Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Mine was running fine , set it down to take a break. Restarted just fine, and idels great , but as soon as the throttle is applied it dies..help.....
    Guru:
  • 479 Answers
Check there are no kinks in fuel line.
Make sure that the air filter isn't blocked.
Check the throttle cable is operating the throttle plate in the carburettor ok.
Ensure chain isn't too tight.
The carburettor should be a tight fit on the air inlet manifold.
It's possible that some of the jets could be blocked in the carburettor. You can try and clean these with compressed air but ensure you remove any seals gaskets, springs on the diaphragm pump , primer bulb etc as they can be damaged by the pressure.
Posted on Apr 07, 2011
Hey everyone i have a suzuki 1978 ts 250 and it runs but as soon as you pull the cable for more fuel it just smothers and die it have no vacuume leaks and i have tamperd with the air and petrol screw but...
Your carburetor has multipule dirty passages. Its getting the right fuel air mixture at Idle but when you open it up it doesn't, which is why it dies. A through soaking of the carb in carb cleaner sould help or simply pull it off and have a shop clean it.
Oct 14, 2013 | Motorcycles
Truck starts but died when i hit the gas
in my 03 1500hd had real rough idel clean the throttle body my truck idels perfectly now dosent take 30min and throttle body cleaners 8$ at autozone theres how to videos on youtube thats what i did
Jul 07, 2012 | 2002 Chevrolet Silverado 1500HD
2003 yz 250 starts and idles but runs rich and bogs as soon as the throttle is applied
Hi, Anonymous and the usual suspects are:
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Intake system air leak.
4. Vacuum piston malfunction.
5. Accelerator pump leaking or no output.
6. Plugged bowl vent or overflow.
7. Fuel level in bowl too low.
8. Restricted fuel supply passages.
9. Plugged jets or passages.
10. Worn or damaged needle or needle jet.
11. The enrichner valve not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2002 yz250 idles fine but bogs and tries to die when twisting the throttle...
Bike dies when you give it throttle
YAMAHA YZ250 LC Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Mar 19, 2012 | 2003 Yamaha YZ 250
I have a 1990 chevy pickup 1500, 2wd. auto. the problem os that it idels ok. while in park you can give it halg throttle it runs fine, but as soon as i put it in drive and drive it down the road it starts...
Check dist. cap and rotor and replace. Just fixed one last week. Rotor was causing a misfire under load and coil contact to rotor was worn out down too the cap. Graphite dust from the center contact in cap was all over the rotor causing a misfire. $25.00 in parts or less. While you are there replace wires and plugs. Autolite ap25 plugs 2.99 each
Apr 09, 2011 | 1992 Chevrolet C1500
My 2000 Dodge Caravan shifts from second gear to third gear way too soon and causes the engine to lug like on a manual transmission auto if you shift it to the next gear too soon, also It won't down-shift...
my van is doing the same exact thing but the othe day it was perfectly fine no slipping i went about 25 miles and i started off from a stop the engine rev and tranny slipped and the van died i restarted the van it runs great but acts as if there is no transmisson does not take power frm ngine when shfted does nothing please help
Mar 16, 2011 | 2000 Dodge Caravan
My pressure washer starts fine but after you run
HAVE GX390 RUNS ON LOW IDEL THAN DIES ON HIGH NEW GAS
Feb 20, 2010 | Honda Pressure Washer PSI 3000
Engine Dies in Idel
this is usually a bent throttle stop caused by people flicking the foot off the accelerator pedal , just bend it back to origional position , hope this helps
Jan 27, 2009 | 1994 Ford Escort
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
143 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
