Question about Texas Instruments TI-89 Calculator
When I attempt a hyperbolic function of a complex number on my TI-89 titanium I get a domain error. Why is this?
    Sergeant:
  • Texas Instru... Expert
  • 265 Answers
See image below
When I attempt a hyperbolic function of a complex - when-attempt-hyperbolic-function-complex-diww3yrrd4bnfxdt4es1ohjj-1-0.jpg
Posted on Oct 08, 2016
  • Texas Instru... Master
  • 7,993 Answers
Have you checked the calculator's manual to see if the calculator is able (natively) to handle functions of a complex argument. It is able to handle simple algebra with complex numbers, powers, roots, solving a polynomial equation.
For this calculator, the hyperbolic functions must have a real argument otherwise you get a domain error. But just to make sure, try the exponential function with i (imaginary unit) as argument. If it comes back with a domain error you have your answer.
Posted on Apr 09, 2011
"Undefined" as answer to an inverse sine calculation
I suspect that you are confusing things a bit.
The inverse sine, called the arcsine is a function defined in the closed interval [-1,1]. And so is the inverse cosine. Any value outside this interval will give you a non-real result (meaning a complex one).
There are no limitations on the domain of definition of the inverse hyperbolic sine or sinh^-1
If your input value is allowed to be complex, the arcsine function gives a complex value. See the screen capture
Mar 17, 2014 | Texas Instruments TI 89 Titanium Graphing...
I am trying to enter a exp to an complex number and am getting a domain error. How do I clear it up
You got a domain error because your angle unit is not set to radians.
Change the angle unit in the MODE configuration screen. In the following screen I calculated the same expression under EXACT and APPROXIMATE calculation formats.
Jan 23, 2012 | Texas Instruments TI-89 Calculator
Domain error occurs if you using polar form of complex numbers in Degree or Gradian angle units.
You have to set up Radian mode and then input complex value. See captured images
At first, you can enter a complex number in r*exp(i*theta ) form. This is exponential form of complex number. However, use this form in Radian angle mode only. It causes a Domain error in Degree or Gradian angle mode. To resolving this problem type Mode then F1 and set up Radian mode
When I attempt to use hyperbolic functions for complex numbers i get a domain error
For this calculator, the hyperbolic functions must have a real argument otherwise you get a error. But just to make sure, try the exponential function with i (imaginary unit) as argument. If it comes back with a domain error you have your answer.
Apr 06, 2011 | Texas Instruments TI-89 Calculator
Ti-89 titanium
Having gone over a month with no response, I assume this is no longer a problem.
Jun 26, 2010 | Texas Instruments TI-89 Calculator
"domain error" message on ti-89 titanium
I had the same problem, this worked for me:
Mode -> page 2 -> Exact/Approx change from "Exact" -> "Auto"
May 12, 2008 | Texas Instruments TI-89 Calculator
An argument must be in a specified domain. For example, ans(100) is not valid because the argument for ans() must be in the range 1–99.
May 11, 2008 | Texas Instruments TI-89 Calculator
Dec to hex conversion
Not sure if TI-89 mode keys are the same, but here's the solution for that calculator:
1. Hit the mode key
2. Hit F3 to get tot Exact/Approx (might be different for 89T).
3. Set it to Exact.
4. Take a look at T-89 manual pages 327, 328, 329.
Nice of TI to NOT include that in the manual, huh?
Dec 13, 2007 | Texas Instruments TI-89 Calculator
Graphing radical functions
I have a TI-89 Titanium and I have experienced the same problem. HERE IS HOW TO FIX IT:
Goto " MODE " and scroll down the options until you get to
" COMPLEX FORMAT " change that option to " RECTANGULAR " and press ENTER until you exit out of the " MODE " screen. (very important that you press ' enter ' until you exit because if you don't, it will not save your changes. )
Sep 19, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
781 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
