Question about GARDENA Water Timer
On one 2hr Timer the clock does not tick to record the minutes used.On the other the thread is broken connecting the Tmer to the tap.
There are no replacement parts for water timers.
Clock motors are small with plastic gears, and they wear down and get slow, and then overheat and quit. If timer is electronic, the circuit board and components have finite lifespan and don't last long exposed to elements and daily temperature fluctuation
Be sure to bring water timers inside each winter to avoid cracks caused by ice expansion.
Open following link for some Gardena instruction manuals:
http://waterheatertimer.org/How-to-program-Gardena-C1060.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 07, 2011
How to set clock ON GE- JB860SJ1SS
RANGE SETTING THE CLOCK NON-ELECTRONIC CLOCKS: To set the clock:
  1. Push the center knob in.
  2. Turn the clock hands to the correct time. If the Minute Timer pointer should also move, let the knob out, and turn the Timer pointer to OFF.
DIGITAL CLOCKS: To set the clock:
  1. Push in the center knob of the Minute Timer.
  2. Turn knob in either direction to set the Digital Clock numerals to the correct time
ELECTRONIC CLOCKS: To set the clock (models with Clock or Set Clock pad):
  1. Press the Clock pad
  2. Press the + / - pads or number pads (depending on model) to set the time.
  3. Touch the Start pad. The time of day will show in the display.
To set the clock (models without Clock or Set Clock pad):
  1. Press and hold the + and - pads for 3 seconds.
  2. Press the + / - pads to set the time.
Nov 05, 2017 | Audio Players & Recorders
I have just purchased a Magnaox ZV247MG9 and to convert VHS to DVD and my first DVD is blank. All the connections are made and I followed the manual, but am confused as to what happened.
I hope you have resolved this by now but in case you haven't: The only thing I can think of is that the disc was not compatible. Make sure to use one of the discs listed in the manual.
Mar 19, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
Setting clock
Hello
To set clock:
1. Press "Timer/clock button". The hour digit begins to flash.
2. Press (<< P.DOWN or >> P.UP) on the multicontrol to set Hours.
3. Press SET button. The minute digits begins to flash.
4. Press (<, P.DOWN or >> P.UP) on the multicontrol to set Minutes.
5. Press "Set" button."CLOCK OK" appears on the display. The clock stops flashing, and the clock timer starts from "0" seconds. If the clock is not set "AM 12:00" will flash instead of the clock indication. When the time has been set, TIMER/CLOCK can be used to operate the daily timer recording timer.
If you haven't the user manaul to your set with you now, send your email address to me by Fixya comment bos. I've the downloaded user manual to your set, and I'll send a copy of it to you by return mail. OK.
Jan 21, 2012 | JVC MX-D402T Shelf System
How do I reset the clock on a Taylor timer 5891-21?
1. Press and hold the "Clock/Timer" button until you hear a beep and the time starts to flash.
2. Adjust the time using the "Hour" and "Minute" buttons. Note the clock includes AM/PM.
3. Tap the "Clock/Timer" button to restart the clock.
Nov 17, 2010 | Taylor Hardware & Accessories
How to reset the clock on my cannon chesterfield gas cooker
Chesterfield gas cooker/clock - doesn't display time, ticking sound in background, timer still works but difficult to set more than 15-20 minutes.
Oct 17, 2010 | Cannon Chesterfield C60G Kitchen Range
How to stop clock ticking
It isn't that hard to get the clock to stop ticking.
Disconnect power to stove so that you do not get a shock.
Take off back panel screws behind the clock.
disconnect the wires to the clock.
Make sure that the wires are not touching anything metal. If they are not insulated, you will want to tape them.
Do not use the hammer to the dial method to get the clock to stop. It is fast but may cause damage.
Apr 15, 2009 | Kitchen Ranges
SETTING SELF TMER FOR CANON 1100
Press the self-timer button (marked with a one-handed clock). Use up/down to select an option. Start the self-timer by pressing the shutter release button.
Feb 24, 2009 | Canon PowerShot SD1100 IS Digital Camera
Zenith XBR617 DVD Sometimes doesn't record full time scheduled
sounds like your clock is wackie. SEE if there is a back up [computer type button] battery in a small draw just by the clock or see your manual for directions on where it is. Replace the battery.Do you have interupted electircity in your [brown outs] area ? That shuts down the recording timer and resets it. Your clock is the 1st thing I would check, 2nd is the electricity.
Nov 12, 2008 | Televison & Video
Downloading from hdd to dvd+r ?
When you recorded your "footage" was the dvd recorder set to 2hr (sp), 2.5hr (spp), or 3hr (LP), etc.?Because for example, you downloaded (recorded to your hdd)your "footage" that is say 3hrs long, and your recorder is set to record at 2hrs mode(sp), then when you put a blank dvd in recorder to transfer from hdd to blank dvd, the 3hrs of your "footage" has been recorded in 2hr mode on your hdd, and will only record in 2hr mode onto your blank dvd. Solution is to set your recorder to the record mode in which your "footage" length is. For example, if your "footage" length is 3hrs, set your recorder mode to LP then when you insert your blank dvd should be okay. Or, set your recorder mode to 2hr (sp) and make two recordings of your "footage" onto hdd, splitting them up: 2hr on one, and 1hr on the other.When you burn to blank dvd you will have to have 2 blank dvds, one for 2hrs, the other for 1hr. I had to same thing happen to me. I hope this works for ya.
Jul 28, 2007 | Philips DVDR3455H/37B
Timer record set
Make sure the clock is set. Since the clock must be set before the timer will work, be sure you have entered an accurate date, day of the week, and time (including AM or PM). And always check the clock after a power outage. Also, check that your videotape does not have the tab removed which protects against further recording.
Mar 08, 2007 | Zenith TVBR1322 13 in. Combo
GARDENA  Water Timer Logo
80 people viewed this question
Top GARDENA Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Bill Boyd
Are you a GARDENA Hardware and Accessory Expert? Answer questions, earn points and help others
