I HAVE A POULAN/WEED EATHER MODEL PP446ET 711882 545-132201 2007 CARB/US EPA PH2 NEED HELP ON THE FUEL LINES ONE IS LARGE AND ONE SMALL LINE.CAN YOU E-MAIL ME A PICTURE ON THE LINES WITH THE PRIMER BULB.ALSO THE CARBURETOR HAS TWO INLET WHICH IS THE INLET THANKS,AL
4 Suggested Answers
  • 149 Answers
SOURCE: poulan 2150 w/ walbro wt324 carb fuel line reassembly
the fule line that comes from the filter/ pick up will go straight to the nipple usualy the one closest to the middle of the carby.
the other hose comes from the carby to the in or **** side( punp it you can feel it)of the primer and then goes to the tank that is the return/ prime, nothing is conected to it in the tank. if you have the carby one the wrong way around it will not prime. just swap them over..
Posted on Jan 12, 2009
panilling9
  • 284 Answers
SOURCE: Which fuel line "port/inlet" on the Walbro wt-380
Usually the line with the filter on it that comes from the tank goes to carb. inlet first which is most likely close to the bottom side of the carb.nearest to the engine,then the outlet or return line on the carb.goes to the inlet side of the primer and the outlet side of the primer goes back to the tank. The primer draws fuel through the carb to the primer to the tank if its not? then correct the line connections until it does
Posted on Jun 25, 2010
  • 2239 Answers
SOURCE: Poulan Woodshark 1950 14" Chainsaw Family: WPWES
Checked all the parts lists, they seem to use the same primer through all types no.s part no. 530047213.
Posted on Jun 24, 2011
Jun 24, 2011 | Poulan Garden
I have a Polan Model 2375 Wild Thing Chain Saw. The fuel lines have deterioated and I need to know correct routing of fuel lines. The primer bulb has to line connectors, one small diameter and one large...
A Poulan IPL for your saw “2375LE Gas Saw Type?” (LE is code for WildThing; if your saw is beyond serial -2 look at a saw without the LE; it makes little difference to the fuel system) can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
  • Small hose (filter on bottom) long enough to reach all corners inside tank, to lower carburetor connection. Please leave the 2 carburetor connections long enough to reverse until the saw is running.
  • Upper carburetor connection, small hose to suction side of primer.
  • Pressure side of primer (large hose) to tank fitting.
The IPL is deceptive it appears the filtered hose connects to the primer; it does not.
A typical fuel system and suggestion or 2 follow:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 19, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a poulan pro 210 chainsaw both fuel lines has rotted off standing behind the saw to the right of the carb there is a large hole in the tank to the left there is a smaller hole, it has a primer bulb...
This should help:
This too:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
Poulan.com
I think this is your saw please ensure I am correct.
http://www.ordertree.com/modelinfo/PWE/PP210-Gas-Saw/75.PP210-Gas-Saw.1.59.1.html
If not your saw it can be found here:
The dash number of your serial number is the type. HTH
Lou
Take some pics first then a small sample of the different fuel lines to your local chainsaw seller. A little extra is agood idea, I have not found a good fuel line stretcher and I have been looking. Probably a good idea to replace the fuel filter too.
Jan 16, 2010 | Poulan Garden
Starts but will not run
its a fuel issue. check fuel lines and fuel filter. If fuel lines are discolored or brittle or if filter has become unattatched from line- the fuel lines need replaced. Then carb needs adjusted ( turn low speed jet out 1/2 turn) or rebuilt
Nov 22, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan leaf blower won't start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Sep 26, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan weed whacker
Youwill need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Just let me know.
Jim
Sep 01, 2009 | Poulan Garden
I have a gas powered trimmer Model#GTI 15 Weed Eather
most any small engine shop can help you in getting parts for you trimmer.then might have discontenu this trimmer for pars if so or go on line google and sercret for this trimmer let me know what you fine out.ok
Jul 24, 2009 | Poulan Pro 25hht 25cc 22" Gas Hedge...
Won't stay running
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Jim
Jun 25, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Lose gas line poulan weed eater
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines.
(HINT): when feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
Jim
Jun 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Open Questions:
For Any Kind Of Toshiba Laptop Problems Call Our Toll Free Number +1888784-9316 As the number of cybercrimes and harmful online attacks are increasing these days, it is difficult to keep ourselves safe while surfing the websites of various sites online. If you are looking for a safe online risk reduction scenario, then trust the tech support of TechFree for Toshiba products. Toshiba laptops and other devices get best maintenance and recovery by the services of Toshiba support. Toshiba support provides best risk safety from online threats and also recovery for broken computers and other peripheral devices. Online threats in the form of viruses, Trojans and malwares that are prevalent everywhere pose serious safety threats to the customer's personal information. Various other regular issues like slow computers, snail speed processing, recurrent screen freezing, frequent and without reason computer shutting down and restarting etc. also prove to be a reason of headache for the customers. In case you want all your tech issues to get resolved while you can be busy doing your usual life stuffs then get in touch with the fabulously supporting Toshiba supprot team. You can get the benefit of 24/7 tech support service at your home or office by calling on their toll free helpline number +1888784-9316 Technicians of Toshiba support got certified for involvement of advanced technology and still making it available for customers at affordable prices. Also, many profitable deals and offers are provided to the customers. Your search for that perfect tech support with features like reliability and consistency is over with Call Toshiba Online remote support service technique makes delivery of support easier and comfortable for the customer. Also, professional tech services become more trust-worthy with the 30 days money back guarantee it comes with. Toshiba technicians make efforts of delivering the best customer support along with proper knowledge sharing which helps the customers to get proper understanding about all issues and their resolutions. For tech related support contact tech service team of TechFree on their toll free helpline number +1888784-9316 anytime. Toshiba support providing professional and certified tech experts will use the most appropriate troubleshooting to resolve tech issues in least turnaround time.
Jul 20, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
