Question about Mtd Garden
I need a wiring diagram for a LT4200 I have a wire off of the solenoid and I have no idea where it goes
  • 979 Answers
SOURCE: GE refrigerator wiring diagram
Icemaker must be at 28 degrees to make ice. The harness supplying the power should have 120 volts there at all times, and the icemaker itself is the device that switches the power off and on once all requirements are met. Your diagram for the fridge is on the rear service panel, or in a packet on the insisde rear..accordianman
Posted on Apr 03, 2008
keemo68
  • 1263 Answers
SOURCE: WIRING DIAGRAM FOR 1984 AMC EAGLE
well you have several options you can go to a dealship and have them copy the diagram for you(i do this all the time) or you can purchase a repair manual at Napa or Oreilly's for around 20 bucks. it has diagrams and schematics in it. it also has alot of instructions in it so you can do repairs yourself. By the way i'm surprised that the mechanic doesn't have these diagrams himself. I was wandering why it won't start after you changed the plugs and wires could it be that maybe the firing order is wrong. i've done that myself a time or 2. double check the the plug wires to make sure they are in the right spot. if the problem is it won't crank. chances are you have a loose ground. please rate this..thanks
Posted on Sep 05, 2008
  • 566 Answers
SOURCE: hooking up wires to battery, solenoid, altornater and starter
hi from the uk if you look at startermotor solenoid you will see two large threaded terminals with nuts? and a third small terminal either spade or round terminal ok? now you should see thet one of large terminals already has a metal or braides strap secured to it and the actual startermotor body? LEAVE THIS ALONE the other large terminal is the one you fit the positive+ lead to from battery also there should be another lead to also attach to same terminal this one supplies power for vehicles electrics etc ensure you secure these with nut ok? now the third small spade or post terminal you will hav a thin wire nearby ?this attaches to thisterminal on its own on solenoid this wire is the one that activates starter when ignition is turned to key start position ok? as for interior light not working ? try again when you complete the above also make sure bulb is ok? ps! before you reconnect starter wires ensure the earth/ground lead is disconnected from battery and when reconnecting battery connect positive lead first then the earth lead or if you try other way you will have sparking from pos lead as you try connecting to battery hope this info is clear instructios for you to follow and wish you luck best wishes from england
Posted on Nov 26, 2008
  • 77 Answers
SOURCE: Looking for a starter solenoid wiring diagram
save yourself some money and go get a lawn mower solenoid and find a way to mount it yourself. I have done a johnson outboard and a tigershark jet ski this way with no problems.
Posted on Jun 21, 2009
SOURCE: complete wiring diagram for a 1990 36volts club car golf cart
http://cartaholics.com/forum/index.php?showtopic=1880&hl=green+wire
See if this helps. Good luck!!
Posted on Jun 30, 2009
I nned a wiring diagram for a murray lawn tractor
My search engine, Bing, came up with a great diagram when "Murray lawn tractor solenoid" was put in the images section. It shows clearly which wire goes where on a generic system.
Aug 15, 2014 | Garden
Solenoid wiring diagram
If you have a relay to the starter solenoid then red one from the battery then red from the relay to the starter solenoid. The starter solenoid earth wire goes into the starter housing for the brushes if not then the red wire from the battery goes direct to the starter solenoid big terminal. The other big terminal will already got inside the housing. That takes care of the really heavy wires . The small wire goes to the little terminal between the big terminals.
Jul 27, 2014 | 2000 Ford Expedition
Why cant i find a wiring diagram for a 2003 chrysler pt cruiser anywere?
You can. Try a Chilton's manual or the how to books sold at auto parts stores. The starter solenoid wire goes directly to the ignition switch The fuse marked IGN controls power to the starter solenoid.
Jul 17, 2014 | 2003 Chrysler PT Cruiser
Pcm wiring diagram
There isn't much to the wiring diagram There is only two wires to the N75 turbo control solenoid.Pin 2 on solenoid green and brown comes from the ECU pin 64 and Pin 1 Green and white wire goes to a 10 pin connector in the plastic channel on the left side of the engine bay pin 6 and then that then goes on to connection 2 (87) in dash panel wiring harness.
Jul 11, 2014 | 2000 Volkswagen Golf
Need a diagram of wiring for starter solenoid/1992/ford/ranger
Not much to the solenoid, but I'll attach a wiring schematic for 3.0 and 4.0. Be careful not to touch the two post together on the solenoid or it will start right up on you! One lead goes directly to the starter and the other goes to the positive lead on the battery. Good luck.
Apr 16, 2014 | 1992 Ford Ranger
1990 ford bronco II solenoid diagram
Not sure what you are saying the problem is.
You have a red wire on the solenoid that goes to the battery and a 50amp fuse. The red and lite blue wire comes from the key switch.
Then you have a black wire that goes from the solenoid down to the starter to energize it. You have a large red wire on the starter coming from the battery to power it.
Feb 08, 2013 | Cars & Trucks
I need to see diagram for the battery wiring for a ford f250 460 cu in engine from starter back to battery. I am not sure what positive cable i need and how it is connected to starter and solenoid then...
There are two cables to the starter. one -, one +, both of these come directly from the battery. The + goes to solenoid on one side then from the other side to the starter. If you have the solenoid on the wheel well. The - goes to the block any where you want, but usually on the bolt that holds the starter on. If you have he starter with the solenoid on it then the+ goes to it. Also on the solenoid there is a smaller wire that is the ignition wire from the ignition switch
Nov 10, 2010 | 1996 Ford F250 Crew Cab
I need a wire diagram for a 1981 harley davidson superglide for the starter wireing
The wiring is simple for a starter. You have a starter solenoid on the bike and a starter relay. When you press the button to start your bike, the button has a wire that runs to the relay. This triggers the coil in the relay and pulls the contacts in. You have three wires that run to the relay for the starter. One hot wire, a trigger wire from the starter button and a wire from the relay to the solenoid. When you press the button, the relay pulls in and makes the wire going to the solenoid "Hot".
The solenoid has three wires going to it. The large battery cable goes to the "long post" of the solenoid, There's another battery cable going to the starter from the bottom of the solenoid, The wire from the starter relay goes to the small terminal of the solenoid. The small wire from the starter relay is the trigger wire for the starter solenoid. When this wire goes hot, it magnetizes the solenoid and pulls the plunger inward. The plunger bridges two large contacts in the solenoid to put high current voltage to the starter.
If you need a schematic, contact me directly at wd4ity@bellsouth.net. I cannot send a file via this medium but I can direct e-mail. Remind me of what you need when you contact me.
Good Luck
Steve
Aug 08, 2010 | Harley Davidson FXD - FXDI Dyna Super...
Need a wiring diagram for a 1969 Ford F250.
there should be a slot for each wire on back of ignition play with them till you get it right cant hurt anything
Jan 14, 2010 | Ford F-250 Cars & Trucks
Need a wiring diagram for solenoid on Ford lawn tractor. Trying to reconnect solenoid after replacing it (battery loses its charge almost too easily, and we constantly have to charge the battery). Any...
one wire goes from the positive terminal on the battery to either post on the solenoid, another wire goes from the other post on the solenoid to the starter. you will have a 3rd small gauge wire coming from the key switch and this goes to the small terminal on the solenoid. all in all it's pretty straight forward. hope this helps you.
Sep 19, 2009 | Ford Garden
Garden Logo
59 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
