Question about Acer Aspire 5100-5022 Notebook
Aspire 5100 HI I have an Aspire 5100 I was having trouble connecting to my printer so I reinstalled the printer software and drivers. The computer was fine until the next time I tried to turn it on. Now it won't load. It goes to the Acer screen and then the windows xp screen with the loading bar, but it doesn't load and just goes back and forth between those two screens. I tried loading in safe mode and that didn't work either.
  • durskelief Aug 18, 2008
    notebook only go's to windows...en wont startup the system....alt f10 wont work...safe modus don't work..f2 don't work ether
    hope you will understand me my english is very bad..
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 86 Answers
Sounds like both of you have what is called 'Microsoft Blue Screen Of Death' and is irreversible, but is fixable at the same time. If you need files on your computer then follow these instructions
  1. Turn on computer and Insert Windows XP Installation Disc that came with your computer
  2. Wait until it says 'Press any key to boot from CD....' and press any key
  3. Wait until it comes up with prompts and choose 'Install Windows XP
  4. Choose to install XP without formatting the hard drive and choose a made partition (C Drive) to install NTFS
  5. Install and now your system will be working again. You will be prompted from now on though which Operating System you would like to use. Always select the first one
  6. Enjoy
For if you want to erase the hard drive
  1. Follow steps 1 - 3 in above instructions
  2. Choose 'Format Hard Drive'
  3. Select create partition in Hard Drive and set it to the maximum space and call (C)
  4. Select NTFS and go through instructions
  5. You won't be asked to choose a OS as there is only one to choose from
  6. Enjoy
Hope This Helps
Posted on Nov 22, 2008
Cant open webcam
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or
update driver
hope this helps
don
Feb 21, 2011 | Acer Aspire 5100 Notebook
Aspire 5100 will not connect to wireless network. -------------------------------------------------------------------------------- I am using an Acer Aspire 5100. I formatted both drives and reinstalled...
http://driverstock.com/Acer-Aspire-5100-driver-download/4-21-12867/index.html
so ..my advise is to reinstall the windows xp ...cause this machine it was on xp from the first ...and this might be just the reason ..those are the drivers for it
also ...you can download Everest software ...and locate the exact name of the wifi platform ..and look after that for a vista driver for it by its name ......this way you cant be wrong ...cause you locate the suitable driver ...not the ones they feed us in packages...
Jul 18, 2009 | Acer Aspire 5100 Notebook
Computer won't recognize new Lexmark X9575 printer
Are you conecting via USB? If so, did you wait to connect the USB cable until the installation advised you to? If not, uninstall the software and driver, unplug the USB cable, reinstall the software and driver, and when prompted, plug in the USB cable.
May 18, 2009 | Lexmark X9575 InkJet Printer
My camera on computer is not working
actually the vista supported drivers might not be installed ,run malawarebytes to find infection also check for services in services.msc and enable it
May 08, 2009 | Acer Aspire 5100 Notebook
Acer notebook usb not recognized
Sounds like a hardware issue. I would guess that there is a bad connection between the usb's and the motherboard. If you are comfortable dismanteling the laptop and re-soldering the usb's than give that a try, but I would recomend you give it to a pro.
Here is a link that explains the process. http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
Jan 17, 2009 | Acer Aspire 5100 Notebook
Installing driver for HP Deskjet 1520 on Acer Aspire with Vista
i recommend an uninstall on the printer software..update the operating system with all known bug fixes, then download a fresh driver set..
Nov 21, 2008 | Office Equipment & Supplies
Installed with enclosed disc
Looking at the setup guide, it does indeed tell you to not connect the usb cable until prompted by the software. It is Step 7.
Here a link to the setup guide:
Kodak 5100 AIO Setup
Kodak Support has step-by-step instructions for uninstalling and reinstalling the software. Just make sure you remove the USB cable from the computer and reboot before you reinstall.
Here is the support page to begin on:
Kodak Support 5100 Reinstall
Comment back to let me know how it went.
Nov 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Acer aspire 5610z orbicam
Better to reinstall the webcam drivers and check it.After installation,First u restart laptop.
Thanks
Feb 29, 2008 | Acer Aspire 5100 Notebook
My Acer aspire 5100
If you are able, when the pc is booting up keep pressing F8, this will take you to safe mode and not allow the graphics driver to run. When in the safe mode options, select either Last known good configuration or start windows in safe mode. Last known good configuration should find the last good system settings, when it reboots. Start windows in safe mode allows you to go into windows using the administartor account, and then you should select system restore and restore back to the day before or just before you updated the graphics driver.
Aug 16, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100-5022 Notebook Logo
108 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
