We bought a new fin but can't get it back in the drum
  • Washing Mach... Master
  • 8,220 Answers
Remove or pop the top. Once that is raised then you can install the fins easily.
Posted on Apr 06, 2011
One of my dryer fins fell off how to get it back on
Look inside the drum at the place where the fin was on the drum.
Do you see any screw holes now showing?
That will tell you that you need to take the machine all apart and re-fasten the fin on with some screws, unless the holes are stripped out in the fin itself, in which you will need to get a little bigger screws, or buy a new fin.
Oh yes, I have been using an epoxy cement in a tube that has 2 chambers, and this may help you.
I think it would work here, but will not be strong enough to glue the fin back on.
I sort of think it would stand the heat if you used it to help secure the screws into the fin.
Honestly, to me the new fin sounds " hard to get".
Be blessed.
Feb 03, 2013 | Maytag Neptune MDE5500AY Electric Dryer
How do you replace the plastic fins inside the drum
You pop the top and use a screwdriver to put the fins back.themobilian_3044.jpg
See the spring clip? Use a putty knife to release the top
Then you can open the door and hold the fin inside while you use a screwdriver to put them pesky fins back in there.
I wrote a page on these
Frigidaire/Gibson/Kelvinator/Westinghouse Dryer Pixthemobilian_3046.jpg
Oct 20, 2011 | Frigidaire Washing Machines
Fin that tumbles clothing inside dryer coming loose, how can I tighten it?
These fins are usually screwed on from the outside of the drum. If you're up to it this is a simple but time consuming fix. Take the cabinet off the front of the dryer, the top will come off as well. be careful of the wires from the control console, they will stay attached to the dryer. Tighten the tumbler fins on the drum and then re-assemble the cabinet. Typically the screws you need to access are the same used for the door latch and hinges. They go back together easy ........
Feb 14, 2011 | Maytag Neptune MDE7500AY Electric Dryer
What is the part on the inside of dryer door with the seal around it called and can you order it
Im not exactly sure which part you are talking about, but if your referring to the actual container that holds the clothes its called the drum. If your talking about the small plastic pieces that stick into the inside of the drum those are called fins. If you need new fins, you cannot order them separately you will need to replace the whole drum. So in either case your getting a new drum. Most appliance part stores don't carry such a large item in stock but you may get lucky and the store can usually order one as long as you give them the model number of the machine.
Dec 13, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag 3000 series dryer, coins stuck in dryer fin
open the top of the dryer. slide the belt down to the power unit. of course you shoudl always unplug the unit first before removing the cover. carefully lift up ont he drum and they shoudl fall out. carefull y palce the drum back and the belt. replace the cover and plug in to see if that works.
Dec 04, 2009 | Televison & Video
The plastic fins inside my frigidaire front loader are trapping soose coins and a key i need inside the hollow fins. I guess in the spin mode just enough space opens up to let them in? How do i remove the...
take off the back of the machine. It will give you access to drum. There are screws to loosed. Go the PartSelect.ca and type in your modle number. You will be able to look at a diagram on how they are removed.
Dec 02, 2009 | Frigidaire GLTF2940ES Front Load Washer
Dryer fins coming loose
Unplug Unit.
Refer to pages 5-2 and 5-3 of the manual below to see how to expose the drum by lifting the top of the machine. Then turn drum very slowly and only until the screw holes for the missing fins are within your reach. Most of these dryers have two sizes of fins make sure you order the right one if you need to replace them.
Good Luck
Download this file : Maytag Dryer
Sep 07, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Loose Tumbler Fin In dryer
most maytag dryers have push type clips that hold the top to the front. look between the top and front with a light and find them about 3-4 inches from the outer edges. once you get the top up then there will be screws that hold the drum baffles to the drum. just put a new screw in them and all will be ok. no need to replace them, just use new screws.
Dec 31, 2008 | Maytag HYE3658AY Electric Dryer
Replacing the a drum "fin"
you should be able to Open the top of the Dryer, from front to back, U might need to pry the front corners up with a flat tip screw driver. It should hinge to the back, to expose the Tub... Hope this Helps U...
Sep 20, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
Replacing the fins on Duet whirlpool washer
most paddles are removed by grabbing hold of the paddle and pull towards the front of the washer which should release them youll need to lift it out when you have pulled on them love
Sep 12, 2007 | Washing Machines
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
