer
    Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers also
    One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
    Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
    the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
    Apr 10, 2011 | HP Puffer2UL8E (51883631) Motherboard
    Problem with the EliteGroup ECS A790GXM-AD3 AM3 AMD 790GX HDMI ATX AMD Motherboard Help please, no power What is the recommended Power Supply Wattage for this MB i am using a Diablotek 550 Watt. I checked...
    Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
    One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
    the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
    make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
    hope this helps
    Dec 15, 2010 | EliteGroup ECS A790GXMAD3 AMD 790GX MB w...
    Biostar MCP6PB M2+
    Hi.
    You can download a manual from here
    Make sure you have the 4pin connector for the cpu plugged in as well as the main power lead.
    Disconnect any other wires you have put on.
    Look for the block of pins (usually marked Panel) on the opposite corner to where the keyboard plugs in.
    Pins 15 and 16 are for the power switch 15=+ and 16=Ground.
    Best of luck.
    Please rate this solution if it was of any help. Thanks
    Feb 02, 2010 | Biostar MCP6P-B-M2+ & AMD Sempron LE-1250...
    PC Chips M756LMRT+ PII/III/Celeron Slot1/Skt370 mATX MB Motherboard, put this into new tower and having trouble with connecting the PW SW,HDD LED, PW LED and Reset SW back to board in the correct position...
    I have the same problem! The PW SW, and Reset SW can go either way round. The LED leads do need to be correctly placed. If there has been any doubt in the past I have tried each way until one way works - this has never caused me any problems. One tip is that usually the marking on the connectors all face the same way.
    Oct 29, 2009 | PC Chips M756LMRT+ PII/III/Celeron...
    I purchased an AMD MCP61PM-AM MB SND/VID/LAN motherboard and need to know where to plug the LED,speaker, power switch and reset power supply into the motherboard. DO YOU HAVE A DIAGRAM OF THE MOTHERBOARD?...
    Hi there.
    Get a strong flashlight and a magnifying glass (if you have one). On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW. On some boards there are no colours but the markings are the same, so a good close look.
    Have a look at these pictures for an idea >>>>>>
    Please post back with the results and any more advice if needed.
    Good luck and thanks for choosing FixYa!!
    Aug 14, 2009 | MSI K9A2 Platinum Motherboard - AMD790FX,...
    Power switch & reset switch hookup
    This should be your manual:
    http://dlcdnet.asus.com/pub/ASUS/mb/socketAM2/M2A-VM/e2975_m2a-vm.pdf
    Page 1-32 Has your connections.
    Hope this helps :)
    Mar 08, 2009 | ASUS M2N-MX Motherboard
    Dead new motherboard
    Are you using a 24 pin or 20 pin power supply? Can you confirm the power supply you are using does indeed work?
    Mar 06, 2008 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
    Computers & Internet Logo
    11 people viewed this question
    David Payne
    David Payne
