Question about Cell Phones
I have a samsung A 887 actually is in line 2 i need to change it to line 1 what can i do i can receive calls but i can not call nobody i need help thanks
  • 2 more comments
  • flyaway10 Apr 07, 2011
    I have a samsung A887 the problem with it is in line 2 and i want to change it to line 1 , i can receive calls but i can not calling nobody what can i do i need help thanks
    The codes you gave me dont help at all have you other solution?thanks
    I have a samsung A887 the problem with it is is in line 2 i want to change it to line 1 i dont know how to do it i can receive calls but i can not calling nobody i need help thanks
    Sorry my friend i did what you told me but nothing happen, my phone still has the same problem, have you another solution? Thanks
    President:
  • 3,278 Answers
Hello.
From Samsung Support, to reset phone:
1. From Idle mode, touch - Settings - Phone - Reset
Phone.
2. At the Continue prompt, touch Yes to reset, or No to
cancel.
3. Enter your phone password, if prompted and touch OK.
4. After the phone settings have been reset, the Reset Phone
done confirmation displays.
Once your phone has been reset to its default settings for those selected options, it will restart itself in order to
incorporate the new settings.
If you have already performed the above, please provide how you are aware that you are using line 2, instead of line 1 - what specific message or code.
Hope this helps.
Posted on Apr 08, 2011
  • 438 Answers
If you go to Settings->Network Services. Here you will find an option to change the Lines. 1 to 2 and 2 to 1. Do that and call happily everafter.
Posted on Apr 07, 2011
  • 2,069 Answers
Backup and then factory reset using this code *2767*3855#. this should restore the default settings which are also line 1 by default.
Regards
  • Muzahura Frank Apr 08, 2011
    ok, did that code react in any way.. no rebooting no nothing? Use also *2767*2878#.
    You may also get your phones user manual from here. go to page 62, you will see guidelines on how to reset that phone using its menu. as a default setting, on resetting, its always line1.
    Thanks for using FIXYA
CO 1 cannot call out or receives incoming.
Panasonic KXDT321 Phone
Conference call Call party 1 and speak
Press transfer
Call party 2 (press 9 for outside line if needed)
Party 2 answers
Press transfer then 3 speak to all three people
Repeat if required
Jan 24, 2014 | Panasonic KX-T7731 Corded Phone
I have 7 incoming lines, I can receive calls on all seven, but I am not able to make outbound calls from any of those lines. I have 6 extensions, out of those six extensions only one is able to make and...
Do you have actual appearance of each line, or just a placement button for calls received, a Call Arrival key, or car key. You can't grab a car key to make a call, the outgoing calls just land on them after you dial 9 or whatever the code is. Anyway, that would have to be changed in system programming, an actual tech would have to look at that. Or the phones are restricted and need a code entered to bypass the restriction. I have no idea how those codes might be set up.
Oct 09, 2013 | NEC Electra Professional ETW-16DC-2
Line 2 on samsung b3410
try line 1 if also same prob
Sep 07, 2012 | Samsung B3410 Cell Phone
Samsung prostar 816 plus system ringing problem
sounds like your having a couple of problems at the same time. the lines only ringing at station 1 is the default setting of the system my guess is that the time and date are also way off if thats the case.
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished.
next, the problem with the cordless not working has to do with the port programming, in default it assigns all ports as multiline sets.
To assign a SLT(single line telephone) port to the system while still in program mode dial #38 the screen should say slt dial type and then 16 0's.
0 = keyset 1=slt set
enter in all 16 digits followed by the # i.e.if your cordless is on port 7 it would look like 0000001000000000 #
lastly the phone that can no lnger recieve calls sounds like the do not disturb or DND has been pressed to stop the alarm from ringing. press the mute/dnd button (light should be off). to cancel an alarm press the ALM/SD button twice and then the hold button.
hope that helps out.
Mar 05, 2009 | Samsung Prostar 816 Phone
2 line phone rca 25205re1 only 1 line works not the rollover line
Most likely the problem is the cord from the wall to the phone. There are two types of cords and they look almost identical. Look closely at the connector. A single-line cord will have only two gold pin at each end. A two-line cord will have four gold pins at each end.
You need a two-line cord to get both lines from the wall to your phone. Since you have had the problem with several phones, that is the most likely cause.
Jan 14, 2009 | RCA 25205RE1 Phone
Unable to send txt msg with pictures on SGH-U600 unlocked!
Goto this website:
http://uk.samsungmobile.com/supports/supportMain.do?&menuIdTop=00000000000003
On the left hand side under configure phone it says WAP and MMS settings
To send picture messages it is the MMS settings you need
Click on the MMS and follow the instructions
Apr 28, 2008 | Samsung SGH-U600
Group forwarding after a delay
In memory block 4-1 for the extension's port, The Lkey for the CO line is lit green for immediate ringing, red for delayed ringing, and off for no ringing.
In memory block 1-1-77 you enter the CO's delayed ringing timer in seconds.
I wouldn't try and deal with seperating into tenants.
What I would suggest is in 4-19 restrict outbound trunk access (corresponding Lkey for CO line is lit to restrict)
For example:
Stations 1-4 would not be allowed to dial out on CO lines 5-6
Stations 5-6 would not be allowed to dial out on CO lines 1-4
This way Company A is not tying up Company B's CO lines for outbound calls and vice-versa.
Apr 09, 2008 | NEC Electra Professional ETW-16DC-2
Denon avr 887 input problem
Sell it on Ebay and buy a new 2309.
Mar 04, 2008 | Denon AVR-887
Motorola v3x...........nobody can ring my phone
The problem is because some how your phone has been set for Line 2. You can fix it by again changing it to Line 1. The option you can find under setting>Call setting menu
Feb 03, 2008 | Motorola Mobility RAZR V3
Cell Phones Logo
83 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
