Question about HP Scanjet 4890
When i try to scan 35mm slides, all i get is a big black rectangle.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 144 Answers
Hi there!
make sure that you put the picture (the item you're scanning) on the right side of the scan bed, try scanning other sizes of pictures too, if that dont work, ive posted the link for that printer here, check out the manuals and troubleshooting steps too, they're all for free. you can also contact 800-HP invent or 800-474-6836.
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&product=446436&
Posted on Apr 07, 2011
Scanning 110 Instamatic slides on Epson Perfection V700 photo scanner
Hi Stanley - does this youtube video help? http://www.youtube.com/watch?v=EcALdbbCnSk
If not, let me know and we can investigate further.
Regards,
Justin.
Jan 17, 2014 | Epson Perfection V700 PHOTO Flatbed...
Does the HP photosmart 2710 scan negative ansd 35mm slides?
This multi function printer/scanner cannot scan 35mm slides and negatives.
Some flat bed scanners with a lighr scource that shines through 35 mm slides and negatives can scan them.
You will be better off getting a dedicated 35 mm slide/negative scanner.
Check out this WEB site foe slide scanners.
http://www.google.com.au/#q=35mm+slide+scanner&hl=en&prmd=imvns&source=univ&tbm=shop&tbo=u&sa=X&ei=dYFIUPKBKMSyiQedl4G4DQ&ved=0CEkQrQQ&bav=on.2,or.r_gc.r_pw.r_qf.&fp=4469b7ccc4340a33&biw=1016&bih=535
Sep 05, 2012 | Epson Office Equipment & Supplies
When the projector was turned on it started to cycle as when ejecting slides then it stopped and seems to be jammed...the rectangle black screen that opens and closes during the cycle to view slides is...
First of all, remove the tray (use the emergency tray removal in the center hub of the projector). BE CAREFUL not to spill your slides, so before you remove the tray, make sure the tray ring is in position & tight, then when you remove the tray turn it upside down immediately and move the tray plate to the "zero" position. Remove any slides that might be in the gate of the projector. Turn the projector on and cycle the projector 2 or 3 times in Reverse. This should clear a tray/slide jam. Good Luck !!
Jan 24, 2011 | Kodak ABR Ektagraphic 35mm 140 Slides...
I'm trying to
Check what resolution you are scanning at. For a 35mm slide it should be at the highest setting since you are probably going to enlarge the image.
Oct 27, 2009 | Computers & Internet
How to scan slides with Visioneer 9520 USB Scanner - it scans who
I have successfully used my Visioneer 9520 to scan 35mm slides, and they came out perfect. To do this, in my image editing software, I select File/Import/Acquire/Visioneer ScanManger Pro. This opens the VIsioneer scan manager window, where I select "Scan 35mm using:" and then I choose the desired scanning configuration, e.g., "35mm Better, 35mm Best, Custom" etc. See image below.
BTW: After several moves, I have lost my 35mm scanning template. Do you know where I can get another one, or do you know someone who could actually scan theirs and email the image to me? I could then create a duplicate from heavy black construction paper or card stock.
Jul 26, 2009 | Visioneer OneTouch 9520 Flatbed Scanner
Trying to scan 35mm slides
slide scan is not an option on that model. slide scanner is an option in some models of scanners. I have a HP one as most HP scanners have the setting built into the scan firmware that lowers and higher the light to get correct scan. brother model will not do this its just normal scan setting.
Feb 16, 2018 | Brother MFC 240C All-In-One InkJet Printer
Scanning 35mm slides and saving to computer
In order to scan 35mm slides to your computer, you need a scanner that has the capability of doing this. These scanners will either come with a 35mm adapter that will allow you to scan the slides, or there are scanners that will scan only 35mm slides. A good recommendation is either this or this.
Thanks and please take a moment to rate as fixya.
Nov 24, 2008 | Canon Office Equipment & Supplies
Scanned 35mm slide comes out as rectangle with dark edges
I've not ever seen "square" 35mm slides. By definition they are a rectangular positive film in an outer square "mount".
If you have a truly square piece of film then it is not a 35mm slide. You may have to use settings other than those for a 35mm film but these would be I don't know.
When were they taken (approximately)? What brand of film? Are they in a cardboard "mount?
Aug 01, 2008 | Epson Perfection 4490 Office Flatbed...
Lomo supersampler.... how do i get the film out?
on the camera you have a round loop on one side and a rectangle loop on the other side. next to the rectangle there is a narrow black slide button. press that button then open the camera. on the bottom where the film on the outside of the case is a black button that hold the film in place. slide that outward then remove the film.
May 12, 2008 | Lomo Supersampler 35mm Point and Shoot...
HOW TO GET FROM 35mm COPYING TO REGULAR COPYING
Configure your scan buttons in the bottom right corner of your screen (when you click on the scan icon in taskbar). This will help you to go back where you want to be. You may find it easier to use XP's inbuilt scanning facility instead or scan via Photoshop.
Sep 17, 2007 | Visioneer OneTouch 8920 Flatbed Scanner
HP Scanjet 4890 Logo
89 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
