Question about Lexmark T652DN MONO LASER PRINTER All-In-One
Keeps showing 900.57 firmware error and the paper gets stuck
    Genius:
  • 1,087 Answers
Power the printer OFF and ON. Send the same file to the printer, if file has not been released from the print queue then delete all pending print jobs out of print queue.
Disconnect all data cables and power the printer OFF and ON. If the printer returns to READY, Reconnect the data cable and try printing again. If you are getting a paper jam error, please take not the error code and locate the jam. For further assistance, please contact Lexmark Technical Support.
Posted on Jul 14, 2011
Hp z2100 paper jam but no paper jam
If you have both firmwares as files, then yes you can downgrade, but be aware that some changes in firmware are not reversible as they reprogram hardware. Keep in mind that this product is classified as EOSL (end of support life) which means HP no longer provides support or spare parts.
Jan 24, 2015 | HP DesignJet Z2100 InkJet Photo Printer
I have a 5650 lexmark printer and it keeps saying paper jams but there is not paper anywhere.. how can i find a solution... when you load paper it keepps getting stuck.. help
There could be something blocking the paper path. Try to shake the printer upside down. You'll be amazed of the things that falls off inside the printer. Also, make sure that there's no paper left inside the printer. Tiny pieces of paper will still lead to paper jams.
May 31, 2012 | Lexmark X5650 AllInOne InkJet Printer
HP color laserjet 3000n error 49.4C02
Thank you for the inquiry.
49.4C02 Error The 49.4C02 error usually follows a paper jam. When the customer closes a door after clearing the jammed media from one area of the printer, the control panel immediately posts a 49.4C02 error. Often, the customer will then power cycle the printer and it will hang at Checking Printer. For the 49 error to occur, additional media must still be stuck in the paper path.
Firmware version 5.005.3 contains a fix that allows the printer to recover and notify the customer of the location of the additional jammed media in the paper path. Customers who experience this issue should update to the newer firmware. This version of firmware also fixes the issue with the printer hanging in Checking Printer.
Since a paper jam is the event that triggered the 49 error, if paper jams continue, troubleshoot as necessary.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 11, 2011 | HP LaserJet 3000n Printer
My copier keeps showing an error: remove paper from output tray but there isn't any paper there? How do I proceed?
on the output tray you will see sensor flapper... it can get stuck ed... try to manually lift or down it, it usually gets out of his holder.
Keep me posted,
Hope that help's!
Nov 18, 2010 | Canon imageRUNNER 4570 Copier
HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Jun 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Paper jam showing when no paper in the printer
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 06, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
Machine says there is a paper jam when there is no jam. Shows jam in exit but the paper never even starts to get picked up from the main paper cassette but it will feed fine frome the mp tray. any...
Dec 08, 2009 | Samsung SCX-6320F All-In-One Laser Printer
Keep getting a service error 5100 notice
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Oct 21, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Have a samsung ml2150 which keeps saying paper jam 2 i can see no paper stuck anywhere any ideas please paulmcfc
Inside the printer,there is a sensor which detects the paper.if something is still stuck in between the sensor or some dust is set between the sensor can make the printer feel that paper is still stuck-ed up.
In that case it will keep on showing the paper jam.to solve this issue,you need to open up the printer and clean the sensor assembly gently.once its done it will no more show paper jammed error.
thanks.
Aug 31, 2009 | Office Equipment & Supplies
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
Lexmark T652DN MONO LASER PRINTER All-In-One Logo
3,530 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
