Question about Panasonic Microwave Ovens
Hi..I have a Panasonic NNV672 Inverter microwave oven. It is about 9 years old. When I start the operation it goes for about 22 seconds and then switches itself off. It seems to do this whatever setting it is on.
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic microwave 1200
This model uses an inverter to produce high voltage. That symptom is an usually indication of a problem with the inverter or a bad magnetron. I do not recommend that a person without training and experience ever work on these models. You should be able to locate a Panasonic-authorized servicer here: http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1 I would mention the exact symptom when you call so the technician can bring a new inverter with him when he comes out to repair it. Might save you having it pulled into the shop. Good luck!
Posted on Sep 22, 2007
SOURCE: PANASONIC INVERTER MICROWAVE, 1300 WATTS
  1. Same exact problem
  2. I've noted 3 different ones with the same problem
  3. Panasonic has produced a lemon, north fixing
Posted on Apr 11, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: panasonic inverter dimension 4 microwave
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Sep 06, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Microwave Oven Stops After 15 seconds - Never Heats
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
You can order Panasonic parts from Tritronics.
If you reconsider, you can find an authorized Panasonic servicer here.
Posted on Oct 22, 2008
SOURCE: Panasonic Microwave NN-A770S getting hot on right side externally
Is it normal for a Panasonic nn-c994s to cycle the fan/inverter
when using combination cook?
16 sec off 6 sec on.
Everything else seems to be working
light, timer counting down, heating food, turntable turning
Posted on Jul 17, 2009
Microwave stops after 22 seconds
Not sure what the problem is but I have exactly the same fault with mine. Apparently it's either going to be the inverter, the magatron or both. Cost approx £120 inc callout.
My advice: Get a new one!
Feb 19, 2010 | Panasonic Microwave Ovens
Panasonic NNH965BF microwave starts but immediately shuts off
your mag has gone bad and possible that the inverter board as well, not really worth the hassel
Feb 06, 2010 | Panasonic NNH965BF Microwave Oven
Panasonic Microwave only works for 37 secs no matter what time setting
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Jan 04, 2009 | Microwave Ovens
Panasonic Microwave Problem
Even though these are different symptoms, the same part may be causing both.
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Sep 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Model 72180883400
F-9 error code indicates a defective control board, inverter or line voltage too high. f the microwave runs for about 7 seconds with a ticking sound..then stops and shows "F-9", it is the magnetron that has failed. The fact that the unit starts and runs with the TICKING SOUND means the control board is sending signal to inverter board and the inverter board is sending signal to magnetron. Magnetron is covered by full 5 year warranty, inverter board is only 3 years.
Sep 01, 2008 | Kenmore 62702 Microwave Oven
Hi there, I have a panasonic microwave which is a few years old now. The problem is that it goes for about 20 secs then stops, the display returns to the time and the light in the microwave goes out....
22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 30, 2008 | Microwave Ovens
Panasonic NN- A712 combination Microwave 1000w - Switches off after 20 seconds
The 22 seconds is the giveaway.
Jul 14, 2008 | Panasonic NN-S753 Microwave Oven
Micro wave operates for a few seconds then shuts down, light goes out, but fan continues to work
The oven will also strop after 22 seconds if there are certain problems with the inverter or magnetron.
Jul 13, 2008 | Panasonic Microwave Ovens
Runs for 30 seconds then goes off. No heating
Is it 30 seconds or 22 seconds?
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 04, 2008 | Panasonic NN-S254BF Microwave Oven
1200w Genius microwave, about 4 years old. Has been working no problem until today. When I press start, its starts ok but cuts out after 23 seconds. It does this on every setting.
The 22 seconds is the giveaway. In most cases, this is a problem with the inverter or a bad magnetron.
May 20, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
60 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
