Question about Ovens
All the knobs are the same, but the one on the bottom is the one that is broken if that really helps!
    Top Expert:
  • Ovens Master
  • 76,164 Answers
Any appliance repair shop can order this part for you, Fixya however does not have any ability to order parts for any type of consumer product, we supply technical advice only.
Posted on Apr 06, 2011
How to replace selector switch on a belling country chef,the switch is ok but the shaft to the knob has broken
I have a country chef half gas and half electric ,the shaft has broken of half of it is in the control panel and other half is in the knob. How do I get a new shalf and how do I put it back on ,I would be very grateful for your help please message me.
Apr 30, 2014 | Belling Ovens
Both oven knobs have come off and although don't appear to be broken we can't seem to fix them back on properly
First try a layer of silver paper around spindle.
If not satisfactory then try a "No nails" type of clue.
Jun 04, 2012 | New World E90DOa Electric Double Oven
Bottom oven element stays hot will not cut off
In order for the element to stay on, the oven switch must be broken. No details are provided, but if your oven is like most, you have an Oven Selector knob for ~bake, broil, clean and another knob for Temperature selection.
Look at your Oven Selector knob closely to make sure it is not slipping on the shaft. It may be as simple as the knob being broken, and even though you are turning it to the Off position, the switch may still be on. If the knob is indeed turning the switch shaft, then it is most likely the switch stuck in the own position. Thanks for using FixYa.
Mar 03, 2011 | Ovens
The stem/shaft that holds the oven knob seems to be broken--the knob turns but does not turn the shaft. Is this a repair an amateur can do and what part do I need?
first pull the knob off the shaft and check to see if its broken where the shaft is supposed to lock-in if so u jus need a new knob. if not you have to pull the panel off the stove and replace the shaft this shouldnt be too difficult either way.
Jan 24, 2011 | Viking 27" Professional Select Built-in...
Creda Oven Model ESO 210 broken multifunction selector knob
Same thing happened with my Creda ESO 210. The function selector works find. It just doesn't rotate the piece of plastic that has the funtion symbols on it. I contacted the authorised parts supplier in Canada and was told it would cost $90 for the part. After a long wait, the part arrived and it wasn't the correct piece (they'd ordered the little plastic circle with the function symbols on it instead of the knob thingee that moves it). So, if that cost $90, I dread to think what the broken mechanism would cost. So, I gave up and I simply count the clicks from the off position to use my oven. However, if you really want to follow up on this, you can contact www.creda.co.uk.
Jan 20, 2010 | Creda Europa E010E Electric Single Oven
Is the knob that turn the light on repairable? The oven light is on but would not turn off. The knob just keeps turning...
HI,and a merry Xmas.
Yes it is repairable, it is going to be one of two things.
1--the control knob is cracked or broken causing it to twist round without turning the control.
2--the spindle on the control is broken or loose inside the switch.
Pull the knob off, and see if yopu can turn the switch on and off with a pair of grips or pliers.
This way it will enable you tell if it is just the knob or the switch that is faulty.
Good luck.
Please leave feedback for my suggested solution.
Dec 25, 2009 | DeLonghi Ovens
Grill control knob broken
hello sir/mam
please check the back portion of the oven you will see the screws which will be fixed to the top cover you should unscrew the screws and using a screw driver push the top cover .Then you can fix the control knob.
Oct 04, 2009 | Smeg DO 10PSS Stainless Steel Electric...
The element won't turn off. When I turn the knob,
Probably a broken element. It is shorting out against the element canister. If not broken and shorted. You have a bad timer.
Jul 03, 2009 | Frigidaire Ovens
BOTTOM OVEN WIILL NOT HEAT
check the bottom heat element and see if you see any burn out spots on it,if so you will have to replace it(easy)let me now-mike
Oct 13, 2008 | GE JKP28 Electric Double Oven
Self cleaning frigidare oven FEF368CCTD
If this stove has knobs, Make sure the clock keeps time. If it doesn't you will have to manually turn this off. (DON"T FORGET OR LEAVE WHILE CLEANING) Make sure there are no large puddles of oil or grease on the bottom of the oven.If the oven is really dirty it may stink a little. Nothing but the racks can be in the oven.Press the lock button and slide the lock lever to lock the door. Set the stop time for 3 hours and turn the knob by the clock to auto. Turn the oven knob to clean. (MAY have to push to turn all the way to clean) It should start heating up. Let it finish and then cool down. It will not let you unlock or open the door until it is completely cool. Wipe out any remaining ash with a wet rag. ALL CLEAN!
Jun 28, 2008 | Ovens
Ovens Logo
29 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
